Re: 56 made2drag
loosely have steering column in place...it bolted right up to the rag joint. still have to put bed on and maybe move cab up an inch before bolting it up. will put the 76's wiring harness/fuse block and connector on steering column soon so i can actually use the key to start it....LOL
feel good about the 3 hours spent today
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
Re: 56 made2drag
Good progress.
Kim |
Re: 56 made2drag
Re: 56 made2drag
Re: 56 made2drag
Re: 56 made2drag
Re: 56 made2drag
Re: 56 made2drag
Re: 56 made2drag
Re: 56 made2drag
Re: 56 made2drag
Went just through your build.
I have great respect of what you've done so far to the truck! I think, I had walked by with tears in my eyes ![]() I certainly can learn from you!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#12 | |
Re: 56 made2drag
#13 |
Re: 56 made2drag
Looking good.
Kim |
#14 |
Re: 56 made2drag
thanks! It seems to fit so far. The frame is now the length of a stock 76 short bed frame....give or take a 1/4 inch. I think once the front is lowered with stock squarebody rallies it will tuck in the front....im crossing my fingers...the rallies I'm getting are super narrow and are really sucked in on my friends 69 c10....he says he thinks they're for a van?
#15 |
Re: 56 made2drag
#16 |
Re: 56 made2drag
#17 |
Re: 56 made2drag
#18 |
Re: 56 made2drag
![]() drilled these nylon inserts out and tapped the shaft in 2 1/4 inches for the steering wheel to be closer to the dash.
#19 |
Re: 56 made2drag
#20 |
Re: 56 made2drag
#21 |
Re: 56 made2drag
still have to bench bleed the master cylinder and replaced some brake lines, but i think the hard stuff is done
#22 |
Re: 56 made2drag
#23 |
Re: 56 made2drag
the build is coming along man ill follow the rest of the way
big_moss bagged 51 3100 build |
#24 |
Re: 56 made2drag
Lots of nice progress.
Kim |
#25 |
Re: 56 made2drag
You have done a great job on a very small budget
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
