Re: Project 69SWB
That looks good, wonder if you could use some lab metal filler to seal it up real good and keep it from leaking?
Scott |
#2 | |
![]() Join Date: Jun 2011
Re: Project 69SWB
Posted via Mobile Device |
Re: Project 69SWB
Cool, I'll be watching and taking tips.
Scott |
Re: Project 69SWB
Came out great!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
Re: Project 69SWB
thanks fellas.
Re: Project 69SWB
Nice work! Roof Looks Great!
" I strive for a level of perfection that I do not possess the skillset to achieve. "
Ariel <> '67 C10 Shorty Stepside *** Build On Hold *** First Ride <> '81 C10 Long Fleet *** Current Project *** ![]() |
![]() Join Date: Oct 2010
Re: Project 69SWB
Nice work Jimmy!
John Mild Custom 68' Work Truck Build Facebook LoL 1977 Trans Am (Project) 1965 Chevelle (Project) |
Re: Project 69SWB
Thank guys!
I laid down some epoxy on that part of the roof last night, then got up this morning before work and spread out some Evercoat Rage gold on the repair... going to sand that down when I get home from work this evening and see where I'm at with it. |
Still Learning
Re: Project 69SWB
Wow, Lot of good progress on your cab. You are knocking it out. It's pretty rewarding when it's all done and in primer.
Re: Project 69SWB
Really liked what you started with. Progress is coming along great.
LIFTED OR LOW THE ONLY WAY TO GO!!!! Check out my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=517346 Projects 56 Chevy pickup Porterbuilt FR/RR dropmembers |
#11 | |
Re: Project 69SWB
Thanks ddubbs! I was pretty fond of my truck before I tore it down, but it needed some work. Looked a lot better in the pics than it did in person. It was a 50ft truck as I called it. (looked great from 50 away) :-) |
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
Re: Project 69SWB
Subscribed! This is a fantastic build you have doing here. I sincerely appreciate the PM's and will be watching your progress.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
#13 |
Re: Project 69SWB
no problem Al! Hope to keep you entertained. :-)
#14 |
Re: Project 69SWB
Was able to get the roof in epoxy yesterday and start on finishing up the repair to the section I had cut out.
This was my first pass with the filler (evercoat rage gold), I sure like working with it. nice stuff. I did one other coat after this one and then top it off with a thin coat of and light sanding of evercoat polyflex glazing putty. I had originally just laid the epoxy over the area I was working on, but after I got the repair done I went ahead and did the whole roof. Letting it dry tonight, then I have a couple tiny dings to fill in and will do one more coat of epoxy and then lay down the polyester primer... just on the roof only. Afterwards I'll move on to another area. first pass of the filler After the epoxy.. I've always had a problem with orange peel due to my compressor not having any guts... especially with the thicker primers. I've only painted 2 jeeps before and color sanded till I was ready to puke. That problem is going away. I figure out of all the money I am spending on the truck I can at the very least upgrade my compressor and do a much better paint job. So by-by 26 gal Craftsman and hello in a couple days 60 gal Ingersol Rand with almost triple the CFM. :-) will post of pic of that when it comes in. |
#15 |
![]() Join Date: Jan 2011
Re: Project 69SWB
Have you been using the 401 or 402 catalyst? (Assing DPLF)
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#16 | |
Re: Project 69SWB
Epoxy: Black PPG Shop-Line JP377 with JH3770 hardner. Poly: Gray PPG Shop-Line JP205 w/hardner Filler: Evercoat Rage Gold Glazing: Evercoat Poly-Flex Paint: PPG Shop-Line JAU (Black) Posted via Mobile Device |
#17 |
![]() Join Date: Dec 2006
Re: Project 69SWB
Are you planning on going with a single stage or BC/CC. I'm trying to learn as much as I can cause i'll probably be painting my truck myself. Trying to figure out the pros/cons of the different options out there.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#18 |
Re: Project 69SWB
Jimmy, the roof looks great.
Scott |
#19 | |
Re: Project 69SWB
Thank you Scott. I'll be glad to get done with the cab. It's a huge peice of the puzzle. Posted via Mobile Device |
#20 |
Re: Project 69SWB
ok the roof is done for now. I fixed a few dings and laid down another coat of epoxy, let it dry for about about 2 hours and then went over it went 2 coats of poly (1st coat light). Going to leave it alone for a couple days while I tinker with some smaller stuff then get it flipped by right side up and work on the back and corners.
Next time I paint I'll have my new air compressor, can't wait. |
#21 |
Re: Project 69SWB
Thanks for the info, the roof looks great. You are inspiring me to do my paint myself. If you have any tips or tricks please let me know.
#22 |
Re: Project 69SWB
Looks really good man. Shopline is great stuff. Thats what Im buying as I need more.
Keith, go for it man. ![]() Posted via Mobile Device
#23 |
Re: Project 69SWB
Roof looks great, keep it up!
#24 | ||
Re: Project 69SWB
Keith all I can tell you is what I've been told to do and what I've realized in the process of being told what to do. haha. tips (not professional, but noteworthy!) 1. Make sure you clean the surface good. (I use PRE from Eastwood) 2. Light coat first, the medium coats after that 3. A good air compressor that puts out at least 11 cfm. 100% duty cycle is preferred. Otherwise plan on sanding a lot of orange peel out. With my craftsman 26 gal 4ish CFM I had to use a HVLP gun it wouldn't handle a regular paint gun... and 3/4 of the way through that roof top is was pretty much done... hence the orange peel. (not enough pressure to atomize the paint) I'm not saying you can't do it with a puny compressor, but it makes for more work. 4. Let it dry, don't rush it. Epoxy I'll let dry 24 hours before I do body work on top of it, poly I let dry overnight, and paint I won't touch it for at least 2 days after I spray it. 5. Let the sandpaper do the work, pressing harder to try to sand faster is only going to clog the paper and/or cause deep scratches. 6. PROTECT YOUR LUNGS. you only have one set... a good coat of primer or paint on your lungs will make breathing difficult for a long, long, time... unless it kills you, then you won't have to worry about it. ![]() When it comes to the job I do it in this order. Starting with clean bare metal... which I usually hit with Eastwood Fast Etch and then PRE Epoxy first. I'm just spraying the areas that need body work, do the body work and sand smooth with 80grit and follow up with some 180, then I feather out the epoxy to the bare metal. This is because I don't have time to do it all within that window that you have to spray the poly without having to go back and scratch up the epoxy. I would hate to go over the entire cab, all the nooks and crannys to do that. Poly second just on top of body work and then I'll feather that out almost to the edge of the epoxy with 220. When all the body work is done I'll spray everything with epoxy, wait 3 or 4 hours then spray it all with poly. (2 different colors is helpful, so when sanding you know when to stop.. I use black epoxy and gray poly. At this point all the body work for the most part is done. It's time for blocking (I use Dura-blocks) to level/smooth out the panels, if I have to put on any filler to level anywhere I'll spray those spots with poly, sand, and then cover everything with epoxy sealer and paint. I also do it all by hand, I don't have a DA... though I may get one now that I have a good compressor. Not sure. That might be more info than you wanted, but that's how I've been told to do things and it's worked out so far. I'm sure there are other ways to go about it as I think paint/body work is a "To each their own" trade. Sorry for the long post but hope that helps someone... that's it in a nutshell. It's Monday, I'm sure I left something out. |
#25 |
Re: Project 69SWB
Wow Man, Wow.
I skimmed through your build awhile back and was impressed then but finally got a chance to concentrate and read through the build more focused. Totally dig your style. Like the I won't settle for anything less than perfection! I now feel I have to order different cab corners from Tabco cause the LMC corners I put on bulge. And they sucked the whole time I was putting them on. Picked up a bunch of tips from you and the guys leaving comments. Dig it Man! Thanks. |
| Bookmarks |
| Tags |
| 1969, black, custom 10, fleetside, shortbed |
