11-11-2013, 08:28 PM | #176 |
Hollister Road Co.
Re: 1949-50 3100
We are working on the engine placement and I have some mounts on the way. This is a GM Connect & Cruise 5.3 package. It includes the motor, torque converter, 4L65E trans, the trans control harness, the engine control harness along with the pedal. Hardware for bolting it together, instructions, and some other items. It does not have the alternator, PS pump, or starter.
11-11-2013, 09:34 PM | #177 |
Formerly- 1972SuperCheyenne
Re: 1949-50 3100
Nice powerplant! Should motivate it nicely.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
11-11-2013, 09:40 PM | #178 |
Re: 1949-50 3100
Wow, that would have looked really nice under the hood of my truck! That's nice Dave!
'72 Ford Bronco project(July 17 2021-?) https://67-72chevytrucks.com/vboard/...d.php?t=828015 59 Apache (sold 6-25-2021) 67 Ford Mustang (re-restored after Harvey) 1968 Jeep Cj5 (2-8-2020 to present) 1992 Jeep Yj (8-17-20 to present) (Jurassic build) www.Classiccarsandtools.com |
11-11-2013, 10:29 PM | #179 |
Re: 1949-50 3100
that looks nice, hot off the press. should treat you well.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
11-12-2013, 01:05 AM | #180 |
Hollister Road Co.
Re: 1949-50 3100
Sounds like I need to bolt it in quick, I don't want any midnight visitors....if I see peacock feathers in the shop I'll know who it was!!! its just over 300 hp so it should move the truck nicely.
11-22-2013, 06:22 PM | #181 |
Hollister Road Co.
Re: 1949-50 3100
Another week of waiting on parts but I did manage to get the Camaro tank in. I need to get an elbow and cap but its mounted and fits nicely. I moved and flipped the rear crossmember so I can have a rear fill that fits below the bed.
11-22-2013, 08:56 PM | #182 |
Re: 1949-50 3100
gotta love when stuff fits nicely. what year is that out of?
11-22-2013, 10:31 PM | #183 |
Hollister Road Co.
Re: 1949-50 3100
Tank is an 18 gallon 67-68 Camaro from Tanks inc. It has the EFI tray in it with a GPA-2 Walbro pump. I used the stock type straps. When the bumper is on your not going to see much of the tank at all.
11-22-2013, 11:05 PM | #184 |
Re: 1949-50 3100
nice, I got a tanks ink too, but its a bit different and different location. Its nice to have those options out there, and their prices are good.
11-22-2013, 11:36 PM | #185 | |
Re: 1949-50 3100
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
11-23-2013, 12:17 AM | #186 |
Re: 1949-50 3100
Dave do you know if a GPA-2 is comparable with a 97 to 200 Chevy in tank FI fuel pump?
11-23-2013, 12:33 AM | #187 |
Hollister Road Co.
Re: 1949-50 3100
Its capable of 190 Liters Per Hour, 40 - 100 psi, good up to 450 hp. I don't remember the spec requirement on the LC9 5.3 we're using , I think 145 gph and 58 psi, but the GPA-2 was above that. Its a good pump for stock to mild 5.3 and 6.0's up to 450hp. Its not a TBI pump.
11-23-2013, 12:38 AM | #188 |
Hollister Road Co.
Re: 1949-50 3100
I looked at those but because i'm using the Danforth cross member the vette stands and mount look to be a perfect fit. I just need to fab up a small perch on the frame rail.
11-23-2013, 04:40 PM | #189 | |
Hollister Road Co.
Re: 1949-50 3100
12-11-2013, 02:30 AM | #190 |
Hollister Road Co.
Re: 1949-50 3100
We have a little more progress. Finally got some engine mounts and exhaust manifolds. These manifolds are from a CTS 6.0L 2004 - 2007. Trailblazer SS was an almost but hit the frame and the engine would have been up way to high. It would have required a 7 degree tilt front to back to get past the frame and have the drive shaft still line up correctly. With the CTS manifolds we are at 4 degrees and were able to set the motor lower into the rails. We also got the radiator fan side brackets made up for the Mark VIII Fan.
I used CTS manifolds, Vette motor mounts, and fabed the fan mount and rear trans mount. next is setting the cab on and recessing the firewall. |
12-11-2013, 09:22 AM | #191 |
Re: 1949-50 3100
Hallelujah on the exhaust manifolds! They look great!!
12-11-2013, 11:38 AM | #192 |
Re: 1949-50 3100
that looks really nice. gotta love when some stuff is meant to be.
12-11-2013, 03:32 PM | #193 |
Hollister Road Co.
Re: 1949-50 3100
12-11-2013, 05:27 PM | #194 |
Hollister Road Co.
Re: 1949-50 3100
Well "it ain't over til its over" is the theme of the exhaust system. I got a right side CTS manifold in today and put int on and it dumps out smack in the middle or the frame rail so I ended up using one right side TrailBlazer SS and one left side CTS. Oddly enough they are about equal length and far better than using both of either manifold. The left TBSS manifold was about 4.5 inches longer than the right TBSS. Vette manifolds I thought sure would work dumped into the engine mounts and I wasn't redoing those.
So in the end its one left CTS and one right TBSS and they tuck in nicely. |
12-11-2013, 07:19 PM | #195 |
Re: 1949-50 3100
Your post with pictures of the manifolds is something I have been looking at as well. I am planning the same connect and cruise package from Pace Performance. Also in a 53 AD five window.
You commented on the corvette manifolds and thought they would fit, except for your style of engine mounts. Is that right? I will probably try that route. I've been following this build and really like everything. I really appreciate the work that goes into the build as well as the work to post it all. Thanks |
12-11-2013, 09:02 PM | #196 | |
Hollister Road Co.
Re: 1949-50 3100
Picture B shows the three manifolds I tried. Corvette, CTS and TBSS. The stock truck ones were not even close on either side. Picture D is where the TBSS manifold dumps,A is where the CTS manifold dumps. Most likely with a MII front end the mount issue would not be there and I could use them in the correct location and use the vette manifolds. I was told that camaro manifold do not work either but possibly GTO may.I spent way to much on manifolds to find out. |
12-11-2013, 09:14 PM | #197 |
Re: 1949-50 3100
wow.....
so many choices. thanks for the pictures. |
12-11-2013, 09:20 PM | #198 |
Re: 1949-50 3100
Looking good! Where did you get those blue brackets for lifting the engine?
I just finished up my exhaust on my s10 framed AD and used the passenger side manifold off a 2003 Suburban and driver's side manifold off a 2002 Camaro. Use what will work best for you!
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
12-11-2013, 10:29 PM | #199 |
Hollister Road Co.
Re: 1949-50 3100
KENT-MOORE J-41798. I got them on Ebay
12-11-2013, 10:30 PM | #200 |
Re: 1949-50 3100
...........Ahhh thanks for the heads up on the Camaro manifolds, I just took delivery on a pair today !!
LS is going into a 46 Chevy truck.
