#176 |
Re: Parting out another 72 LWB and other parts
Is the passenger inner fender clean (any rot at the front reinforcing brace)? If its good, I'll take it, either shipped to 78737, or I'll come up and pick it up, depending on shipping, let me know. (but I know they are all rotted -- but I just had to ask). Thanks, Ken
#177 |
Do you have any bench seats for a 67 to 72 chevy/GMC?
1969 GMC SWB |
#178 |
![]() Join Date: Apr 2013
None that I am willing to let go of until I figure out my next several projects.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
#179 | |
Ken
Sorry I'm keeping all my good ones I have for myself. Quote:
#180 | |
Ok I have the two guide loops, the one "U" connecter (intermediate to rear cables)
I don't know what you mean by equalizer with hex nut for adjusting the tension on the cable. Because the adjustment is done on the primary cable from the pedal to the intermediate cable. I do have the rod and "U" saddle that is on the passenger side frame to the intermediate cable. Mow the pin & C-clip to connect the parking lever arm to the brake shoe inside the drum I don't know of the pin being separate from the parking lever arm. all I have is a pre '70 rearend to look at and the pin is part of the arm, and it's been a while since I've been in a '71-'72 rearend but I don't recall the pin being it's own piece. Let me know Brian Quote:
#181 |
Mike I have two roof sections that can donate what you need, but it would be best to set up a time next weekend to come by and look at them.
#182 |
#183 |
Yes I have one real good set the holes are unmolested by drill or torch I'll send them to you for $45.00
#184 |
Sorry nothing good.
#185 |
What kind of condition and year are you looking for?
#186 | |
Thanks for digging up the parts!! The equalizer is the other u-shaped saddle the slides onto the end of the front cable (the cable that connects to the pedal) and a nut holds it on the cable. As you tighten the nut, it draws the saddle up the cable to put more tension on the intermediate cable. I have the saddle and rod for the pass side. Also, I think you're right about the pin for the lever arm, I took the pass side drum off today and looks like it's part of the arm. I have a drivers side arm on its way to me, so I should be good, finding the clip will be easy. I'll take the loops and the u connector from you- how much do you want for them and the shipping to Jonestown, TX 78645?
#187 | |
OK I do have the the "equalizer" "U" shaped saddle as well, with the two jamb nuts, I would call it the primary "U" saddle myself. (but no big deal there)
parts I have: equalizer" "U" shaped saddle with jamb nuts "U" shaped clip interm cable to wheel cable 2X cable guide loops So how does $26.00 shipped to you sound. Quote:
#188 |
#189 | |
That sounds good, that will be everything I need, I can use paypal or send a money order. Let me know!!
#190 |
looking for V8 engine towers 85043
#191 |
If camaney doesn't take me up on the set posted above, you will be next in line.
If he does I do have another set that isn't as good, the motor mount holes have been enlarged by a torch a little and I see one small crack in a bend on one of them. I'll do them for $25.00 plus mailing cost.
#192 |
Do you have the center drag link and if so what would be cost with shipping to Stillwater, Oklahoma. Thanks for info Bobby
#193 |
I'm not letting go of that.
#194 |
Sorry I Don't have anything decent.
My preference on steering wheels is off of the '88 up pickups, though they are getting had to come by.
#195 |
Thanks again for getting the brake parts to me!! Exactly what I needed!
#196 |
TTT,
One more time, look and see if there is anything your interested in. I have a little more time left on my seller membership here, and then I'm downgrading to just being a member for a while. I'm about to get in the middle of building a new shop, and time will not be there for parts selling.
#197 |
do you still have the drag link if so how much and what is the shipping to 78729
#198 |
Sorry it's sold many months back.
#199 |
Pm'ed u
