Old 12-14-2014, 11:16 PM   #176
Pro Performance
Pro Performance's Avatar
Re: 63 C10 SWB Dropmember Build
Got some time to work on the truck this weekend again, and feel good about the progress made. I was able to get the engine torn down, cleaned up, and new cam installed. I am new to the LS engines, and was good to learn about them by taking them apart. As expected, these engine are quit different than the traditional SBC.
From there, we also got the brake lines ran along the frame, along with the fuel lines. I decided to run SS lines to the master cylinder form the frame. To do this, we did bulkhead fittings in the top of the frame, and will run up to the master from there. I plan on using the new Baer Remaster master cylinder.
Pro Performance is offline   Reply With Quote
Old 12-15-2014, 01:57 AM   #177
Captainfab
60-66 Nut
Coming along very nicely
Old 12-15-2014, 02:33 AM   #178
joedoh
joedoh's Avatar
I wish the gas shocks were available when I ordered my hinges too.
truck looks outstanding!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 12-15-2014, 01:37 PM   #179
Pro Performance
Thanks! I'll be putting on your brake booster bracket soon.
Thanks!
Old 12-16-2014, 04:40 PM   #180
youngrodder
youngrodder's Avatar
Nice progress Travis...
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-19-2014, 01:38 AM   #181
shrunken66stroker
shrunken66stroker's Avatar
Such a quality build. Great work.
shrunken66stroker is offline   Reply With Quote
Old 12-19-2014, 12:21 PM   #182
naynay
what oil pan is on the motor?
naynay is offline   Reply With Quote
Old 12-19-2014, 12:39 PM   #183
Bhelton
Bhelton's Avatar
Done yet? To bad it wasn't there when I was out or we could've knocked it out!
Bhelton is offline   Reply With Quote
Old 12-19-2014, 05:29 PM   #184
Pro Performance
Marc
Thank you!
It is a f-body oil pan.
Almost! I wish it was done for this last Git-Down, but for sure in 2015.
Old 01-12-2015, 01:42 PM   #185
Pro Performance
Been real busy with work lately, and haven't had time told to much on the truck. I did however come across a 1-piece kit for the side windows, and ordered it up today. Should look clean without the vent windows in there.
http://www.classictruckglass.com
Old 01-12-2015, 02:38 PM   #186
gixxer711
Originally Posted by Pro Performance View Post
Which steering column are you running?
Danny
64 C10 SWB fleet
gixxer711 is offline   Reply With Quote
Old 01-12-2015, 08:23 PM   #187
Pro Performance
That is a Summit Racing column that my Dad had lying around the shop, and never got used. It could be a little "firmer" felling in the tilt and and mechanics, but overall is nice. I would like to eventually change it out for a Ididit, but works great for now.
Old 01-12-2015, 08:55 PM   #188
Bhelton
Bhelton's Avatar
Truck looks great brotha....maybe you need a engine sponsor with boost!!
Old 01-13-2015, 04:15 AM   #189
Pro Performance
Thanks man!
Old 01-13-2015, 10:42 AM   #190
aggie91
I'm just glad to be here!
aggie91's Avatar
Looking good Travis!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-13-2015, 05:46 PM   #191
Pro Performance
Thanks!
Old 01-25-2015, 05:19 PM   #192
edflores
Doyou have any pics of your column mounts? Im not sure how to mount mine
edflores is offline   Reply With Quote
Old 01-26-2015, 01:03 PM   #193
stealth_weapons
i would like to see how the one piece glass looks after you get it installed. i am very interested in doing that to my 63 also.
the Stealth Weapons 63 project, all comments, advice, and critiques welcome!
http://67-72chevytrucks.com/vboard/s...d.php?t=438235
stealth_weapons is offline   Reply With Quote
Old 01-27-2015, 05:40 PM   #194
Pro Performance
I will try and grab some pictures for you. I basically just put the column in the factory place, and clamped it down using the factory clamp at the firewall and under the dash. I used a piece of rubber in both areas, to better let the clamp hold it in place, and tighten down more and have more friction so it wouldn't rotate. I don't think the rubber was needed, but used it anyways.
I will definitely post pictures, and have yet to receive it yet.
Here is some progress from this last weekend. Got the rest of the accessory drive in and the Vintage Air AC bracket and compressor installed. I also managed to get the door aligned as best as possible and installed the PB front core support cross member. Just a lot of little things that needed to be addressed.
I got the CaptainFab brake booster bracket installed, and fits awesome! I originally got a 88-98 booster, but was too large (11") and hot the coil pack on the valve cover. I needed up finding a 85-89 Astro Van booster that is about 9" and clears. I am running into this problem due to the drop member raises the engine 2". Normally the 88-98 would have worked.
Old 01-30-2015, 12:06 AM   #195
64shortc10
64shortc10's Avatar
Trucks looking good! Will that steering column work with a stock steering wheel? Keep them updates coming!
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 01-30-2015, 12:33 AM   #196
edflores
Did you have to buy the Kwik AC bracket separate or does it come with the vintage air kit?
Old 01-30-2015, 12:34 AM   #197
edflores
Tony from Norcal
The work with the stock wheel but you need a horn kit to fill in the gap.
Old 01-30-2015, 12:39 PM   #198
Pro Performance
Tony from Norcal
Thanks!
It does come from Vintage Air, but is separate from the regular kit. It is an extra $125.
Thanks for the info. I have never tried this, so wasn't for certain.
Old 02-01-2015, 11:54 AM   #199
Jer64
Jer64's Avatar
Great work, that AC bracket looks awesome
My build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=587028
Jer64 is offline   Reply With Quote
Old 02-01-2015, 01:47 PM   #200
Vics63Chevy
Vics63Chevy's Avatar
Badass brotha!
1963 Destiny Build Log
Vics63Chevy is offline   Reply With Quote
