Old 02-07-2018, 06:24 PM   #176
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: New 64 Stepper Project
Anyway here is the back-side of the frame where the power steering gear box is mounted. Before the powdercoating I had a hole or two welded up. I used grade 8 bolts and extra heavy washers as well as blue locktite and lock washers.
Old 02-07-2018, 07:10 PM   #177
zachiatrist
zachiatrist's Avatar
Dang, just saw this. Really clean build going on here. Looks like every little nook and cranny is buffed to perfection. Superb work!
1964 Chevy C10 "Honeydew"
http://instagram.com/zachiatrist
http://zachiatrist.com
zachiatrist is offline   Reply With Quote
Old 02-07-2018, 07:44 PM   #178
The Rocknrod
Moderator
Thanks but I have much cleaning to do before it's ready for prime time.
Old 02-10-2018, 07:42 PM   #179
The Rocknrod
Moderator
Okay finished the brake bleeding front and rear. Then operated the electric parking brake unit to adjust the rear brake travel. Since one sides cable is longer than the other I had to make sure they travel the same, so now they do.
Old 03-25-2018, 05:51 PM   #180
The Rocknrod
Moderator
Worked on re-fitting the radiator and side baffles. I had previously made the top front baffle so I installed the rubber and re-fit it all together to see (post paint) how it looked. What do you think so far?
Old 03-25-2018, 08:06 PM   #181
Joe Pass
Joe Pass's Avatar
Man that sure looks good.....Hope the hood spring mod works for you....
Joe
Joe Pass is offline   Reply With Quote
Old 03-25-2018, 11:42 PM   #182
Captainfab
60-66 Nut
Looks good to me
Old 03-26-2018, 11:35 AM   #183
The Rocknrod
Moderator
So here is a closeup of the top radiator seal I was talking about. I plan on using the hood anti rattle rubber that comes with three pieces in the kit, since I have one for the side I need another for the other side of the radiator if anyone has a spare. Instead of the folded over rubber, I will Plastic-dip the end.
Old 03-27-2018, 07:36 AM   #184
That looks good!
Old 03-27-2018, 08:39 AM   #185
The Rocknrod
Moderator
Originally Posted by Joe Pass View Post
Man that sure looks good.....Hope the hood spring mod works for you....Joe
Originally Posted by Captainfab View Post
Looks good to me
Cool.
That looks good!
Thank you.
Old 04-10-2018, 12:20 PM   #186
The Rocknrod
Moderator
Installed the lower radiator seal and then stapled it all in. Actually used super weatherstrip adhesive (3M) and wire and patience but it looks okay.
Old 04-10-2018, 12:21 PM   #187
The Rocknrod
Moderator
Then I put together the grill and headlight brackets getting ready to put the grille together and wire it in.
Old 04-10-2018, 07:29 PM   #188
Pinchecharlie
Wow looks great! You mind telling me your solution to having the proportion valve hanging off the master? Did you build a bracket for it on the frame rail? I am not to happy with the lines all cluttered in the engine bay and yours look perfect.
Pinchecharlie is offline   Reply With Quote
Old 04-10-2018, 08:32 PM   #189
The Rocknrod
Moderator
Thank you.
Starting on page #7 at post #171 I explain it. http://67-72chevytrucks.com/vboard/s...=666226&page=7
Old 04-17-2018, 04:20 PM   #190
The Rocknrod
Moderator
I've been wiring up my truck and also installed the wiper motor and wiper transmissions. I had to wire wheel the trans paint them lube them etc. They run perfect after I got the switch dialed in, they even park.
Old 04-28-2018, 04:49 PM   #191
The Rocknrod
Moderator
Started wiring the truck, not finished but you get the idea:
Old 04-28-2018, 10:00 PM   #192
Joe Pass
Joe Pass's Avatar
Very clean work.....
Old 04-29-2018, 01:07 AM   #193
pdxhall
pdxhall's Avatar
Your wiring looks great. I'm just a little behind you. I've got the fuse panel mounted and I spent about 3 hrs. today untangling wires. This nice work gives me motivation.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 04-29-2018, 09:39 AM   #194
The Rocknrod
Moderator
Thanks guys, ya those wires are a mess when you get them I never thought I'd get this far. I had to buy some terminals for the fuse panel and replace a couple wires I thought were too small and remove a couple I wasn't using. That gave me the opportunity to clean it up. In case you want to know - http://www.repairconnector.com/produ...52d14-AWG.html
Old 04-30-2018, 05:32 PM   #195
The Rocknrod
Moderator
I was trying to make sure I bought the right speedo cable so I took an extra piece of 3/16" tube and ran a 63" length from the gauges to the trans are where the planned 200R4 threaded connection will be. So I am sure that it will work.
I know that the ATP Y-804 Speedo cable is 5/8"-18 gauge end and 7/8"-18 Trans end at 63" long.
Old 04-30-2018, 07:27 PM   #196
Joe Pass
Joe Pass's Avatar
I'll be interested in how the 200r4 works for you.....considered that myself since its a direct replacement for my T350......
Old 04-30-2018, 09:31 PM   #197
The Rocknrod
Moderator
Sent you a PM Joe.
Old 05-03-2018, 03:53 PM   #198
The Rocknrod
Moderator
Another way to skin a cat - I just saw this pic from Clemdaddy's post. See the proportioning valve on the inside of the frame?
Old 05-08-2018, 07:01 PM   #199
The Rocknrod
Moderator
I started working on the hood lamps. I used an American Autowire grommet for the firewall plug for the hood wires to include a ground wire to the lights, I used some push-mount wire ties in the interior of the hood wiring, they are hard to even notice. The pad isnt installed in the hood on the pic below, hard to see with so much red.
Old 05-08-2018, 07:04 PM   #200
The Rocknrod
Moderator
I plan to use F6 wire covering for most of the wire but it hasnt arrived yet so I got started anyway. I'll change it out when it arrives.
