Old 04-02-2016, 12:04 AM   #176
AJCK87
Re: 1963 GMC C30 panel truck
Originally Posted by 62stepside longbox View Post
Nice job! I don't know where you find the time to do all this in one day
Thank you! I have been putting in some long hours this week, I'm really pushing to get the floors done.
Got more panels fabed up. Here's the Inner A pillar
AJCK87 is offline   Reply With Quote
Old 04-02-2016, 12:05 AM   #177
AJCK87
And the inner B pillar panel
Old 04-02-2016, 12:09 AM   #178
AJCK87
I got both panels welded in and the floor support bolted in. The outer rocker will go on tomorrow along with some paint. More to come
Old 04-02-2016, 06:34 PM   #179
AJCK87
Oooooo yeah!!! Drivers side floor, rocker and floor support checked off the list. Very pumped, all the cab metal repairs are done getting very close to drive line work. I am looking to take the dodge off the road the next stretch of time off I get. I can't wait to get the Cummins between the frame rails
Time for a cold one!
Old 04-02-2016, 10:07 PM   #180
62stepside longbox
62stepside longbox's Avatar
Wow nice job man! You are in the home stretch now keep up the good work
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 04-08-2016, 03:48 PM   #181
AJCK87
Thanks! Back at work now. Should have some time next week and weekend to get some more done. I have been fixing up the new to me passengers side barn door hopefully get it done this weekend. Pictures to come
Old 04-10-2016, 04:38 PM   #182
AJCK87
Here is the passengers side barn door, thanks Perro13!
I got the rusty bottom patched and the whole door wire wheeled and painted. Bondo free!!!!
I had to rebuild the latch I picked up off that 62 Suburban in Princton as well as modify the new lock/ push rod to match the length of the original. The latch push rod is shorter and I could not find and repos for the panel/ Suburbans out there. All works like a dream now.
I Will be dropping the door off at a glass place this time.... Cracked the pane for the drivers side. Need some fresh rubber anyways. Hahaha. Luckily I got a spare pane from the new door.
I have the highs all ready to go and some new hinge seals to go with them.
I will be working down island next week so I will have some time in the evenings to get the door mounted, mess around with the drivers side door spacing and the door seals.
Thanks for tuning in!
Old 04-10-2016, 04:40 PM   #183
AJCK87
This door is in much better shape then my old one!
Side view. The rebuilt door latch, turned out awesome.
Old 04-14-2016, 12:09 AM   #184
AJCK87
Working down island this week so I got a chance to bring the barn door down with me. I got some "smoke" tinted glass cut for both doors and the seals were salvageable! With a little adjustment I got them working pretty good! Still need to fab up some rubber door stops for the passengers side.
I also have a set of the OEM rear seals coming. Just about got the rear end all wrapped up.
Old 04-14-2016, 12:10 AM   #185
AJCK87
Very pumped !
Old 04-14-2016, 12:11 AM   #186
AJCK87
Finally able to put my cowgirl where I want her hahaha
Old 04-14-2016, 12:34 AM   #187
62stepside longbox
It's looking really sharp
Old 04-14-2016, 05:15 AM   #188
Old 04-14-2016, 11:06 AM   #189
AJCK87
Thanks Nik! Hopefully I can swing by some time with the panel, when it's up and running, come check out your pick up
Thanks Bill!
Old 04-21-2016, 06:49 PM   #190
62stepside longbox
Sure that would be awesome, any updates on the panel?
Old 04-21-2016, 10:54 PM   #191
AJCK87
Not too much, been busy getting wedding invites together and in the mail and knocking out the tax return.
Finally got the passengers side fender all smoothed out and got some POR on her, jeeze stuff rusts fast here hahaha. Got some time this weekend so hopefully I can get the fender all finished up.
Old 05-01-2016, 11:47 PM   #192
62stepside longbox
Any recent progress on the panel Anthony?
Old 05-02-2016, 11:51 PM   #193
AJCK87
Hey Nik,
Thanks for checking in hahaha.
I got the passengers side fender all back together, not super happy with how it turned out, but it's on... Will have to address it later. Went to the junk yard in Port Hardy and picked up a bunch of window seals and started to fit them around the door glass. I got the passengers side seals all done up, I think I looks good and should keep the water and wind out a bit better then the felts.
Old 05-02-2016, 11:52 PM   #194
AJCK87
Another of the fender
Old 05-02-2016, 11:53 PM   #195
AJCK87
With the new seals
Old 05-02-2016, 11:54 PM   #196
AJCK87
The inside
Old 05-02-2016, 11:56 PM   #197
AJCK87
I also got the main door seal put in also. Super nice, I really like the precision seal product. Went in nice
Old 05-03-2016, 12:08 AM   #198
62stepside longbox
Good to hear the door rubber worked out well for you. I hear lots of complaints on the repop seals
Old 05-03-2016, 10:29 AM   #199
65sub
65sub's Avatar
Do you have any more details on the window seals you used. Close up pictures? What they are out of?
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 05-03-2016, 10:50 AM   #200
AJCK87
Thanks! It was a bit of a fight but the weather strip adhesive really pulled it together.
I will have to get some better close up pics for you next time I'm down to work on the truck. As for the seals, I know some may not want to hear this.... Hahaha they are out of a 2009 Ford. The ripper seamed to fit the window glide profile and had fresh rubber and the inside was felted. I'm not to picky as long as it works. The bottoms are out of a 2000's Chevy van. They have all been modified to fit. It's not perfect, but it actually turned out pretty good hahaha
