Old 01-29-2019, 11:48 AM   #176
dayj1
Re: Another way to skin the cat; the High Torque 292 LS swap
Originally Posted by Dads79GMC View Post
How are your truck injectors working in the fuel rail and intake.
The injectors worked fine. I think I had to pop the plastic caps off the end to get them to slip into the intake, but it's been so long I can't remember.
dayj1 is offline   Reply With Quote
Old 01-29-2019, 12:27 PM   #177
Dads79GMC
Dads79GMC's Avatar
I’m a self taught gearhead. So, I know the injector bottoms out in the intake, then I slightly brought it back ever so slightly. So the end cap comes off and the injector, then should protrude through the base of the intake? Thanks Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 01-29-2019, 12:50 PM   #178
mongocanfly
Post Whore
mongocanfly's Avatar
yep Jonathon...you removed the black plastic end...at least that's what you told me to do on mine....haha
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-29-2019, 03:30 PM   #179
dayj1
As long as it seals on the o ring, you're good (at least from a no-leak perspective). But, in some intakes, the cap on the end of the truck injector stops it from pushing into the intake far enough to seal. So you have to remove the caps. They'll pull of with a pair of pliers.
Thanks for the reminder!
Old 01-29-2019, 04:13 PM   #180
Dads79GMC
Dads79GMC's Avatar
I appreciate all the help!! Thanks Mike
Old 01-30-2019, 12:40 AM   #181
LT7A
Wow, I really enjoyed reading this. Style and taste are individual, but combined with ingenuity, the appeal is universal. I hope to see more on this truck. Thanks for sharing.
Old 04-14-2019, 10:56 PM   #182
Captainfab
60-66 Nut
I really like what you did with your truck build.....nice job
Old 04-24-2019, 02:11 AM   #183
72GreenMonster
72GreenMonster's Avatar
Joining the swap community but the simplicity and fabrication is top notch.
Tell us your really a 🚀 scientist and if not your work and detail is worthy of one. Thanks for sharing. My swap may never match up but the bar has been set. Next read is lsnova.
Thanks again
72 GMC Sierra 2500
72GreenMonster is offline   Reply With Quote
Old 04-24-2019, 10:30 AM   #184
solidaxel
solidaxel's Avatar
LS1Nova your PM box is full
I have a question for you!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-26-2019, 12:50 AM   #185
dayj1
Thank you!
Thanks again
I'm not a rocket scientist, but I do work for the folks who put the first man on the moon. Thanks for the kind words.
Old 05-03-2019, 12:28 PM   #186
mattfranklin
mattfranklin's Avatar
Wow! Beautiful work. The vision, the fab, and the pics. Everything top notch.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 05-08-2019, 02:40 PM   #187
chev-obsession
chev-obsession's Avatar
What exhaust manifolds did you use?
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 05-08-2019, 04:28 PM   #188
dayj1
Thanks!
LS3 Camaro manifolds.
Old 05-09-2019, 12:20 AM   #189
gringoloco
A guy with a truck
gringoloco's Avatar
Just wanted you to know this thread is a giver. I’ve used it twice in the last week, once plumbing fuel lines and once cutting radiator hoses. Thanks!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-09-2019, 01:10 AM   #190
Dads79GMC
Dads79GMC's Avatar
So true!!!!!!
Old 05-09-2019, 02:04 PM   #191
Willie Makeit
Willie Makeit's Avatar
I know dayj1 personally and he is that way with his time and his knowledge in the "real world" too.
Just a dang good dude all around & I'm lucky to be able to call him a friend.
Willie Makeit is offline   Reply With Quote
Old 05-10-2019, 10:30 AM   #192
dayj1
So true!!!!!!
I'm glad it's getting some use!
Thanks! I don't think there are many of us who do everything to our trucks by ourselves. I know my projects wouldn't turn out as well as they do nor be finished as quickly if I didn't have help from my friends. And, of course, that includes all the side projects I send your way!
Old 07-04-2022, 07:29 PM   #193
incoma
incoma's Avatar
Originally Posted by dayj1 View Post
and more...
Is there a disadvantage of just converting a 71-72 style fuel sending unit to a return/feed system? I've noticed a few guys adding an extra inlet/outlet to the tank. I was going to convert a 71-72 over... but I'm second guessing myself now.
"Green Monster" (Red Sox fan)
1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension
incoma is offline   Reply With Quote
Old 07-05-2022, 03:50 PM   #194
dayj1
Packaging was the big reason for me. Incorporating a feed and a return line and the appropriate bulkheads for the pump and the sender is a lot to put in a stock sending unit as it's pretty small. It'd also be tough to get a pump and float through the stock hole in the tank.
I'm sure the stock sender could be modified to work, but I went with what I thought was an easier/better alternative for me.
Old 07-05-2022, 04:00 PM   #195
incoma
incoma's Avatar
Old 12-23-2022, 07:55 PM   #196
larryboy_3t5
larryboy_3t5's Avatar
Hey, looking to do a similar swap and my issue is leg room in the cab. It looks like you had plenty of room in that area behind the driver's side cylinder head to mount your coils. If I didn't do that, would I be able to push that area of the firewall, where the throttle pedal attaches, forward an inch or two without interfering with the back of the engine? It almost looks like the firewall could be flush all the way across behind the engine in your photos.
"A man's got to know his limitations"
1969 Chevy C20 Camper Special
1968 Chevy C-10 short/fleet
1970 GMC Jimmy 4x4 (SOLD)
larryboy_3t5 is offline   Reply With Quote
