Old 01-26-2016, 04:35 PM   #176
dragnframe
Re: My 83' Crew Cab Dually project
A little bit of heat and a scraper usually works pretty good
dragnframe is offline   Reply With Quote
Old 01-26-2016, 05:11 PM   #177
64chevtruck
Oo good one. I normally use a scraper but ill be adding heat for sure.
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 01-27-2016, 01:20 PM   #178
aggie91
I'm just glad to be here!
aggie91's Avatar
Originally Posted by DblTrbl View Post
A little Easter egg for those that look close enough...
Originally Posted by dragnframe View Post
Now that's bringing a fish plate to a whole new level!
That's not a fish plate, THAT is a SHARK Plate...
For those projects where a fish is just not enough...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-27-2016, 02:04 PM   #179
Low Elco
Oh, I'm stealing that! Too slick!
Low Elco is offline   Reply With Quote
Old 01-29-2016, 01:38 AM   #180
DblTrbl
DblTrbl's Avatar
It's nice to be actually putting this thing back together instead of taking it apart...I think I've finally hit the top of the hill.
I have the body mounted back on the frame, engine and trans permanently installed, headers and resonator pipes in, most of my fuel and brake lines run, wiring to the rear, and I'm buttoning up all of the connections to the engine. I had to lengthen some of my harness and shorten other parts because of the Z. The power steering pump turned out to have a different fitting for the pressure line, but I was fortunate enough to have a really helpful guy at the parts store and I ended up cutting the old flare off and flaring the end to match the pump. I painted the firewall and I've been working on looming everything...which has been incredibly time consuming!
Anyway here's some pics of progress:
Old fitting:
Everything in place and attached:
My wiring mess!
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192
Instagram: lofab77
DblTrbl is offline   Reply With Quote
Old 01-29-2016, 01:41 AM   #181
tinydb84
tinydb84's Avatar
Damn man. You work fast!
David
Instagram: myfabguy
Old 01-29-2016, 01:50 AM   #182
DblTrbl
DblTrbl's Avatar
I wanna drive it! Lol
Instagram: lofab77
Old 01-31-2016, 07:39 PM   #183
DblTrbl
DblTrbl's Avatar
40gal burb tank is out of the burb...that was a chilly adventure. It's a little bigger than I'd expected, and it doesn't fit between the rails, rather right on top of them, so I'll have to build some kind of framework to house it...I can also see that my bed floor is going to be raised waaaay up to cover it.
Instagram: lofab77
Old 02-03-2016, 12:09 AM   #184
DblTrbl
DblTrbl's Avatar
Geez...I could sure use a brake and a slip roller. This is hard on the elbows.
Instagram: lofab77
Old 02-04-2016, 01:00 AM   #185
54earl
54earl's Avatar
Maybe I should look into this Instagram thing. Keep on keepin on.
54earl is offline   Reply With Quote
Old 02-04-2016, 01:06 AM   #186
DblTrbl
DblTrbl's Avatar
So...photobucket is apparently all screwed up again which has resulted in some broken links. I don't feel like going through the entire thread to figure out which pics are missing right now, but if anyone comes across one that's not working and really wants to see it, let me know.
Here's the broken one from above:
And here's my current progress on the plenum. I'm a little out of practice with aluminum tig'ing and my machine keeps popping the breaker. Just when I've got my rhythm back, it pops! I'm going to grab a bigger breaker tomorrow and see if I can finish this up. I moved the blower motor 5" up and deleted the AC. I've had some interest in this on Instagram. If anyone else is interested in something like this, let me know. I'm trying to gauge whether or not it's enough to knock out a few of them...
Instagram: lofab77
Old 02-04-2016, 03:00 AM   #187
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Make sure on the photobucket deal that you don't rearrange any photos in your photobucket account. I had that problem a while ago when I was trying to reorganize my photobucket and put different photos in certain folders. If you move them around or put them in a folder the links will change.
Dunno if this is your issue but in case anyone else doesn't know.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress
Ghostwhite is offline   Reply With Quote
Old 02-04-2016, 10:28 AM   #188
N2TRUX
Happy to be here
N2TRUX's Avatar
Thats the issue almost all of the time with Photobucket. Any changes made to location or file name creates a new URL and your pics go dead.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-04-2016, 04:57 PM   #189
DblTrbl
DblTrbl's Avatar
Not the case with mine. Everything goes into the "truck" folder and stays there. Photobucket has bee having significant upload issues and drops like 20 of the same picture. I was able to go delete the extras, but apparently it moved other pictures in the mix or something and broke the links. I've had the account for over ten years and never had any issues until just a month ago. App reviews are showing that others apparently are having similar problems. Maybe they upgraded to Windows 10...
Instagram: lofab77
Old 02-04-2016, 08:41 PM   #190
DblTrbl
DblTrbl's Avatar
A little sanding and polish and it's done.
Instagram: lofab77
Old 02-04-2016, 09:21 PM   #191
Advanced Design
Advanced Design's Avatar
Nice work! That looks really good.
Advanced Design is offline   Reply With Quote
Old 02-04-2016, 11:06 PM   #192
54earl
54earl's Avatar
My photobucket is messed up as well. Mine is VW though, not near as interesting as square body dually.
Old 02-04-2016, 11:15 PM   #193
DblTrbl
DblTrbl's Avatar
There's a lot of VW on mine too, though I haven't touched the "go-cart" in almost 5 years....
Instagram: lofab77
Old 02-05-2016, 12:43 AM   #194
DblTrbl
DblTrbl's Avatar
Everything is better shiny...
Instagram: lofab77
Old 02-05-2016, 11:14 AM   #195
aggie91
aggie91's Avatar
I like it. Turned out great!
Karl
The LST Challenge:
Old 02-05-2016, 02:52 PM   #196
Low Elco
VERY slick!
Old 02-05-2016, 09:07 PM   #197
54earl
54earl's Avatar
Plenum looks great. Is that a rabbit ? Mine is 70 bus that I am not smart enough to figure out now to post photos of.
Old 02-05-2016, 09:17 PM   #198
DblTrbl
DblTrbl's Avatar
Thanks. '78 Scirocco full race, caged, braced, coilovers, turbo 1.8L
Only full pic I can seem to find if it. This was after a rainy day at the track.
Instagram: lofab77
Old 02-06-2016, 09:20 AM   #199
TrailerTrash
TrailerTrash's Avatar
plenum looks awesome dude i didnt expect it to look so at home on the firewall
photobucket has been giving me issues for awhile now. i used imageshack for like 6 years but then they changed everything, required payment, then all my pics went dead. so i switched to photobucket and havent been very pleased about it
TrailerTrash is offline   Reply With Quote
Old 02-06-2016, 05:11 PM   #200
DblTrbl
DblTrbl's Avatar
Had to take a break to clean the shop today. Small space gets out of control quickly. I was nearing gridlock. When I can't find tools, it's time...now I have no excuses not to get things finished. Lol
Instagram: lofab77
