Old 07-27-2019, 05:39 AM   #176
44boggers
Re: American in Austria 83 Build
Last few, speaker mount, fuse box, msd box location and then I mounted my FITECH controller in the ash tray. I didnt like how it face direct, so I just bent up some aluminum so it would sit at an angle and it is easier to see when i am in the seat. It still flips up nice and hides away.
44boggers is offline   Reply With Quote
Old 03-22-2020, 01:12 PM   #177
44boggers
After a bunch of months off from working on the c10, i am back on it.
Now I am aligning body panels and then creating an even 3/16" gap all around.
I am having a slight issue with my pass side door. I have it adjusted the best i could where 90 percent of the door aligns really well, except for the opening side of the upper door frame. From the body line down it lines up really well and the bottom of the door is maybe 1/16" to far out, but i can work the metal there. The fender side of the door is very close and where it meets the upper part of the fender it lines up perfect.
But the upper part of the door frame towards the back of the cab, is roughly 1/4'' to far out.
I can move the door in (by adjusting the striker in) and it will up perfect but then that puts the lower part of the door (body line down), roughly 1/8" to far in. Which would leave me with the only option of filling that area with some fiber glass filler to make the panels even.
I have tried tweaking the door frame a bit, since it seems to be twisted but it has done much, maybe i need to be more forceful.
Is the best way to fix this to try to hammer the door frame a bit or continue to try to twist it into shape?
The first two pics are of how the door currently sits with the upper part of the frame out and the lower section of the door lining up nice.
The last two pics are of when i adjust the striker in, the upper part of the frame lines up perfect but the lower part, body line down, is about 1/8" to far in all the way down,
Any advice would be nice,
Thanks guys
Paul
Old 05-31-2020, 02:09 AM   #178
LT7A
Man, I lost track of this thread. You have made a ton of progress and the work is all to a really nice finish level. I see what you're saying about the door fitment and wish that I could offer a useful suggestion. Maybe p.m. Jasonb? I haven't seen him on here for a bit, but he churns through body work like nobody else I've seen. The wheels and tires look great and those three fifteens are huge. You must be looking forward to driving it. Is the TUV going to be a problem? I have heard that they are very strict.
Old 06-01-2020, 12:59 PM   #179
44boggers
Thank you. I have made some progress, it is slow going but progress nonetheless. I finished up the pass side door and fender (final primer). I was able to get the door to sit flush, made all the door to fender gaps an even 3/16". I am happy with how it turned out, should be very flat and then door to fender flows together nice.
I started on the driver side. This door is in better shape. The bottom side of it has one dent and the bottom flange is bowed out a bit so i need to fix that. Where the door meets the fender was banged in pretty good, but i was able to get the door lip to come back out and be around 1/32" below the fender. So some filler will be able to flush it up. The cab side of the door frame was very bowed out from the body line up. and was sticking about 1/2" higher than the cab. But the rest of the door lined up pretty well so i couldnt adjust the door anymore. So I got some wood and clamped it to both sides of the door frame and was able to flatten the curve out and now it is very close to flush with the cab or flush in most spots. The gaps are all over the place, but it is an easy fix with some welding rod. So that is the next step. Here are some pics of the progress.
Paul
Old 06-01-2020, 01:03 PM   #180
44boggers
More body work pics.
Old 06-01-2020, 01:10 PM   #181
44boggers
and on and on and on.
Old 06-01-2020, 01:15 PM   #182
Hart_Rod
Hart_Rod's Avatar
Truck is coming out nicely! I'm not sure if you are doing, but I would recommend you putting in your door weather stripping and recheck your gaps before going to final paint. It's crazy how they can change things up, been there ... done that, . Keep up the good work!
Hart_Rod is offline   Reply With Quote
Old 06-01-2020, 01:17 PM   #183
44boggers
On to the driver side.
Old 06-01-2020, 01:19 PM   #184
44boggers
Thanks, yes I do have the weather stripping in there. I am not sure how normal it is, but you need to put a bit of force behind it to close the door. Like the weather stripping needs to thin out. It would close real easy if i moved the door out 1/8" but that would mess up the alignment. It doesnt pop hard when i open it and i dont need to slam the door, but I cant just let the wind close it.
Old 10-05-2020, 12:15 PM   #185
44boggers
Time for an update, got a handful of pictures.
In the last few months i was able to finish up all of the metal work on the doors and got the gaps down to 3/16" all around as well as to the fender/door.
I also added some weld to the top of the fender where it meets the cab
After that I did a couple skim coats of filler to the door, blocked it out with 80, expoxied and then shot it with slick sand, blocked that out with 80, 1 more shot of slick sand, blocked it with 180, shot it with 2 coats of epoxy to seal it up and now it is in high build primer.
I will post pics of this first and then move onto my slight dilemma.
Old 10-05-2020, 12:21 PM   #186
44boggers
I also added some weld to the top of the fender where it meets the cab because the lip hung a bit lower than the cowl.
And a picture of it in wet epoxy.
Old 10-05-2020, 12:35 PM   #187
44boggers
Now the slight dilemma. When I bolted the door and fender back up and pulled a piece of tape along the entire length of the driverside to get an idea of body line placement, things did not line up despite the body lines being straight. The line from the door to the fender climbed about 1 inch up the fender by the time it reached the front. Then I started to take some measurements on the fender, side light etc. Basically everything was 11/16" lower on the driverside than the pass side. Then I measured the frame horns, and sure as **** the driverside frame horn was exactly 11/16" lower than the pass side. But it is only from just behind the core support mount forward. Not where the control arms or motor is, that is all fine. So i guess I missed that somewhere that the frame was bent down. I took some fender shims and shimmed it 11/16" up and now all those body points i measured are exactly like the pass side. This is something I will need to tackle later and in the mean time I will make an aluminum puck to take up that space and then I will need to do something with the bumper mounts.
The fender line is not 100 percent straight across without any pitch but it is very very close. I thought about a door adjustment but I did so much metal work to get the gaps right that I didnt want to touch it. Plus I measure the pass side door body line front and back and the difference from the back of the door body line to the front is a 3mm drop towards the front, which is the same on the driver side. So I think it is where it should be, plus it lines up perfect with the cab body line.
But now my perfect fender to door gap i had before of 3/16" is all messed up and I will not need to add welding rod to the fender to bring the gap in. Basically it starts to go out just above the body line to the bottom of the fender.
Before I start redoing the fender, maybe someone can chime in, in case I am seriously missing something obvious.
Here are some pics. It does look like the fender has a downward kink right where the sway bar mount it, just not idea how this could have happened. My guess is it was that way when I got the truck and when I stripped the frame down and unbolted the cross members it let the tension go and it moved. Because there were not any shims under the core support when i took it off.
Ok enough writing, here are some pics.
Old 10-05-2020, 01:01 PM   #188
44boggers
I forgot to add some of the pictures from the metal work/gapping. Man these stock doors were all over the place.
Old 10-05-2020, 01:06 PM   #189
44boggers
Few more of the metal work.
Old 10-05-2020, 02:21 PM   #190
LT7A
Wow man, you're doing such a tight, clean job that you're almost a victim of your own success and abilities. I know that doesn't help much. Here's my train of thought for what it's worth. Being that 85% of the truck is aligned, I don't think I would want to put that rig on to a frame table and try to tweak that section back into alignment. If you are going to consider re fixing the fender to get your gaps where you want them, I would first fix the frame permanently. It sounds as if you might be able to cut the bent area off and either re-welded it in the correct location, or more likely, and probably better, to get the horn off of an un-bent frame, preferably longer than you actually need, for comparison's sake. Maybe all the way to the firewall? If you don't fix it now, when you do, it may once again disrupt the fine detail work you've done. Once the frame is fixed, you may feel better about whatever you have to do to the fender because you know it is permanent and the last time.
Old 10-05-2020, 02:33 PM   #191
44boggers
Thanks for your thoughts. I am my own worst enemy, my OCD is taking over hard. But doing a precise build like this is something i have wanted to do for 15 years now but never had the time, place or money. Now I at least have the money, a 1 car garage and at least limited amount of time.
The biggest issue is that I live in Austria, so there are no junk yards around with chevy anything to rip parts off of and to find a frame shop anywhere near me is basically impossible. People here are not so much into fixing their cars, opposed to trading it in for something newer.
I think i am going to leave the frame for the time being and next time i get back to the US, I will cut a frame horn off a junk yard c10 and bring it back over. I just dont want to cut up my frame before I have something to compare it to. In the end that part of the frame will not effect or should not effect the driving. And I have a spare frame to bumper bracket that I can modify so the bumper is mounted properly. I feel like its a bit of a hack job, but I am confident in my OCD and my abilities that it will look like it should have come that way, or at least not be noticeable to the naked eye.
I guess my next step is to tighten up the fender gap, hit it with some fiberglass, body filler and primer and then I will be able to sand the driver side down to 220 and hit it with the final coat of high build.
Then move onto gapping the hood cowl to the fenders, body work it and then the hood. If I can get all of that done this winter I will be happy. Then the only thing left will be the bed sides and tailgate which are all in pretty good shape.
We are building a house next spring and I will have a 40x50' garage, so I will do the final sanding and painting in there. Because right now my garage is way to small to do a basecoat/clear coat job.
Anyway, ill post some more updates.
Old 10-05-2020, 02:44 PM   #192
LT7A
Yeah I was thinking about your situation and location when I wrote that, knowing that it would be more difficult there. You have a lot of cool stuff going on and everything you said makes sense to me. It may be worth a weekly update to your thread noting progress as well as referencing that frame need. Maybe you can leave that work until just before you paint it. I'm sure that there are a number of guys that have parts trucks. Even I do, and I would happily send you a chunk if I had stripped it down that far and couldn't sell the frame as a whole. There have got to be guys on here with bent frames, hit in the back, that could sell you a chunk from the front. I would read other people's build threads who are combining two or more trucks. I can think of a couple right off the top of my head. PM those guys and I'm confident you'll land a piece.
Old 10-05-2020, 03:02 PM   #193
44boggers
Thanks again for putting some thought into my issue and thanks for the offer. I have been building this truck for 5 years now, so I am getting anxious to get it done and actually drive it.
I was thinking about the splicing of a frame section in and your concern about it messing with my current body alignment. My thought is that i can finish the body work to my liking and when I get a chance to splice in a new section it shouldnt (in theory) mess with my alignment. As long as I keep all of the body panel bolts tight and i keep the core support propped up when i get it the frame, all i would need to do is bolt the new section to my core support so i know that the core support is tightened down properly to the frame and then weld it in. So really if that all goes as planned the body panels should not move at all.
I travel about 200 days a year for work so I just dont have much time to work on my truck, and as the aforementioned garage, I dont have any room to pull panels and paint inside. So basically I need to do all the priming outside, ok I cant get away with pushing the truck to the wall and getting the door and fenders on a stand to prime them, but no chance for a hood or bed sides.
This is a big reason why this build has taken 5 years so far, between my OCD and lack of space it is hard to accomplish a lot in a short amount of time.
Either way, I will update this thread more often if people are interested in seeing whats going on.
Thanks again for your feedback.
Paul
Old 10-11-2020, 01:44 PM   #194
44boggers
So for now I am going to put off welding on the fender, just because I want to move forward with the hood body work before the snow comes and the fact that I want to move onto that stage anyway.
So I have been trying to align my hood the best I can. I have billet hinges from Little Shop MFG https://www.littleshopmfg.com/81-c10...t-hood-hinges/
Its a very nice set with a lot more adjustment built in, especially side to side.
I need to take the hood cowl off so I can adjust the side to side part of the hinge some more. But right now I can see that there will need to be a lot of welding to the edges to get the gaps correct. I have the hood aligned so the front side is pretty much flush with the front of the fenders.
Here are some pics of where the hood is at now. The biggest cap is roughly 3/8" but the cowl to fender and hood to fender (back side) is right at 5/16" and I want everything to be at 3/16'' like the rest of the body gaps.
Old 10-11-2020, 01:50 PM   #195
44boggers
Next round of pics shows the gapping shims. The two larger shims are 1/8" and the smaller shim is 1/16"
First pic is pass side hood cowl to hood gap. 5/16"
Second pic is pass side hood to fender gap (back side) 5/16"
Third pic is driver side cowl to fender (5/16")
Fourth pic is driver side cowl to hood (3/8")
Fifth pics is driver side fender to hood front side ~3/16"
So its a bit all over the place, but I think some side to side adjustment will help things along.
Old 10-11-2020, 02:14 PM   #196
Lokin4AReason
Lokin4AReason's Avatar
How long of a frame horn are you needing and which side ? A friend of mine is suppose to be getting 85 c10 and junking the frame and suspenion . I can also let you know at when he ll have it .
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 10-11-2020, 03:27 PM   #197
44boggers
Hey thanks for the offer. I am not exactly sure, but a safe bet would be from just behind the A arm to the bumper. And it would be the driver side.
Lets stay in touch about it.
Paul
Old 10-18-2020, 10:24 AM   #198
LT1 Burb
LT1 Burb's Avatar
Very nice work, I just did the same gapping method on my 66 ragtop. Here is what I will say, my gaps were perfect until I painted it and put the rubbers on. The doors closed effortlessly and after rubbers, not so much. Also the paint stick rule for gaps is what I would adhere to, the buildup of paint and clear is more than you think, as you are adding material to both sides. I have a couple areas that are extremely close to touching on my door and jam where I added material and I wish I could remove some. Work looks great BTW.
LT1 Burb is offline   Reply With Quote
Old 10-20-2020, 02:32 PM   #199
44boggers
Thanks for your thoughts. I am doing all my sanding and gapping with the rubbers installed. Regarding the gaps, I am making them just slightly larger than 3/16" to account for the base and clear that will be applied. So I think everything should come out as planned, even if I know how dumb those words are
Old 10-24-2020, 03:44 AM   #200
44boggers
Knocked out a little body work the last two days. Stripped down the bumper cowl or whatever it is called, the top filler panel above the bumper. My OCD kicked in hard with this one considering you only see about 10 percent of this panel once the bumper is on. But hey you never know how close you might look and cant risk seeing a wave.
So I stripped down both sides to bare metal, hit it with 2 coats of epoxy, then 3 coats of slick sand, sounded down with 80 then 180, 2 more coats of epoxy to seal it up, then 3 coats of high build primer. The panel was pretty much flawless to begin with so I will leave it in high build until its time to paint. But one more part done!
