#176 |
![]() Join Date: Jul 2016
Re: Crew Cab build preview...
#177 |
My latest project was getting the AC system rebuilt and charged.
I read and read and read up on how A/C works and how the POA valve in our trucks system functions. Read lots on our forum and the autoac forum about 134a problems and decided to stick with R12. I was about to buy some $40 a can R12 off ebay, takes 5+ cans and then looked on offerup, found 2 30lb jugs, one with 17lbs of R12 in it and the other with about 27lbs in it, got those from 2 different people for a total of $185. I bought some AC gauges, vacuum pump, nitrogen tank and regulator....etc. I had to buy the high mount AC brackets from Cummins, it was a ton of work but it all worked out and now I have a working AC system. I learned a lot doing it too. Now I am putting factory AC in my short bed 2wd project, hope to get it charged this weekend. |
#178 |
I almost forgot I put a rebuilt he351cw turbo on it and some 300hp marine injectors. Amazingly my old injectors with almost 300k on them were in great condition. New turbo and injectors make a bit more power, think I need to bump the timing up a bit next. The new injectors do idle noticeably smoother.
#179 |
Next project is on board air, you can see in the last picture part of the mount I made for a York compressor, need to find a compressor at pick n pull, haven’t been there yet. The York will mount adjacent to the power steering pump and below the intake elbow. I machined a v-belt drive pulley and installed it on the fan hub.
#180 | |
![]() Join Date: Dec 2009
You will Enjoy having on board Compressed Air. That brings back memories. My Daddy had a set-up that would run a 3/4" drive IR impact. Main thing is on those York's / the plug in the top is where you add Oil. Keep oil in It. Daddy used it daily as a Over the Road Mechanic. With his busy schedule sometimes it ran TOO low. I learned a lot . He had Dual tanks and valves on the bottom to drain the water. Off that subject but with the same truck (That the Odometer turned 10 times) I remember one time I was riding shotgun with him and the truck quit running. Quick survey of the situation was fuel pump not working. So With a set of Oxy/Acy. bottles for a torch set-up in the bed of the truck. With removal of gas cap on auxiliary tank and an Oxygen hose with (Magic Tape) and 5 lbs. pressure pushing fuel forward. So we did not walk home. ![]()
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#181 |
Active Member
![]() Join Date: Jun 2007
Randy, You have way to many cool projects. Chuck :-)
#182 |
Thanks bud. Working on getting you that cab
working on my 72 k10 today |
#183 | |
![]() Join Date: Nov 2018
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
#184 | |
I thought of the manifold flip and almost had to do it when I installed the he351 turbo since it is slightly larger diameter. If it becomes a problem I plan on installing a turbo blanket, making a heat shield or re shaping the outer ac box. In fact the box on it has been repaired so is a good candidate to test out making a dimple in it. |
#185 |
6>8 Plugless........
![]() Join Date: Sep 2007
On my 72 my turbo is really close to the hvac box. It hasn't even discolored it and I've towed quite a bit with the truck. I was worried about it too but I don't think it's an issue. But, maybe the heat could effect the coolness of the A/C? I couldn't tell yo on that because I haven't finished my ac.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#186 |
Not trying to turn his thread into something else and do a thread jack. But since a few of us are running very similar setups I thought y’all may like to see the flipped manifold clearance. That wire loom isn’t actually touching by the way.
#187 | |
When I charged my ac system it was only 75 degrees here so it hasn’t been fully tested. I thought i checked the box by hand after driving a few times. I suspect it might get a little warm idling in heavy traffic but moving down the road there has to be a lot of airflow over it keeping it cool. |
#188 | |
When I was installing my engine I put it where it is, which is as far to the driver side and back as possible while using the 2nd gen mounts...at the time I had a feeling the manifold could be flipped but wasn’t sure, also I used the diamondback exhaust system for a 1st gen and didn’t want to make many mods to it therefore I didn’t flip the manifold. I didn’t want to mod the exhaust because the amount of work it takes to install a Cummins is overwhelming and I wanted it on the road as soon as possible. If I have any problems with the ac system fromexhaust heat I will flip the manifold to,cure that and to get a better air filter set up on it with less bends. |
#189 |
BTW: took another trip to Vancouver about a week ago, 135 miles each way, all highway with a couple slow spots, 19.5 mpg...I still am stunned by the mileage but since the install have read more and more threads on Cummins installs in this style and square bodies...mpg seems to be inline with others that have posted, although most seem to be VE pumps.
#190 |
In my ac system picture a few posts ago you might notice I installed the he351cw turbo, and when I did that I installed 330hp Bosch marine injectors.
In theory I think it should get on the boost a little sooner, it probably does, what it does do is pull stronger and a bit longer, it’s more robust in almost every way. It does have a gutted afc, not my doing so it will put out a cloud of smoke if floored when not spooled up. It’s easy to control since it’s manual transmission. I did break the tires loose at 40mph or so in third going uphill when the turbo spooled which it didn’t seem to do before, scared the crap out of my wife... So even with the larger turbo and injectors the mpg is fine which makes me real happy. |
#191 |
I also never posted that when I installed the dana 60 front axle I put 3:54 gears in it, the axle needed a full rebuild so I bought a new gear set, at the time I still had the rear dana 60 with 3:73 gears, I ran it a bit like that, maybe a week then found a 1st gen dana 70 with 3:54 gears on Craigslist, I think I paid about $200, it has a powelock, I bought that and installed it, of course I had to remove the shock mounts and perches, find suitable replacements, etc, along with mods to the parking brake cable mounts. The build/install was fine but I had just done all that mount work to the dana 60 I had in there...at least the dana 70 has 32 splines, the dana 60 had 30 and I was afraid it would break at any moment.
As luck would have it the local pick n pull got a 2nd gen truck with a dana 80 3:54 power lock the following week...I bought it so another axle build and swap is in the works...it will need to be narrowed. I bought a mittler brothers alignment bar and made some pucks but haven’t gotten to it yet. |
#192 |
Sooo....you might ask, how Do i like the new gears?, I don’t. Too high. Around town it’s much more effort to take off and seems to lug a bit on gear changes where the 3:73’s seemed perfect. It’s fine, it’s just different. Of course much better on the highway but I’m in town usually. So I will eventually put a 6 speed in it, not anytime soon but it’s on the list.
#193 |
A couple pucs of what im working on right now, 72 K10, kind of a frame on restore...
#194 |
A couple quick thoughts. I’ve heard when going larger on injectors as long as you have enough turbo which we do. But going larger helps mileage to an extent. My theory is more torque equals less work/load. I’m running 35s with 4.10s, limited by the Eaton. When I had 37s it was happier highway but I felt I would use more throttle accelerating. If I keep cruising under 72-75 it seems to just go with very light throttle at 7-8 lbs of boost. What size tires are you running? O and I’m auto with overdrive if I didn’t tell you before.
#195 | |
I have 32’s essentially, bfg specs them as 33 but I think they measure out to 32 ish. Don’t recall the size but they are the largest diameter that will fit stockish wheels for hubcaps, econoline wheels. I think my boost is around 10 at 70 mph which I think is 1800 rpm or so from my last trip glancing at the tach. |
#196 | |
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
#197 |
I haven’t posted in a long time....
The crew has been my daily driver all all last winter and still is. Haven’t had any problems with it as all. When I started driving it spring of 2018 I think, it had lots of bare metal in the door jambs, roof etc, all the crew cab mods. Well all that stuff got real rusty, I wasn’t able to keep it out of the weather. So I have it torn down a bit and am painting the door jambs and will be finishing the outer roof too. While it’s down I’m installing the trim and practicing making the upper back door trim. Surprisingly the rust came right off with a wire wheel, I normally don’t use a wheel for rust removal but it did a real nice job, I guess the rust was really just light surface rust, it looked real ugly though. |
#198 |
I don’t know if I ever commented on how rough it rides. I haven’t had a straight axle 4wd in a long time and never as a daily driver so I just chalked it up to straight axle ride, well after finishing my k10 and it driving so nice and smooth I decided to do something about the front suspension, it has unknown very heavy duty 2.5” lift springs, I don’t think they absorb any road impacts at all. I think it just bounces over stuff.
Today I ordered a set of alcan springs which will be custom made for my truck and the weight on the front axle. I can’t wait to get them, the ride quality really sucks and it’s wearing on me. Ordering from alcan was a chore and I’m not sure what I will get. I posted in the 4wd section about how that went. Hopefully I will get a nice set of springs that provide a smooth ride.... |
#199 |
![]() Join Date: Apr 2008
Will look good when you’re done- hopefully the springs you ordered will work well for you. Thanks for the update
#200 | |
