12-27-2018, 03:59 PM | #176 |
Re: 1972 SWB Build
Are you installing the park safety switch on the transmission? I'm in the middle of reworking my LQ9 harness and trying to figure out whether to keep the switch or not. I have a large grey 12-pin connector in my harness that connects to the transmission-mounted switch. I'm guessing you have a single wire from your PSI harness that connects to the brake switch.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
12-27-2018, 04:08 PM | #177 | |
Re: 1972 SWB Build
I did get a new brake switch that supplies the ecm 12v when the brakes are applied and 12v when the brakes are not applied for the TCC circuit. |
12-27-2018, 04:55 PM | #178 | |
Re: 1972 SWB Build
Looks like you used mild steel brake lines? I just put stainless lines on my dad's 66 and it's been a little difficult because the stainless is so hard and it doesn't like to seal without a great deal of tightening. What engine mounts did you use? Looks like you kept the stock perches but maybe used some kind of adapter plates?
12-27-2018, 07:21 PM | #179 | |
Re: 1972 SWB Build
I used the stainless steel lines from Inline Tube. If I had to do it again, I would have used the steel lines. I had to make custom lines for my rear axle and I couldn't get the 3/16" stainless to consistently flare. That's good to know it takes some tightening to seal. I used the stock small block pedestals with energy suspension poly mounts. I just used some cheap adapter plates I bought on amazon. They are 3/8" thick. |
12-27-2018, 08:21 PM | #180 |
Re: 1972 SWB Build
Went into the shop and cut down the lower hose and it fits perfect. I had to flip it around to make it work. The direction I thought it would fit was actually backwards.
12-28-2018, 10:02 AM | #181 |
Almost Satisfied
Re: 1972 SWB Build
Hoses look good. Did you go with an overflow tank for your radiator?
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
12-28-2018, 10:48 AM | #182 |
Re: 1972 SWB Build
Yeah, I am going to. I have a Dorman universal tank kicking around the garage, but I may look in to other options. I haven't really looked in to it much.
01-07-2019, 10:57 AM | #183 |
Re: 1972 SWB Build
Sorry, I haven't updated in a while. We are expecting a baby tomorrow. I've been scrambling trying to get everything in order for that. I have been able to work on the truck hear and there. I decided to back burner the wiring until the end. It was consuming too much time that I needed to be spending on mechanical items. Just about everything is buttoned up on the engine. I broke out the cherry picked to center and align the engine and trans. It is all torqued down now. Once I get it on the lift, I am going to check the driveshaft angles and make adjustments as needed.
I also did some measuring on the brake booster pushrod length. The Tuffstuff booster comes with a short and a long pushrod. Initially, I was going to use the short in conjunction with the Wilwood bullet. But after measuring, I found that the short pushrod/bullet combo was actually .046" too long. The long pushrod measured in at .065" short. After talking to Wilwood, the recommend .062" play so the long pushrod is the way to go. I talk a little about it in the video below. I am officially at a standstill for a few weeks. I've got to help my oldest with his pinewood derby car. His race is on the 26th so we've got to get cooking on that. |
01-07-2019, 11:26 AM | #184 |
Almost Satisfied
Re: 1972 SWB Build
Congrats on the baby! Don't build a pinewood derby truck...they look cool, but go too slow....ask me how I know.
01-07-2019, 11:27 AM | #185 |
Re: 1972 SWB Build
Funny you mention that, my son wants a truck lol
01-07-2019, 11:43 AM | #186 |
Re: 1972 SWB Build
Suggest to him that you make it a "daytona" truck, wedge the front like a door stop, it could look truck-like but it will be faster than a square front. Or, just give him what he wants and let him learn about aerodynamics.
Congratulations on the baby!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
01-07-2019, 07:05 PM | #187 |
Re: 1972 SWB Build
Thanks! I think a slant nose truck would be decent. I can add the weight to the "bed" which is ideal anyway. We shall see. I think I may be more excited than he is.
01-20-2019, 11:10 AM | #188 |
Almost Satisfied
Re: 1972 SWB Build
Did you have the baby? Hope all is well
01-20-2019, 09:57 PM | #189 |
Re: 1972 SWB Build
We did! Little baby girl is perfect! We are getting back in to a groove now. I spent about 5 hours out in the shop today. Heading back to work tomorrow.
01-20-2019, 11:56 PM | #190 |
Almost Satisfied
Re: 1972 SWB Build
Congrats! Hope you get some sleep
01-21-2019, 11:46 AM | #191 |
Re: 1972 SWB Build
Thank you! She is actually sleeping quite well. My boys are adjusting well too. So far so good (knock on wood)
01-25-2019, 10:28 PM | #192 |
Re: 1972 SWB Build
I’ve been slowly working on odds and ends on the truck. Going to work on some wiring tomorrow.
Tomorrow is the big day for my oldest. This is the truck he built. I helped him with some of the prep work on the paint and locating the weight. He did the rest. We shall see how it does in the morning. |
01-25-2019, 11:01 PM | #193 |
Re: 1972 SWB Build
Boy that brings back good memories. Post up the results and some more pictures if you don't mind...
Brian
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
01-26-2019, 04:05 PM | #194 |
Re: 1972 SWB Build
Thanks. We came in 3rd place. Not too shabby for s blocky truck.
01-27-2019, 11:55 AM | #195 |
Almost Satisfied
Re: 1972 SWB Build
I just feel like it should have been painted red and white! LOL. 3rd isn’t bad at all for a truck.
01-27-2019, 08:07 PM | #196 |
Re: 1972 SWB Build
He originally wanted red and white but changed it to white. I was surprised it do so well. I posited the axles and did the 3 wheel setup. Worked out well.
01-30-2019, 11:43 AM | #197 |
Re: 1972 SWB Build
Amazingly clean truck man! Glad to see the progress, I actually remember seeing you post this thing on KCSR when you got it!
01-30-2019, 05:48 PM | #198 |
Re: 1972 SWB Build
Thanks. It's changed a bit since then.
02-03-2019, 09:33 PM | #199 |
Re: 1972 SWB Build
I'm falling behind in here. I've been working on the truck as much as I can. I am finally making progress. The last year or work is finally starting to pay off.
The motor is all but buttoned up. Fuel tank is mounted. Final wiring has been sorted and started. The big items are the fuel lines, transmission lines, and finishing up the wiring. I am going to tackle the wiring first to get it done. I have a plan and all of the parts in hand or on order. I am going to use relays and parts that I mostly had on hand to get it running. Then down the road, re-do it with the nice Bussmann relay center. Here are the latest videos on the build. Thanks everyone! |
02-11-2019, 12:19 PM | #200 |
Re: 1972 SWB Build
Spent some time this weekend sorting the wiring out on the interior. The LS harness is not integrated with the truck and Dakota module and every which way in between. It took a few hours, but it is almost complete. I ran in to a little bit of a snag with the PSI harness and poor crimps. The trigger wire leading from their fuseblock broke free. After some investigating, half of the crimps inside the fuse/relay assembly are no bueno. I am going to de-pin it and fix them all. I think I am also going to bypass the fuel pump relay in the PSI harness and use my own in the engine bay. The terminals they send with the kit are not large enough for the 10ga wire I am using. I did find the appropriate terminals online, but I think I may use one of my heavy duty relays that I am using for the fans and headlights. Keep the high load relays together. Still not 100% yet thought.
Sometimes, I think my anal retentiveness gets the best of me. I can't leave well enough alone. Here is a little video of this weekends progress. |
