05-16-2018, 07:10 PM | #176 |
Re: Brother's keeper - '58 Stepside build
The body shop finished up my rear fenders, all that's left is the doors and the truck will be ready for final prep and paint.
05-17-2018, 02:53 AM | #177 |
Bro
That mobile storage rack is fandamtastic nc
Been there, wrecked that |
05-17-2018, 12:23 PM | #178 |
Yup! VERY cool. Looks easy to make too!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
05-17-2018, 01:47 PM | #179 |
I need to make me one of those. Might help from burning bridges with my wife - keeping them in the guest bedroom and all.
05-17-2018, 06:24 PM | #180 |
The rack keeps stuff from getting bumped and dinged up. It also saves a lot of floor space...
05-31-2018, 10:01 PM | #181 |
Recent progress...
On the 3rd attempt I finally got the filler between the radiator and grille surround painted |
05-31-2018, 10:06 PM | #182 |
Fixed the low brake pedal, finished the heat wrap on the H-pipe, mocked up the tail light wiring, and got the bed rail plugs finished up.
05-31-2018, 10:10 PM | #183 |
Finished up the custom fit carpeting...
05-31-2018, 10:27 PM | #184 |
Black Sheep - I went back to page 6 to see what you had posted about your carpeting but there wasn’t much detail.
Did you do it yourself? If so it looks great. What did you use for the edge, some kind of continuous whip stitch or banding/edging? I really like the look.
05-31-2018, 10:52 PM | #185 | |
05-31-2018, 10:59 PM | #186 |
Dan here's the modification done to the floor. Filler panels were added to eliminate the cut out for the cab steps. The floor is flat from door to door...
06-01-2018, 03:19 AM | #187 |
Very interesting. So when you open the door is there storage space under these filler panels? Or is it closed off permanently?
I’ve never thought of it before but if someone did this with hinged panels it would create quite a bit of storage space and these truck have ZERO storage especially if you’ve added AC like i have.
06-01-2018, 08:03 AM | #188 |
It’s like a shelf so it’s open underneath. There isn’t as much room as you might think in terms of storage. I will probably mount a fire extinguisher on the driver side
06-06-2018, 10:00 PM | #189 |
I spoke to the painter, he says in 2 weeks he can get it in for final prep and paint. In the meantime there’s still plenty to do...
06-06-2018, 10:03 PM | #190 |
Got a little care package. The UPS delivery person probably hates me, the box was pretty heavy...
06-16-2018, 02:33 PM | #191 |
Quick update, I guide coated the louvers and finally finished blocking them out. Box crossmembers and a few other small parts are back from powder coating and progress continues. Shooting for getting it to paint in the next few weeks.
06-20-2018, 10:38 PM | #192 |
Door hinges in, just waiting on the doors...
06-21-2018, 12:20 AM | #193 |
Nice and clean............
06-22-2018, 06:40 PM | #194 |
Black Sheep, If you said and I missed it I apologize in advance: What's with all the door switches? I assume the one with three contacts is for speakers or maybe electric windows in the doors? The single black button one is for a dome light? What's the other one?
Also, I'm curious what brand/model the single button dome light switch is as mine is still manually operated only and I want it to work with the door opening. Thanks for any help in advance.
06-22-2018, 08:53 PM | #195 |
The topmost switch is for the dome lights,it grounds a relay and completes the circuit so the relay turns on. Beneath it is the hole for the door popper. The bottom one is the contact for the door solenoid. It’s a spring loaded contact, an identical one is on the door. They get current to the solenoid without having a wire running from the jamb to the door.
06-22-2018, 08:56 PM | #196 | |
06-22-2018, 09:21 PM | #197 |
You sure have a way to keep my attention going! Great Work
06-22-2018, 10:12 PM | #198 |
Previously mentioned schematic...
06-22-2018, 10:16 PM | #199 |
07-01-2018, 07:25 PM | #200 |
Thursday I brought all of the sheetmetal except the cab and doors to the painter. My goal for the weekend was to block the jambs and get them in paint. Once the doors are hung the rest of the truck will be ready to go.
Color is '63 Chevrolet Laurel Green... |
