![]() Join Date: Sep 2017
Re: Ol' Blue
Thanks Raven, that is a good idea. I have some of those wheels to try that with.
I don't think I'll try all the seams, but those where the factory welded them and did a poor job.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
Re: Ol' Blue
I plan to upholster the headliner in my project. Hopefully keep some heat out, or in depending on the weather, and also help with sound insulating.
Re: Ol' Blue
I think I have the original door latches and strikers for the 55-59 truck, but I see some differences and wanted to ask for some help in figuring them out. Pictures to come.
Thanks.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 Last edited by 8man; 01-30-2025 at 01:05 PM. |
Re: Ol' Blue
The second photo shows the two strikers, they are different. Is there a reason for this? Has anyone seen this before?
The first picture shows the latch, without the metal strip/shield, the 3rd photo shows the latch with the metal strip covering the striker. Thanks.
Re: Ol' Blue
Possibly the difference between a GM part and an aftermarket part.
Mine were from a farm truck and totally worn-out. I had to build up the strikers for the latch to clear the groove worn in. |
Re: Ol' Blue
I plan to use latches and strikers from a modern vehicle. Like the besrclaw style but a GM part.
Re: Ol' Blue
Thanks Raven. I thought about Bear Claws, and used them on the 48, but wanted to stay stock looking on this one.
You don't know which is re-pop and which is original do you?
Re: Ol' Blue
Sorry I don't. All the doors I have had really well worn latches.
Re: Ol' Blue
I think the top one with an actual thick plate is OEM, and the bottom is a cheaper stamped aftermarket... usually whichever part looks like it was better made was OEM.
The little metal cover on the latch was like a easy-fix-it option to repair a worn out part instead of replacing the whole thing. Often a groove would wear into it from that OEM striker and that little plate covers the groove and restores the alignment.
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
Re: Ol' Blue
Thanks Dave.
Re: Ol' Blue
Ok, ok, I've been slacking, I know. I have been doing stuff not so fun, like Metal to Metal on the cab, getting it ready for primer. However, I did make some progress so far this week.
I made the brackets for the battery box, painted them and got it all mounted up. Yes, it's a pain to change the battery, but I did it on the 48 and liked not having it under the hood, so here it is. The 2nd picture is of the rear axle. I bought a "Ebay kit" for the rear brake line, and guess what, it didn't fit. So, I broke out the bender and tubing flaring apparatus and re-built it. It now fits. While I was working on the rear axle, I made sure the pinion angle was at 3 degrees up. I'll check this again and then weld the perches to the axle.
Re: Ol' Blue
Well, I decided to smooth out the seams. Started with welding and grinding the seams I wanted to smooth out. Have some more to do, but I wanted to post an update.
Going to use some fiberglass reinforced "Bondo" to finish the job.
#13 |
Re: Ol' Blue
looking good
keep at it
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
#14 |
Re: Ol' Blue
will you epoxy it first or fill over bare steel? arguments for both methods. I like to epoxy first to create a moisture barrier.
#15 |
Re: Ol' Blue
If I go metal to metal or all metal, it'll be first then primer.
If I go filler with fiberglass, it'll probably still be first, but I'm still wrestling with that. That's why I haven't decided which filler to use, but I'm leaning toward the fiberglass.
#16 |
Re: Ol' Blue
I find the fiberglass filler is harder to lay down smooth over thin spots due to the small strands.
#17 |
Re: Ol' Blue
I'm not sure what you guys are referring to when you say 'fiberglass', is it fiberglass filler with strands? or, what I have done before, is add fiberglass resin to regular body filler? It makes the body filler very smooth/creamy and easy to spread, AND, it is very hard once cured.
Either way will work, and FWIW, I do prefer to epoxy before filler. (as I like the moisture barrier on the metal)
#18 |
Re: Ol' Blue
Thanks guys.
The filler would be the one with the short fiberglass strands, if I don't go with the All Metal, and I'm leaning that way. If I do use the filler with fiberglass, it will definitely be after primer. I've been researching that again and that is the recommended way to do it.
#19 |
Re: Ol' Blue
I assume it is the stranded fiberglass body filler. It is available in different strand lengths.
#20 |
Re: Ol' Blue
Yes, that is what I've been looking at.
#21 |
Re: Ol' Blue
Went with Dynaglass to smooth out the welds and seams. Not finished, but I think it's looking pretty good.
#22 |
Re: Ol' Blue
Well, the cab is finally in primer, and all the seams are gone!
Next stop is to test fit the body parts.
#23 |
![]() ![]() Join Date: Oct 2014
Re: Ol' Blue
Nice work!!
#24 |
Re: Ol' Blue
Thank you. About 60 hours, but I like the finished look.
#25 |
Re: Ol' Blue
very nice. always a welcome milestone when you start shooting primer.
keep it going
| Bookmarks |
