Closed Thread
Old 01-04-2016, 04:41 AM   #1976
casey g
casey g's Avatar
Re: What did you do to your truck today part III
All I did was figure out where I wanted to mount the bags.
casey g is offline
Old 01-04-2016, 02:13 PM   #1977
AngryPirate
AngryPirate's Avatar
Tried my hand at some lead body filling. I certainly prefer it to the more modern body fillers.
I also sprayed it with some eastwood 'after blast' since I wasn't putting any primer on it straight away.
Before and after pics...
AngryPirate is offline
Old 01-04-2016, 10:51 PM   #1978
TJ's Chevy
TJ's Chevy's Avatar
Painted my steering box and pitman arm...also installed my new water pump pulley.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 01-05-2016, 12:19 PM   #1979
forestb
forestb's Avatar
Stopped buy the paint shop again and here is what I saw.
forestb is offline
Old 01-05-2016, 12:25 PM   #1980
schpeen
schpeen's Avatar
way cool
i remember that day!
schpeen is offline
Old 01-05-2016, 02:48 PM   #1981
TJ's Chevy
TJ's Chevy's Avatar
That's a pretty color!
Old 01-07-2016, 11:53 AM   #1982
chevy2tom
chevy2tom's Avatar
I pulled the new "ready to run"(no it's not with antifreeze in the oil pan & cylinders) engine on my 64 I purchased from California last month. From what I've read the new promax vortec heads may be warped. Oh well lol
chevy2tom is offline
Old 01-07-2016, 03:08 PM   #1983
Joemomma1
Joemomma1's Avatar
Muhaha! That's what happens. Keep poaching our trucks!
Joking. So it was bought then shipped without been seen?
Joemomma1 is offline
Old 01-07-2016, 04:19 PM   #1984
chevy2tom
chevy2tom's Avatar
Yep, sometimes you have to trust your fellow man. Everything is new on the engine including the short block from summit, we'll pull it apart & see
Old 01-07-2016, 05:41 PM   #1985
60chevyjim
60chevyjim's Avatar
it may have the wrong head gaskets for those heads ?
I had a problem something like that when I put some late model heads on a 1964 327 .
the older style head gaskets didn't work with the late model heads I had .
60chevyjim is offline
Old 01-07-2016, 06:56 PM   #1986
chevy2tom
chevy2tom's Avatar
Thanks Jim, that'll be one of the things I'll look for
Old 01-07-2016, 10:41 PM   #1987
craiginaustin
craiginaustin's Avatar
That sucks, sorry to hear it.
craiginaustin is offline
Old 01-07-2016, 10:45 PM   #1988
60chevyjim
60chevyjim's Avatar
chevy2tom that shore is a good looking truck . I hope it is a minor problem .
Old 01-07-2016, 10:53 PM   #1989
chevy2tom
chevy2tom's Avatar
Thanks guys, as you can see the heads were never painted(they rusted as soon as it rained here) so I was planning on pulling the engine to paint it black & clean up the engine bay anyway.
Old 01-07-2016, 10:57 PM   #1990
chevy2tom
chevy2tom's Avatar
Joe, we gotta get all those sweet west coast trucks to the Midwest before California becomes part of the ocean lol
Old 01-07-2016, 11:07 PM   #1991
craiginaustin
Looks great dude, nice work.
1964 C10 Fleetside Long Bed
Old 01-08-2016, 06:48 PM   #1992
chevy2tom
chevy2tom's Avatar
You are correct Jim, it was the wrong head gaskets allowing the coolent to bypass the cylinder head & to the oil passages to the lifter valley 2 new head gaskets, solvent flush the oiling system & some fresh oil & filter then back to the truck.
Old 01-08-2016, 09:57 PM   #1993
hkopp
I had added a receiver hitch to my 60 k10, since it was for a newer chevy the side brackets didnt line up with my frame. I cut them off and bolted the hitch directly to my frame (I didnt want it hanging down anyway.
So I had the hitch ends in my iron scrap pile, and I needed to make new seat brackets as my seat was sitting too low in the front. The ends worked perfect...1/4" steel, 3 mounts into the floor on each side, and 4 mounts into the seat. It is VERY sturdy...sure beats the 2 2x4's that were screwed together and a long bolt going thru them.
hkopp is offline
Old 01-09-2016, 08:37 PM   #1994
forestb
forestb's Avatar
Tried to install the vent glass into it's trim and broke the litte pivit tab at the top of the trim in the process. So the glass is fully installed in a broken trim. Now I have to get the glass out of the trim without breaking it and have the table welded back in and then repaint the frame.Not a fun day.
forestb is offline
Old 01-10-2016, 12:47 AM   #1995
TJ's Chevy
TJ's Chevy's Avatar
Started it and moved it forward 15 feet.
Old 01-10-2016, 05:22 AM   #1996
Grizz1963
Grizz1963's Avatar
Progress is Progress as my good friend Ta2Don always says.
I bought a new, adjustable Panhard Rod from Performance On Line for the truck as the various geometries change when you lower the truck.
Tried to undo the previously lubricated nuts keeping ithe Panhard Rod captive.... Fail.
Out came my faithfull rattle gun and in moments we were in business. This really is a great tool when doing a resto or trying to get 50 year old nuts undone.
Wear and tear and rotten bushes.
Once that was done, I could at last do the rust converter on the prop shaft, diff and rear axle and trailing arms. These will all get painted black, like the rest of the underside of the truck.
I am in two minds about the lowered springs, the red I put on them is looking worse for wear, being rattle can red, so do I paint them red Hammerite or black??
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 01-10-2016, 07:43 AM   #1997
jbgroby
jbgroby's Avatar
My brother came by to help me bleed the brakes, we realized that for what ever reason the OEM push rod was/is too short to actuate the new single master cylinder. We tried adjusting it out up to a 1/4" but that was still not enough. SO we found some 7/16th. fine threaded rod and machined down one end allowing for and extra 1 1/4" length, works perfectly. We also fired her up for the first time in about two years and realized that the Alt. fan blade is making contact with the shelf. so I need to get a 2" shorter belt to bring the Alt. inward.
jbgroby is offline
Old 01-11-2016, 06:38 PM   #1998
OldChevy61
OldChevy61's Avatar
Worked on the heartbeat a little more. Need more bolts.lol.
OldChevy61 is offline
Old 01-11-2016, 07:49 PM   #1999
karlbenz
started to prepare for taking cab off yesterday. wife made me go to doc today. bronchitis. damn the luck
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline
Old 01-12-2016, 01:54 AM   #2000
Joemomma1
Joemomma1's Avatar
Got it running for the first time since I tore it all apart. No fires yet so it's looking good. Had a hell of a time getting fuel to the carb. Double checked the new fuel line and all connections twice. The pump did fail but a swap still didn't fix it. Turned out to be the open port on the back of the carb for the pcv hose. Nothing like racking your brain then finally getting it.
Closed Thread
