Old 12-30-2010, 12:35 AM   #2001
daverod
SSN 706
daverod's Avatar
Re: Daverods project 66
Originally Posted by Strodder View Post
What's the link?
The paint section on this forum.http://67-72chevytrucks.com/vboard/f...splay.php?f=16 You don't have a rum and coke in your hand do u?
daverod is offline   Reply With Quote
Old 12-30-2010, 12:38 AM   #2002
shrunken66stroker
shrunken66stroker's Avatar
I would flat clear the whole thing for durability and shiny clear the flames. Did I just invent he term "shiny clear"? I think I coined a phrase. Anyway, you won't be able to color sand or buff the flat clear because it will start to get shiny, so your not getting yourself into a bunch more work. Do a test. It's the only way to see before pulling the trigger. Oh, it's about the time of year where I mention how cold it's getting down here in Vegas. This is where you give me **** and imply that I'm a puss.
Ask around at paint shops to see if I'm right. Or someone chime in here. What do all you other guys think?
shrunken66stroker is offline   Reply With Quote
Old 12-30-2010, 12:40 AM   #2003
daverod
SSN 706
daverod's Avatar
I did notice it warmer here at night then in Florida. I kinda like the cold. It's better then heat. You can always just put on more clothes. I think I would miss the snow. I like to sled and snow board too much. Maybe when I'm an old #uck I'll think different. Sorry Strodder. I think I need to do some paint testing.
Old 12-30-2010, 01:08 AM   #2004
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
I would spray a flat clear. It will fade and start to look chaulky if you dont. Oh and I through in some wire loom in with the harness.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 12-30-2010, 06:50 AM   #2005
Ipaintgrt
I'm not sure, but I think that the Hod Rod Flatz should be ok. I'm not a fan of flat myself, but as long as you use a paint that is made to take the elements and has UV protection it should be fine. Like I said I like shiny, but diversity is what makes our hobby great. Great build, keep up the good work. Also your local paint supplier should be able to answer any questions you have.
Ipaintgrt is offline   Reply With Quote
Old 12-30-2010, 10:31 AM   #2006
Strodder
Daring to be Different
Strodder's Avatar
How did you know? I was too lazy to look for it.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 12-30-2010, 10:35 AM   #2007
Strodder
Strodder's Avatar
Here's our house we had in Vegas. Yes it gets cold there.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 12-30-2010, 11:15 AM   #2008
daverod
SSN 706
daverod's Avatar
I think the Hot Rod Flatz is made not to be cleared. It says its sealed. If I was going to clear it why not just use normal paint that can be sanded and then clear it. I'm not to worried about it fading or chalking. I am worried about how tough it is. I want to do a test piece and then rub on it to see how much it can take.
COMPLIANT COATING SYSTEM
POLYURETHANE COATING SYSTEM
Kustom Shop Products 6695 Rasha Street, San Diego, CA 92121 (858) 909-2110 KustomShop.com
HOT ROD FLATZ URETHANE
VOC: 290 g/l, 2.42 lb/gl (Combined Components)
HOT ROD FLATZ is a fast drying two-component
durable and chemical resistant urethane finish
that provides excellent adhesion to properly
prepared steel, aluminum, fiberglass and OEM
finishes. HOT ROD FLATZ also contains UV
inhibitors to protect your finish from fading and
chalking like traditional primers.
Now you don’t have to be limited to just primer
for your flat look. With 36 traditional to wild Hot
Rod solid colors and 20 metallic and pearl colors
to choose from, customize your ride with HOT
ROD FLATZ. HRF colors are very user friendly
and easy to spray and achieve that custom low
luster Hot Rod finish without having to use a dull
clearcoat. Optional KR Reducer may be used in
areas where VOC limits permit.
ADVANTAGES:
�� High Durability
�� Chemical Resistance
�� Easy to Mix
�� Fast Dry - Dust-free in 20-30
minutes
�� Single Stage Urethane
�� 36 Solid Colors Available
�� 20 Metallic and Pearl Colors
Available
�� Low Luster Anti-glare finish
Product Numbers: HRF201 - HRF236 (solids); HRF260 - 279 (metallic & pearl)
COMPLIANT COATING
Old 12-30-2010, 11:48 AM   #2009
bubba327
HOW long until spring??
bubba327's Avatar
Geez Dave, you are reading the directions?
Then the gas mask respirator must be working !!!
The truck is looking great !!!!
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 12-30-2010, 12:23 PM   #2010
ruffrida2005
Oh by the way. That UT burnt oranage sure looks good.
Paul
Old 12-30-2010, 02:04 PM   #2011
daverod
SSN 706
daverod's Avatar
Got a big box of pampers today. Thanks Paul.
Old 12-30-2010, 02:07 PM   #2012
daverod
SSN 706
daverod's Avatar
Gave up on the gas mask idea for now ,bought a throw away resp. It was cheaper then new cans. And quicker then the mask thing.
Old 12-30-2010, 02:10 PM   #2013
daverod
SSN 706
daverod's Avatar
Don't look now but in the second pic I think your duck got away. Nice house. Looks easy to build. How many Sq/ft?
Old 12-30-2010, 03:34 PM   #2014
ruffrida2005
I wonder if that's Bonnie floating in the pool. Oh and your welcome for the Pampers. I figured you might need some. I found some wires that go to the head lights. Didn't know they were still on the front clip. I'll get them in the mail to ya.
Paul
Old 12-30-2010, 03:40 PM   #2015
Strodder
Strodder's Avatar
2400 sq. We liked the house, but hated Vegas. We only lived there for 19 months. And made a ton of money. We got out just in time. Then the housing market dropped.
BTW #uck that duck
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 12-30-2010, 04:11 PM   #2016
daverod
SSN 706
daverod's Avatar
It's always good when you count your money by the ton.
Old 12-30-2010, 04:16 PM   #2017
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
X2
Tony
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 12-30-2010, 06:31 PM   #2018
daverod
SSN 706
daverod's Avatar
Thanx Ruff. Reading the instructions now. Are u sure its painless. Looks like it going to hurt.
Old 12-30-2010, 10:12 PM   #2019
Strodder
Strodder's Avatar
We bought the house for 305,000 tons,and 19 months later we sold it for 500,000 tons. Who says you lose when you go to Vegas.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 12-30-2010, 11:39 PM   #2020
shrunken66stroker
It snowed here today. Flurries mostly, but I guess it counts for Vegas snow.
Old 12-30-2010, 11:47 PM   #2021
daverod
SSN 706
daverod's Avatar
Put my bed back on by myself. Well, the dog tried to help. Made a shifter knob. Now if the snow would melt I could go test out my new notches. Thinking about putting a rear sway bar and moving my rear shocks.
Old 12-30-2010, 11:54 PM   #2022
Strodder
Strodder's Avatar
Dave do you have a switch for each bag? If you do you don't need a sway bar.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 12-31-2010, 12:04 AM   #2023
bubba327
bubba327's Avatar
I Like the shifter . What happened to the shingle hatchet you had for a while as a shifter???
I built a Shifter knob from a brass door knob once , Poured it full of lead and then drilled and tapped it . ..
Worked good and looked cool but it was always too darn COLD in the winter when you had to shift !
I took it off and went to a 8-Ball The plastic felt warmer..
Old 12-31-2010, 12:18 AM   #2024
daverod
SSN 706
daverod's Avatar
I got the accuair for my 66. I was thinking about the sway bar for my 64. It just has jeep springs for now. If I put bags on my 64 no compressor do you think I would need a rear sway bar?
Old 12-31-2010, 12:20 AM   #2025
daverod
SSN 706
daverod's Avatar
When I bought a new shifter I got rid of it. Had to cut it off.
