#2001 |
Gearhead
Re: What did you do to your truck today!
Eagleuh1: Sorry to hear, but glad you, truck and motorcycle made it out ok. I hate hearing things like this...
I ordered Autometer water temp/trans temp gauges and new front brake lines for the 72' also might order a new trans crossmember today, need to get this thing squared away for summer cruisin'
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 Last edited by 6772owner; 03-30-2011 at 10:28 AM. Reason: text |
#2002 |
Damn Eagle, that really sucks. I'm glad you're okay.
#2003 |
![]() Join Date: Mar 2010
#2004 |
Got the driver side bed panel just about stripped to metal... It takes awhile to get a gallon of bondo off an area that is only in a 1 sqaure foot area...lol (heat gun is the key btw) Has anyone elses truck been shot at with what seems to be 20 guage bird ****??? o well..
66 Gmc 1 ton. Long Step 351e V6 69 1/2 CHEVROLET (now a shortbed) LONGBED! ![]() ![]() 61 Shortbed Fleetside 1/2 ton.. in progress Next a 50-53! MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=447926 |
#2005 |
in the morning i removed the front wheels, hubs, and drums. then i removed the old seals and bearings. then i cleaned the bearings. after lunch i took the bearings to be packed. when i came home i cleaned the wheel hubs. then i pressed a seal in too hard and crushed it so i quit for the day.
The Next Day 3/31/11: the seal isn't designed to sit flush with the hub once its in, about half of its width protrudes above the hub. that's what led me astray yesterday. so today i bought another seal and put it in no problemo. put the hubs and drums back on so i'm done with packing front bearings. if my truck has feelings it should feel ecstatic about its front wheels. nothing left to do there - its got all new brake shoes, drums, cylinders, hoses, and freshly cleaned and packed bearings. when i started this little project, the front brakes had no stopping power whatsoever. they were an abused, neglected mess. i also put in a new ignition cylinder that uses the same key as the door locks. my camera acted up (aka "operator problems") so no pics to bore you with. i decided to edit my post of yesterday. the thread won't go ttt on edits i've noticed. i may start a project thread of my own so i can keep a record of what i do to my truck.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 Last edited by bollybib; 03-31-2011 at 11:16 PM. Reason: finished up the job |
#2006 |
I got visited by the brown box guy, I finely took the plunge and found some 3/4 Length headers, I will be putting my own finish on these headers since I have done it in the past and they hold up great the way I have done it.
These style headers are for an SBC 88-95 and I did some reading on them fitting for our trucks and the frame has to be notched a slight bit, that was not a big deal for me really it only took about 20 minutes to complete. I am very pleased with the quality of these headers and the low price. Header is slightly touching the Frame here before Notching the frame a bit After Notching my frame.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 Last edited by Jeffs70; 03-31-2011 at 08:47 PM. |
#2007 |
Where did you get them headers? How much were they? Looks great!
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
#2008 |
![]() Join Date: Nov 2010
I installed new plug wires a new fuel filter and replaced me ebrake cable
1970 Custom camper 20 lwb 1978 yamaha xs1100 (insert clever quote here) |
#2009 | |
Here is also a Link for you all that are interested http://cgi.ebay.com/ebaymotors/ws/eB...#ht_2288wt_918 Item number: 190509493576 Incase the link doesnt work
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
#2010 |
Still plays with trucks
So what is your trick to getting a finish on them that will hold up? I've never had anything work for long.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
#2011 |
70Custom10
I ordered the 2" lowering springs for the rear that will give me that nice level look im going for.
#2012 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Finally got rid of the cheap coil overloads, re-installed the bump stops, and installed Hellwig overloads on my K20.
![]() Removed: ![]() Installed: ![]()
#2013 | |
RAT1968 '68 Cab/'71 Parts
I had a two sets ceramic coated. Sort of a shiny aluminum floating in ceramic bake-on product. You all know what that is. The first set worked for as long as I had that truck. But it was serious bucks to have done. And, as an aside, I took the other set I had been given by a friend for yet another truck. They were a little pitted. The same coater, a pro for sure, said they would come out with some "cottage cheese" in the bad spots, after they blasted them. I still went for it...For about two bills +. They looked okay when they were done. But only until I put them on the truck and started it up. Blew three inch holes in both sides. Bye-bye $$$$$$. I was stupid. The upside? I won't do that again. I'll only ever coat new headers. I don't expect this chrome will last too long.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 04-01-2011 at 01:14 PM. |
#2014 |
![]() Join Date: Apr 2004
New wheels and alternator
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#2015 |
I put a splitter on the front for the high speed passes I make with the 250. Race ready now.
![]() ![]() ![]() Looks like it belongs there to me. Someone posted a pic of this adaptation of a Ford part on their truck. I stole their idea. Thanks to whoever it was. Chop |
#2016 | ||
#2017 |
got the vent windows out and side glass... Called around for pricing to have the cab blasted. Kinda was trying to avoid going this far...but "might as well"
#2018 |
Got a product you like and a link to it for reference?
#2019 |
Changed my shifter cable and drove it out to the Sonic cruise night. 2nd time out in 5 months.... felt good!
#2020 |
Got my Boyd's Welding gas tank today, it was waiting for me when I got home from work. I wasn't expecting it for another week, so, I put it in my truck this evening.
#2021 |
any more info on that (part #, price, where to get it, etc.) i kind of like it, looks good, also any more pics of the truck, how easy was it to install??
#2022 |
From Fordparts.com picked up at my local dealer for $27.91. Look up parts for a 1995 Bronco.
Part Name: Bumper Valance Panel Part Number: 17626 Part Description: Black (Front) I used some self tapping screws on the lower edge of the front fenders and two brackets I bent up to secure it to the bottom of the frame rails. I'll get more pics if it ever stops raining. Chopster |
#2023 |
![]() Join Date: Feb 2001
Today fine69 will be picking up the Circuit Rider and hauling it back to his shop and fix the "leaks"...then once it is mechanically sound I will drive it down to the body shop and let Curt wrap up a few details that need to be finished. Then the Circuit Rider will be ready to prowl the streets in all her glory.
![]() The next step is to buy a set of 15x7 TT II's for the front and also a tonneau covers for the bed. ![]()
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 04-02-2011 at 09:41 AM. |
#2024 |
Dropped in my 350/th350 yesterday..Use to be a inline 6 with 3 speed Od. Now to figure why my 2 piece drivehaft is to short...And about 2 inches from even touchin the trans. Any ideas?
#2025 |
yes, i do
the l6 mounts sit further back on the crossmember than the 2wd v8 mounts. you can a) move the engine back to the rear holes, where the l6 was sitting b) get a th350 with the 9" tail housing c) lengthen the drive shaft
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
