#2026 |
![]() Join Date: Nov 2007
Re: PO has me PO'd
ok, I found them plates and ubolt, still in my scrap pile. If you want, just cover shipping and there yours.
#2027 |
![]() Join Date: May 2006
Re: PO has me PO'd
Are the plates heavily pitted? I just bought some aluminun stock to build the plates, but if yours are in good shape, ill take them. Thanks for thinking of me
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#2028 |
Re: PO has me PO'd
There still kinda muddy, but I see no pitting at all. Send me a pm with your addy if you want them and I will get them out in next few days.
:Edit: Relooked. It is just starting to get to the points of pitting. But they are still very solid pieces. Last edited by Dale99; 07-15-2013 at 08:43 PM. |
#2029 |
Re: PO has me PO'd
Thanks for taking the time, and not going to the scrap yard yet....PM sent
#2030 |
Re: PO has me PO'd
Do you need the ubolt? Its bent, but could possibly be useable.
#2031 |
Re: PO has me PO'd
Yes, if the threads are good
#2032 |
Re: PO has me PO'd
Just sent out, should have friday.
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half ![]() 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
#2033 |
Re: PO has me PO'd
Sweet, thanks Dale. And yet another reason why this board rocks....how much do i owe you for shipping?
#2034 |
Re: PO has me PO'd
After thinking about it, I got a box of hardware for free off this site. So I'll pass that along.
#2035 |
Re: PO has me PO'd
![]() 20130717_123126 by jarosaj, on Flickr Had my nephew make a plug for the fuel regulater, was told or read that you dont need to, (gotta be true, if it was on the internet, bonjour)lol, but i thought it would be better to have the return fuel go directly into the basket, as opposed to just shooting all over and some of it going in the basket Got the 1/4" 6061 aluminum plate from McMaster-Carr, for the retaining plate at the fuel pump ![]() 20130717_123808 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-18-2013 at 11:20 AM. |
#2036 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: PO has me PO'd
Actually it is preferable to have the return as far away from the pump as possible so as to not aeriate the fuel, and to give the warm return fuel time to cool down.
#2037 | |
Re: PO has me PO'd
Now that you mention it, i will look into the actual function of the pump, as far as where the pick up of fuel is....seems to have a filter sock on the bottom of the basket, so that must be where the fuel is introduced. Then, somehow, it must take it out of the basket, dunno If it dumps into the basket, before being used to supply fuel to the injecters, it should have time to deaerate, and cool down, but i dont know at what time the fuel is being used from the basket Ill check it out, and give you an answer All that being said, i checked out having a tank being made at a cost between 600 and 900, i opted for a new tank and pump in the range of 300, trying to keep the cost down somewhat
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-19-2013 at 12:19 PM. |
#2038 |
Re: PO has me PO'd
Thanks Dale, just got the parts, they look 100% better then mine
![]() A liilte soap and water then a coat of rust converter, and paint. These tank spacers should be good as new Thanks again....
#2039 |
Re: PO has me PO'd
![]() 20130720_190756 by jarosaj, on Flickr Happier than a camel on wednesday (hump day) May be the last of my rust....what a differance between parts from az. and pa. Thanks Dale
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-20-2013 at 10:06 PM. |
#2040 |
Re: PO has me PO'd
![]() 20130720_184933 by jarosaj, on Flickr Had time to work on the retaining ring. Screwed the plate to some wood, so wouldnt cut into my drillpress base. Used a 3 1/2" holesaw ![]() 20130720_190959 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-21-2013 at 09:01 AM. |
#2041 |
Re: PO has me PO'd
Glad that they work for you! If you've sent out free parts, you just paid back a little.
#2042 |
Re: PO has me PO'd
![]() 20130721_101336 by jarosaj, on Flickr Hammer and chisel to start hole, then tin snips. After neck was off tank, blow torch and 7/16" wrench. Hold neck horizonal and let gravity help by flowing old solder away. Repop tank has smaller locating/mounting bolts, so well see how that works out
#2043 |
Re: PO has me PO'd
Ordered my injectors from fast today, 36 lb@58 psi=331.00. Still working on my order for fuel line 3/8" wall thickness. 035, 90/10 copper nickel
Went to offer up fuel tank and ran into a problem, if i put into stock location, interferance with second to last cross sill, could fix it by sectioning in a piece of flat stock in the middle for about a foot and a half....alot of work! Second option, body lift of about 1 1/2", alot of work and money! Third option, relocate tank forward about 1 1/2", required to drill 6 holes, and maybe buy a new fuel filler hose. I think i will opt for 3, but everytime i think of drilling large holes, tom vogel comes to mind with a broken wrist. So, when i use my 3/4" chuck drill ill use the handle adapter and hope i can control the torque...if not the build will halt for awhile, and i will utter several curse words. Man that has got to be painful! Cant think of any options short of renting a magnetic base drill Recieved the fuel pump connecter from vette works out in washington state. Only need two leads 12v, and ground, other two will be deleted, they are for the sending unit, and i am using the oem sending unit that came with the tank Gotta take the connecter apart, and check what pins they use, i want to get rid of any splices ![]() 20130723_135557 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-23-2013 at 02:05 PM. |
#2044 |
Re: PO has me PO'd
Hey Jim a lot of nice machine work just on that ring alone...if I may ask the dumb question whats the problem with the tank install? fuel supply and return lines, ..Also this is going to be a pressure system will an original filler neck seal enough.? Ed.
#2045 | |
Re: PO has me PO'd
The whole problem with the install is that the pump can only mount in one flat spot on the tank, so all changes have to be made to accomadate that location. The actual lines seem to be the easy part, i can rotate the pump just about 360 degrees, just not aimed at the cross sills The pump shouldnt build pressure in the tank, as it has a vent system right between the supply and return line fittings. So, there shouldnt be any pressure at the fill cap. Hope i answered your question. I dont believe there are any dumb questions on this board, if you dont know the answer, then you have to ask the question.....
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-24-2013 at 10:55 AM. |
#2046 |
Re: PO has me PO'd
I am sure You will come up with a good compromise, I put a poly tank in 15 yrs ago, it was loose side to side and I didn't like the way it fit. I added a 1/4" angle 3 x 3 x 8 on both sides and 1/4 rubber mat to cushion it. This moves the tank down 1/2" and gives a little clearance. Short stubby fuel fill on tank got a longer hose. Might be another option to consider.
#2047 | |
Re: PO has me PO'd
![]() I think the proper way to tackle this problem is going to be modiying the the second to last cross sill, so, i hope one of our arizona boys have a bed they want to chop up. Doesnt seem that the sill is in repop, i think it is blazer/jimmy specific
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-25-2013 at 12:21 PM. |
#2048 |
Re: PO has me PO'd
![]() 20130730_114138 by jarosaj, on Flickr Got a couple minutes to work on the retaining ring, now i can just use a transfer punch to referance my holes for the nutserts in the tank. Probably using 6 to mount it up Still working on the fuel injectors, seems they are more costly then originally planned. Sent the original injectors back to fast Not sure of these quick connects, reading some bad things
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-30-2013 at 12:14 PM. |
#2049 |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Re: PO has me PO'd
Jim
Make sure if you are drilling the holes for nutserts you use the knurled type. If you use the smooth type on anything other than a punched hole they will eventually slip and make it so you cant get the bolt back out. Ask me how I know LOL. McMaster has both kinds. Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
#2050 | |
Re: PO has me PO'd
Just ordered my 90/10 fuel line, and 1/4" brake line
