Closed Thread
Old 10-30-2010, 02:09 PM   #2026
nlped
nlped's Avatar
Re: Finally "Silvers" build thread!! ('78 swb 2wd silverado)
Did you adjust the rear calipers? They do use the actuated style rear parking brake caliper...right? If they do, the parking brake has to be adjusted, or you will have a terrible feeling pedal. Try pinching off the "drop line" from the frame to the rearend and see if the pedal isn't better. If it gets firm, then the rear calipers still need adjustment. This was the issue I ran into with the McGaughy rear brake kit...
Hope that helps.
Ed
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 10-30-2010, 06:42 PM   #2027
menace121978
menace121978's Avatar
thanks guys! it wont be anything as incredible as v502's but it will be something! i'll wait for ya bro! i took a weeks vaca starting nov. 7th just for you!!
Ed.. i have the non parking brake calipers. they are same as the front thanks for that tip though!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline
Old 10-30-2010, 08:38 PM   #2028
JohnC
JohnC's Avatar
Hey even though it may have been inches she moved under her own power!!!!!
JohnC is offline
Old 10-30-2010, 08:40 PM   #2029
menace121978
that true John!!!! tonight i jacked up the rear and ran her through the gears and did some more brake bleeding. i'm getting real antsy now!
"Dennis the Menace"
Old 10-30-2010, 08:41 PM   #2030
JohnC
JohnC's Avatar
You're not the only one man!
JohnC is offline
Old 10-30-2010, 08:50 PM   #2031
nlped
nlped's Avatar
Oh well...I hoped it was something that easy
Carter
nlped is offline
Old 10-30-2010, 08:55 PM   #2032
menace121978
yea me too! seems like nothings been easy lately
"Dennis the Menace"
Old 10-30-2010, 09:01 PM   #2033
JohnC
JohnC's Avatar
You wouldn't enjoy it as much if it all went easy.
JohnC is offline
Old 10-31-2010, 09:33 AM   #2034
Jonboy
Slots go on anything!
So that's why all my projects go like they do.....
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline
Old 10-31-2010, 04:18 PM   #2035
nbpro
so just when are we gonna smell the sweet smell of paint in the air?
nbpro is offline
Old 10-31-2010, 10:13 PM   #2036
Jonboy
I don't know about Dennis, but I am going to tomorrow. And Tuesday, Wednesday, Thursday, and Friday, too.
Jonboy is offline
Old 10-31-2010, 11:23 PM   #2037
menace121978
glad i'm not that lucky Jon!
idk... tried to get in touch with him friday to check everything out. i haven't heard anything. must be busy huffing the fumes
"Dennis the Menace"
Old 10-31-2010, 11:33 PM   #2038
nbpro
yeah we were gonna smell paint next week, until some dipsh*t came through the parking lot slinging mud and gravel. Got little dings I gotta fix all on the truck now. back when i did bodywork when I was young paint smells is the reason I quit. Couldnt stand it. had a grandfather and two uncles affected by paint fumes. maybe it's time like they do on tv. if you can't get the job done in time, time for a new painter.
nbpro is offline
Old 11-01-2010, 12:06 AM   #2039
Jonboy
I did just the opposite. I like the fumes. When I figured out you could get a buzz and get paid, I was hooked. That was over 20 years ago now. Every so often I will catch a whiff of something that smells like old school catalyzed enamel, and it will take me back a little bit. Now I just sit in an office on the other side of the wall from the fumes.
Jonboy is offline
Old 11-01-2010, 12:11 AM   #2040
nbpro
oh i had friends growing up that used to do the kmart gold thing. you know, a rag and a bread sack, and hallucinate their blank off. I tried it a couple of times. but there were some things that i liked better as i was sitting there on that sack of seeds
nbpro is offline
Old 11-01-2010, 12:05 PM   #2041
68 TT
Still plays with trucks
68 TT's Avatar
well not much of a picture update but i did manage to get the stainless brake lines installed and i got the brakes bled... sorta. spent 5-6 hours bleeding the damn things yesterday. tried every trick i know. even used the vacuum pump. there is still some air in the lines but i do have a pedal though! i also fired her up and put er in reverse and then drive! hopefully next weekend i'll have the battery tray from the painter so i can mount the battery and maybe roll her down the street.
I have never had much success with a hand vacuum pump on new setups with lots of air in the system.
Have you tried a pressure pot approach yet? I built my own after seeing a mechanic friends setup. Pretty simple and it works great. Pressurize a container with brake fluid in it and feed the pressurized fluid into the master cylinder. Clamp a plate to the top of the MC and put a hose barb fitting into the plate. Connect the tank to the plate with some hose coming out of the bottom of the pressurized fluid container.
It won't take much pressure at all, maybe 10 psi at the most. Start low and wrap the MC with rags so if the plate leaks you won't get fluid everywhere and be ready to shut off the air supply to the pressure tank in a hurry. I put a ball valve on mine and use it to control the air flow into the pressure tank.
I have seen a different approach to this method of actually feeding the pressurized fluid through each brake bleeder and it pushes the air out the MC. Seems like a good idea but I have never tried it.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline
Old 11-01-2010, 09:18 PM   #2042
bluex
bluex's Avatar
http://www.summitracing.com/parts/PSL-2004/
You need one of those. I'm working on a '97 firebird to replace my 07 as my DD. I had to put a engine in it (3.8l) and during that the front brakes leaked all the fluid out. I picked that bleeder up and in 5 pumps per side all the air was out and the pedal is nice and firm. I havent drove the car yet, but it feels good in the garage. Really beats the old pumping the brakes method.
bluex is offline
Old 11-01-2010, 10:00 PM   #2043
3r!c84
Badass
3r!c84's Avatar
is my computer broken or somthing. 2 pages of NO pictures ! tisk tisk
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline
Old 11-01-2010, 10:03 PM   #2044
menace121978
i stripped the caliper where the brake line bolts on tonight!!!!!!!! i'm gonna need more than the pump now. pos calipers! the only thing that saved my sanity tonight was Jeff calling me and letting me know the gauge mounting brackets are done so the cluster, bezel, and gauges will all be in soon! thank you Jeff!!
"Dennis the Menace"
Old 11-01-2010, 10:06 PM   #2045
bigblock73
yeller
bigblock73's Avatar
No problem Dennis. I have had plenty of those days/moments myself!
bigblock73 is offline
Old 11-01-2010, 11:26 PM   #2046
menace121978
i'm going to be forced into getting the wilwood D52 calipers now... no other choice right guys!? now i'm just wondering if the prop. valve i have is going to work. its supposedly for a disc/disc or disc/drum set-up. i gotta go back and do some more reading. i also need to think of a way to milk some overtime at work
"Dennis the Menace"
Old 11-02-2010, 11:27 AM   #2047
nlped
nlped's Avatar
Haha... Yep, you need the Wilwood D52's!!!
Carter
nlped is offline
Old 11-02-2010, 12:43 PM   #2048
6772owner
Gearhead
6772owner's Avatar
I agree, you cant really go "overkill" on brakes, safety is paramount!
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline
Old 11-04-2010, 02:28 AM   #2049
81C10LS3
81C10LS3's Avatar
Dennis,
I just read this ENTIRE thread and I must say it has inspired me more than words can say.
It's nice to see such attention to detail and the photos are awesome. I'm doing a very similar swap in an 81. 6.2LS3/6L80. It's in the beginning stages and I will be using your thread as a guide. I have bookmarked it "The BEST build thread yet" in my favorites.
Congratulations on getting this far on your project, especially since the truck has so much history within your family. I can't wait to see the final product.
I'm sure i'll have a few questions for you.
Again, congrats man...
Justin
Here's mine.....
81C10LS3 is offline
Old 11-04-2010, 07:34 PM   #2050
menace121978
your post made my day buddy!!! thank you for the kind words!!
i have a HUGE update finally!!!! today i was lucky enough to meet a local guy that is a dealer for WILWOOD!! he's the top seller in the area now and he got me a screaming deal on the D52 calipers front and rear in the newly released BLACK!!!!!! i am stoked!!!! just had to spend a day of shopping with the wife and show her Ed's post that i had to have them! and promise to water the new money tree i just bought for her!!! i'm happy again they should be here monday! btw the super secret price book he had came to $700 with tax, shipping and everything. and fully loaded with the new wilwood b10 pads
"Dennis the Menace"
Closed Thread
