Closed Thread
Old 01-23-2016, 09:31 PM   #2026
LT1 Burb
LT1 Burb's Avatar
Re: What did you do to your truck today part III
On my second round of block sanding.
LT1 Burb is offline
Old 01-23-2016, 09:34 PM   #2027
Backpayne
Put seatbelts in.
Also, since I've only had the pickup I checked the spark plugs. They were at 0.30! Yikes!
Backpayne is offline
Old 01-23-2016, 09:40 PM   #2028
forestb
forestb's Avatar
Visited my truck at the paint shop today and saw my new white interior.
forestb is offline
Old 01-24-2016, 12:28 AM   #2029
AngryPirate
AngryPirate's Avatar
that's gorgeous.
AngryPirate is offline
Old 01-24-2016, 12:30 AM   #2030
forestb
forestb's Avatar
forestb is offline
Old 01-26-2016, 05:45 PM   #2031
TJ's Chevy
TJ's Chevy's Avatar
ForestB: That looks NICE! Can we put that cab on My frame? lol!
Today I pulled my rolling chassis out of the shop and washed it down. Nice to get that inch of dust off of there. Also installed my steering box.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 01-26-2016, 05:50 PM   #2032
SnS C10
SnS C10's Avatar
Made a couple of firewall heater block off panels and attached them. I also machined an aluminum bracket for my new power brake booster conversion
SnS C10 is offline
Old 01-26-2016, 06:00 PM   #2033
forestb
forestb's Avatar
Sorry already put it on mine.
forestb is offline
Old 01-26-2016, 08:16 PM   #2034
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Took Clyde out for a drive yesterday and then changed his oil....now he is good till July!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline
Old 01-26-2016, 09:34 PM   #2035
TJ's Chevy
TJ's Chevy's Avatar
AW MAN! lol! Looks good! Love that color!
Old 01-26-2016, 10:44 PM   #2036
Sik5chevy
Man good work on the booster bracket.
Sik5chevy is offline
Old 01-29-2016, 01:45 AM   #2037
Grizz1963
Grizz1963's Avatar
Made up new brake lines for the truck.
Well, after much faffing about and trying all sorts of ways (about 20 samples) to get this to work, the flares came together.
The result left me happy for sure.
This nut fits the master cylinder serving the rear brake line and was the only one I could not find a replacement for, fortunately it was in really good condition and could get reused.
Next up was threading the original through the chassis as a sample of the bends.
The original pipe had a join around about at the rear of the cab. I chose to delete it, as Martin and I worked out that it must have been the option of the long and short Chevy bodies where the factory could screw on the rear half depending on what they built.
I had to put a bend in it where it joins the flexi hose at the chassis to feed over the rear axle, at which point for some reason the pipes change to a 3/16" size from the 1/4" the rest of the system employs.
No idea why the difference.
Just finger tightened, this allowed me to bend the line to the various contours coming to the front.
Up front I used a straight joiner and a bend to join to the pipe that runs over the cross member or under the sump.
The other thing I did was to keep an extra 500mm to create a spiral once I do the front brake lines as well.
Tomorrow I will spend the day out with Nicola.
Hope to finish the pipes over the weekend.]
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 01-29-2016, 03:58 AM   #2038
schpeen
schpeen's Avatar
EFI is in
schpeen is offline
Old 01-29-2016, 04:01 AM   #2039
schpeen
schpeen's Avatar
Originally Posted by schpeen View Post
EFI is in
schpeen is offline
Old 01-29-2016, 04:02 AM   #2040
schpeen
schpeen's Avatar
schpeen is offline
Old 01-29-2016, 08:29 AM   #2041
chevy2tom
chevy2tom's Avatar
Getting ready to put it back in
chevy2tom is offline
Old 01-29-2016, 03:06 PM   #2042
forestb
forestb's Avatar
What made you go with FiTech (a brand I have never heard of, which is not saying much) as apposed to Edelbrock or Holley?
forestb is offline
Old 01-29-2016, 05:02 PM   #2043
jb9281
jb9281's Avatar
How good does it run? How hard to install? I have been looking at them on Jegs and waiting for someone else to review them.
jb9281 is offline
Old 01-29-2016, 09:21 PM   #2044
canadian_diesel1964
canadian_diesel1964 is offline
Old 01-29-2016, 09:23 PM   #2045
canadian_diesel1964
I got the T5 cleaned up...bolted up ...painted and new boot, fork painted and new ball stud...going to be nice mated up....
Old 01-29-2016, 09:25 PM   #2046
canadian_diesel1964
Engine....$175 invested that's about 130 USD!
Old 01-29-2016, 10:54 PM   #2047
ChrisDollins
ChrisDollins's Avatar
Gorgeous!! Can't wait to see it with the carbs on it.
Chris
ChrisDollins is offline
Old 01-29-2016, 11:05 PM   #2048
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
EFI is in
Keep us updated with your experience:
http://67-72chevytrucks.com/vboard/s...d.php?t=686601
66 C20 Service Truck:
LostMy65 is offline
Old 01-30-2016, 03:39 PM   #2049
Grizz1963
Grizz1963's Avatar
Had a good friend over till after 2pm today. So I went back down to the garage to make up the 1/4" front brake pipes and then the 3/16" rear pieces.
The more you do, the easier it gets.
Then had to start the bending, and copying the old brake pipes.
I am very pleased with the way it has come out.
Looking down from the top, so much better than the units removed.
Outside the cold and darkness around the garage door side chased me indoors, so I will finish off the front lines in the morning.
Old 01-30-2016, 05:01 PM   #2050
You are doing a great job Rian. Very nice on the bending!
Palf70Step is offline
Closed Thread
