01-03-2011, 11:56 PM | #2051 |
HOW long until spring??
Re: Daverods project 66
Dave there is tons of info in the FAQ section on disc brake swaps.. I am using 6 lugs on '72 spindle/rotors
When you come to Motorfest in July I can find you some 1/2 ton stuff around here -- Rock On !!!- Bubba
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
01-04-2011, 12:06 AM | #2052 |
SSN 706
Ah, I'm thinking I need some different headers also. Mine already almost touch the ground. At 2 1/2 more there won't be much left. You changed your whole cross member. I'm keeping my orginal cross.
01-04-2011, 12:25 AM | #2053 |
The 60-66 GMC/Pontiac guy....
The (a) proportioning valve must be installed since there is no valve originally.
In fact, disks require replacement and or re-routing of most of your brake lines. The early A arms will take the later disk spindals... In fact, the A arms are the same on half tons from 63 and at least till 73 and I have seen 79 arms bolt right in place of the 63.... NAPA shows the A arm shafts having the same stock number from 63 thru 81. Doing a brake conversion is 10 times more easy with the availability of a donor truck to pull all the parts from and 10 times cheaper too..
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
01-04-2011, 12:44 AM | #2054 |
the donor truck would have all the brakelines and brackets needed too
if you have the space to store it the time to rip them apart and the knowledge of what is worth money theres money to be made out of donortrucks
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
01-04-2011, 03:14 PM | #2055 |
Member of the longbed union.
You can use your stock arms and get disc brakes. You will have to replace the ball joints and get either 71-72, or 73-87 spindles. Make sure that the spindle shaft is 1.25" not the 1". Then you will have to use 4x4 rotors, which is 6 lug. Make sure that you replace the drag link as well to the same year that you use.
It's better to use 73-87 stuff since the parts are cheaper.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 Last edited by ruffrida2005; 01-04-2011 at 03:15 PM. |
01-04-2011, 03:40 PM | #2056 |
SSN 706
The kit is starting to sound better. I did use a parts truck to do my 66 disks. Had to buy new calipers and get the rotors turned also new bearings, seals and hoses. Paid 300 for the truck plus the time to take it all apart and clean it. Still thinking about it.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 01-04-2011 at 03:44 PM. |
01-04-2011, 06:55 PM | #2057 |
I had a kit from perfromanceonline.com I ended up selling it for $500 shipped
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
01-04-2011, 07:17 PM | #2058 |
1965 Chevy C10, 2005 4.8L/4l60
I would look at ECE and not buy from CPP, I haven't had specific issue with CPP but many on the board has, I saw a recent issue in the review area about them.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-04-2011, 07:51 PM | #2059 | |
SSN 706
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 01-04-2011 at 07:53 PM. |
01-05-2011, 12:02 AM | #2060 |
SSN 706
Thanks Bubba I knew I saw it somewhere Just took me awhile to find it again. Motorfest You going to enter your truck?
01-05-2011, 12:08 AM | #2061 |
Hey man do you still have the dash that you put the impala dash in? I got guy wanting to buy one!
01-05-2011, 12:19 AM | #2062 |
SSN 706
I cut it up for the metal contours. I have half.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 01-05-2011 at 12:19 AM. |
01-05-2011, 12:33 AM | #2063 | |
I bought a kit from CPP for a deal.. It was a E-bay auction for the package of 6 lug rotors and GM calipers with stock GM 71-72 spindles. It was a whole bunch less than catalog price.. Now I know some folks have an issue with them, But I decided that i would take a chance. Have bouht several thing with no problems. Ebay is always supposed to back up the buyer if an issue occurs.. Hows that compressor running ?? Mine would not turn over and smokes the belts in the cold.. I drained the oil and put in 5W30 motor oil just to get things working in the cold!! HOW LONG TILL SPRING???
01-05-2011, 12:42 AM | #2064 |
do you still have the guage cluster area and glove box area? That's all he needs.
01-05-2011, 03:28 AM | #2065 | |
it works like a freezer when you compress you release the warmth stored in the gas when you expand the gasses it pulls heat out of its suroundings , theres even been an american submarine once that sunk and imploded during it maiden voyage because of this , the pipes moving the air frose up and they couldnt blow out the balasttanks to surface
01-05-2011, 11:01 AM | #2066 |
SSN 706
I think I have the guage area/ box area i'll check at lunch.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 01-05-2011 at 11:01 AM. |
01-05-2011, 11:04 AM | #2067 |
SSN 706
My compressor is in a heated garage. I keep it about 45 all the time. No problems so far. Your addicted to ebay.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 01-05-2011 at 11:07 AM. |
01-05-2011, 03:23 PM | #2068 |
let me know if ya got it so I can let the guy know.
01-05-2011, 04:34 PM | #2069 |
SSN 706
All I got left is this.
First time I ever hung my sled from a tree.The tree and his buddy did'nt make it. http://s697.photobucket.com/albums/v...idoveredge.mp4
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 01-05-2011 at 08:51 PM. |
01-06-2011, 12:20 AM | #2070 |
Daverod, I can't believe the work that you have gotten done. Man I'm jelaous of the heated shop. So whats all the crap about Rexburg?: Hey keep up the good work. Your the inspiration man
01-06-2011, 12:23 AM | #2071 |
SSN 706
Judges up there suck.edit.edit. Did I really say that? oh well.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 01-06-2011 at 12:25 AM. |
01-06-2011, 12:25 AM | #2072 |
You are O so right. I had to go before one on a custody case this summer. No Fun!!!
01-06-2011, 12:25 AM | #2073 |
he decided he wants a whole dash now. It's going in a 86 CC truck.
01-06-2011, 12:28 AM | #2074 |
SSN 706
That will be cool.59 impala would be cool er.er.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 01-06-2011 at 12:28 AM. |
01-06-2011, 08:06 PM | #2075 |
SSN 706
Gotta love life.mi mal
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 01-06-2011 at 08:11 PM. |
