Old 01-19-2022, 11:38 AM   #2051
oldman3
oldman3's Avatar
Re: My 50 roadster pickup build
Jim, while I don't run a rack & pinion, we used a pressure reducing kit on my buddy's Fairmont swap project. The LS pump needs to be turned down so it doesn't blow the seals out. I'm not familiar with the valve you mentioned. Something like this:
https://www.scramspeed.com/products/...ction-kit.html
Originally Posted by youngrodder View Post
Glad you had an easy first drive other than the shifting set back.
I used a Borgeson pressure reducer in mine.
https://www.summitracing.com/parts/b...SABEgJ5IvD_BwE
With this power steering reducer, it contains 5 different shim/washers each one reducing the power.
No Shims 1350PSI
1 Shim 1200PSI
2 Shims 1100PSI
3 Shims 1000PSI
4 Shims 850PSI
5 Shims 700PSI
I'm thinking you could fine tune it to your liking. I forget how many shims I used. Thinking 3 or 4 but its been a minute since I added it. At only $16 bucks and some of your time it might be worth a try.
Marc
Thanks Outlaw and Marc, that's what I need. Ordered the Borgeson unit. Will let you know, when I get it installed...Jim
oldman3 is offline   Reply With Quote
Old 01-25-2022, 10:49 AM   #2052
oldman3
oldman3's Avatar
Update on power steering. I talked with Borgeson about the flow valve I had and number of shims needed. Didn't know anything about the flow valve, but suggested to remove it, install stock fitting and 4 shims. So that's what we did. Hard to see it pic, but the flow valves hole is about half the size of stock one...Jim
Old 01-25-2022, 10:59 AM   #2053
oldman3
oldman3's Avatar
After changing everything out, I took it for a drive, like the feel better that before. I the way back to the house, I heard the squealing from the engine. Mark and I checked it out, thought it was the belt, but after further checking it was the water pump. New pump, but something went wrong. So tear apart the front, remove radiator, etc. It's 95 percent back together now, will finish up the morning, and will let you know.
Pic 1 old pump removed
Pic 2 new pump all painted and ready to install.
Pic 3 and 4 not good pic, but back together, ready to put on cover and fill up the radiator.
stay tuned...Jim
Old 01-25-2022, 11:06 AM   #2054
OutlawDrifter
Glad you got the power steering on the right track!
Bummer about the new water pump though.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 01-25-2022, 12:18 PM   #2055
youngrodder
youngrodder's Avatar
Glad the power steering pressure reducer worked to your liking. Now that you mention it I think I used 4 as well. I just followed the directions. Seems like I had one shim left in the bag.
Good to find a failing water pump on your terms. Nice catch.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-25-2022, 04:00 PM   #2056
joedoh
joedoh's Avatar
seems like its always something, glad you got it figured out though!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 01-25-2022, 04:27 PM   #2057
8man
Hope you slayed the last gremlin and can now drive and enjoy!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 01-25-2022, 08:41 PM   #2058
oldman3
oldman3's Avatar
Marc
Thanks guys...Jim
Old 01-25-2022, 08:46 PM   #2059
oldman3
oldman3's Avatar
Update from yesterday. Got everything buttoned up, anti-freeze in radiator. No squeal from engine area. Took it down the road for about 5 miles. Steering is tighter that before, but not as much with the old system. Maybe 5 shims would have worked, but not going to change. Plans are tomorrow for me to take it on about a 50 to 60 mile jog, and see how it runs. Still need to get Brendon to hook up lap-top and fine tune things. Will let you know tomorrow...Jim
Old 01-26-2022, 08:51 AM   #2060
Indian113
Indian113's Avatar
Try your best to not to pull a muscle around your jaw from smiling all day! Have Fun Jim and good luck on your shake down cruise.
Indian113 is offline   Reply With Quote
Old 01-26-2022, 10:31 AM   #2061
youngrodder
Great off season upgrades Jim.....Now the fun part......Driving it.
Marc
Old 01-26-2022, 10:59 AM   #2062
oldman3
oldman3's Avatar
Marc
Thanks Ray and Marc, will post up later on drive...Jim
Old 01-27-2022, 06:40 PM   #2063
oldman3
oldman3's Avatar
Where do I start, if it wasn't for bad luck I wouldn't have any luck
Ok Wednesday 1/26 started to take my shake-down run. Went about 20 miles or so, heard a noise and noticed my volt gauge was dropping down, lower and lower, turned around and headed home. Needless to say with low voltage, thinks started going wrong, temp went up (no fan), etc. Was about 4 miles from home. Called Mark, he came with jumper cables, let engine cool down, then made a mad dash to the house.
Pull radiator, etc apart again. Removed thermostat, and alternator. Went to parts store, alternator bad, only had about 80 miles on it, didn't want to chance the thermostat going bad with hight temps around 240. Bought a new alternator $$ and thermostat. Came back and got alternator ready for paint, installed thermostat, etc.
Today Thursday 1/27 Mark reinstalled everything, along with new anti-freeze, etc. Took a short drive and everything seemed good. After lunch I took off again, this time everything went good, about a 90 mile round trip.
Next week Brendon will hook-up laptop and find tune everything.
Here's a few pics.
Pic 1. This was Wednesday running along about 70 mph everything good
Pic 2. Looking down the road.
Pic 3. Torn apart again.
Pic 4. New alternator painted
No pics today, forgot the camera.
A big THANK YOU to my son Mark for all his hard work..Jim
Old 01-27-2022, 07:39 PM   #2064
lower50's
lower50's's Avatar
OH no. It never fails though the one part you should not have a problem with. At least you did get home without a tow, and everything else is working great.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-28-2022, 12:29 AM   #2065
oldman3
oldman3's Avatar
Hey Bob, what makes me mad, is all the parts are new, from good sources, I guess someone has to get the bad ones...Jim
Old 01-28-2022, 01:35 AM   #2066
mongocanfly
mongocanfly's Avatar
Had to catch up on your project ..hopefully you got the bugs worked out..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-28-2022, 10:10 AM   #2067
Tempest67
Tempest67's Avatar
it is very frustrating when new parts are faulty.
Glad to hear 'Icon' is back on the road and doing well. enjoy.
No test drives up here til' April
Tempest67 is offline   Reply With Quote
Old 01-28-2022, 10:17 AM   #2068
8man
I hope all the bugs are gone and that you get to drive the tires off of it.
Also, please tell me what brand washer that is that doubles as a paint booth.
8man-aka Robert
Old 01-28-2022, 10:22 AM   #2069
youngrodder
Isn't hot rodding fun??? You guys are probably getting as efficient as a NASCAR pit crew disassembling that front end.
Enjoy test drive #3....You'll get it
Marc
Old 01-28-2022, 10:46 AM   #2070
6DoF
6DoF's Avatar
i had actually never gone back thru the whole build on this truck, holy balls! i'm guna have to take more time to go page by page at some point.
6DoF is offline   Reply With Quote
Old 01-28-2022, 11:56 AM   #2071
oldman3
oldman3's Avatar
Thanks Greg, I think they are, yesterdays drive was good...Jim
Tempest thanks, I lived in Michigan for 30 yrs, so I know how it is to wait for good weather...Jim
Marc
Thanks Marc, when Mark saw you post he got a chuckle, I think we finally got it whipped...Jim
Robert, wish it could, brought it in overnight to dry...Jim
Thank you, yes it's been through several upgrades over the years...Jim
Old 01-28-2022, 12:20 PM   #2072
joedoh
joedoh's Avatar
wow thats a hard luck story if i heard one. glad its all fixed, I gotta tell ya I laughed at the alternator on the washer picture, one of the work at home things that I appreciate seeing!
i bet all the people you passed on your 90 mile trip were wondering who the nut with the convertible in january was.
Old 01-28-2022, 09:28 PM   #2073
oldman3
oldman3's Avatar
Thanks Russ, I think the high yesterday was about 37 degrees, heater worked great...Jim
Old 01-29-2022, 09:37 AM   #2074
Jason 56
Congrats on finishing the swap. It’s amazing the gremlins you find when doing something like this. No question that the aftermarket parts available today don’t live up to a high standard. Enjoy cruising with the modern engine!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 01-29-2022, 11:44 AM   #2075
oldman3
oldman3's Avatar
Thank you...Jim
