Closed Thread
Old 02-20-2016, 06:14 PM   #2076
OldChevy61
OldChevy61's Avatar
Re: What did you do to your truck today part III
After a lot of blasting, sanding , tearing apart, sprayed two coats of epoxy and two coats of urethane primer on the cab today.
OldChevy61 is offline
Old 02-20-2016, 07:28 PM   #2077
OldChevy61
OldChevy61's Avatar
Urethane.
Old 02-21-2016, 06:56 PM   #2078
jbgroby
jbgroby's Avatar
Got the bed flipped right and starting the wood install over the next week.
jbgroby is offline
Old 02-21-2016, 07:27 PM   #2079
OldChevy61
OldChevy61's Avatar
Got the front brake lines fabbed up and installed.
Old 02-21-2016, 10:32 PM   #2080
jbgroby
jbgroby's Avatar
Got the tub in and called it a night.
jbgroby is offline
Old 02-22-2016, 11:26 AM   #2081
edisonfire
edisonfire's Avatar
I finally got my hood hinges installed and the hood on!
edisonfire is offline
Old 02-22-2016, 04:46 PM   #2082
TJ's Chevy
TJ's Chevy's Avatar
I installed my new tailgate! Finally GMC in all 4 corners.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 02-22-2016, 08:00 PM   #2083
60chevyjim
60chevyjim's Avatar
I tried this aqua color today to see if I like it better than the red or flat black ?
im going to strip all the paint off the truck when I do all the body work .
60chevyjim is offline
Old 02-22-2016, 10:31 PM   #2084
Tarc
Made a throttle rod and installed a radiator overflow.
Tarc is offline
Old 02-22-2016, 10:45 PM   #2085
jbgroby
jbgroby's Avatar
Got the first placeof the boards mounted
jbgroby is offline
Old 02-23-2016, 09:04 PM   #2086
65Gregg
65Gregg's Avatar
I got my new shocks installed and started on the front shock relocation mounts.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 02-23-2016, 09:12 PM   #2087
TJ's Chevy
TJ's Chevy's Avatar
Nice!!!
Old 02-23-2016, 09:13 PM   #2088
Lugnutz65
Lugnutz65's Avatar
I media blasted and then applied primer to some engine parts. Not very exciting but it is progress.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 02-25-2016, 03:20 AM   #2089
Grizz1963
Grizz1963's Avatar
Last weekend.......
Split motor and trains.
Useful tool...... Keeping things together.
Yup.... Four bolt.
Camel hump heads, missing most valve stem seals, one valve damaged and a spring broken.
Still trying to figure which parts to replace, or just how much new stuff to add.
Needs a clean and paint as well.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 02-26-2016, 12:07 AM   #2090
Chevy Fleetside
Chevy Fleetside's Avatar
I made room in the garage so I could remove the windshield and change the gasket. It had a split at the bottom and water would come into the cab when driving in the rain. Here they are a nestled in.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 02-26-2016, 12:12 AM   #2091
Chevy Fleetside
First picture shows how the old owner used roofing tar to patch a hole or something. When it rained the water would come in and spill on the dash and the floor. Surprised there isn't more rust. You can also see the split at the bottom. The gasket also melted back into petroleum form which also melted onto the dash and I think it protected it from the water and it was rust free so I had to clean all that up and after doing so I sanded some of the surface rust off and coated it with Duplicolor Truck Bed liner.
Old 02-26-2016, 10:54 AM   #2092
Chevy Fleetside
I also took my automatic steering column apart and repainted it. Don't know if I will stick with the color or not.
Old 02-26-2016, 07:19 PM   #2093
Chevy Fleetside
I took my wheel off to adjust my front brakes and after about 5 blocks of driving it is pulling right again.
Time for disc.
Old 02-27-2016, 10:58 AM   #2094
jbgroby
jbgroby's Avatar
Got more wood........😚
jbgroby is offline
Old 02-27-2016, 11:01 AM   #2095
Lugnutz65
Lugnutz65's Avatar
Time for disc.
I'm thinking you have a bad brake cylinder, weak brake springs or both. Just me thinking. I'm no expert.
Old 02-27-2016, 11:41 AM   #2096
Chevy Fleetside
I threw new wheel cylinders in not to long ago. I didn't change the springs only because I didn't plan on keeping the drum brakes for to long. The only reason I have not done the brakes yet is I am contemplating a 2" drop or keeping it stock height.
Old 02-27-2016, 09:01 PM   #2097
Grizz1963
Grizz1963's Avatar
Well, the VHT Chevy orange engine paint went on without a hitch.
Good preparation, cleaning three times over and some head in the steel meant good adhesion.
Rattle cans work well if you,are patient and keep the distance equal on every pass.
Result, three coats on flat surfaces, more on the bends.
Masked up and cleaned block painted too.
Very pleased with the results of today's work.
Almost 01.00 now, so bed time I would think.
Final pic just for Greg "Bomp" in Kaiser, Oregon........... There you go my young friend.
Old 02-27-2016, 09:33 PM   #2098
jbgroby
jbgroby's Avatar
All the boards in to dry fit so we can mark the holes for drilling. I think I see light at the end of the tunnel...
jbgroby is offline
Old 02-27-2016, 09:56 PM   #2099
urmyboyblue
I have been making new dash and console panels for my 65 C10- it has a custom dash thanks to my efforts years ago to lighten the truck up for bracket racing. I will post a picture after the dash is back together. Today I primed the panels. Monday I hope to paint them satin black.
I also painted the upper A arms for my 66 C30- I pulled them and cleaned them up back on New Years. I also started disassembly of the LWB fleetside bed I bought for the C30.
urmyboyblue is offline
Old 02-28-2016, 01:14 AM   #2100
allchevy58
allchevy58's Avatar
Like it, looking good!
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline
Closed Thread
