02-06-2024, 11:01 AM | #20976 |
Post Whore
Re: Facebook Marketplace finds
https://www.facebook.com/marketplace...7-8f8353353e6e 1968 Chevrolet suburban 3 door
$29,500 Listed a week ago in Salt Lick, KY |
02-06-2024, 11:18 AM | #20977 |
Post Whore
1972 Chevrolet 1500 regular cab Long Bed
$35,000 Listed 2 weeks ago in Dagsboro, DE https://www.facebook.com/marketplace...3-e1a93ef9e3c2 |
02-06-2024, 11:19 AM | #20978 |
Post Whore
https://www.facebook.com/marketplace...3-e1a93ef9e3c2 https://www.facebook.com/marketplace...3-e1a93ef9e3c2 1972 Chevrolet k10 4x4
$50,000 Listed 2 days ago in Cedartown, GA |
02-06-2024, 11:22 AM | #20979 |
Post Whore
https://www.facebook.com/marketplace...3-e1a93ef9e3c2 1972 Chevrolet 2500 regular cab
$200 Listed 12 weeks ago in Middletown, OH |
02-06-2024, 11:40 AM | #20980 |
Post Whore
https://www.facebook.com/marketplace...type=top_picks 1970 Chevrolet 1500 regular cab
$5,000 Listed 7 weeks ago in Earlysville, VA |
02-06-2024, 11:43 AM | #20981 |
Post Whore
https://www.facebook.com/marketplace...type=top_picks 1972 Chevrolet c10 Step side
$28,000 Listed 6 days ago in Bristow, VA |
02-06-2024, 12:20 PM | #20982 |
Post Whore
https://www.facebook.com/marketplace...3-ea3f3f12294b 1969 Chevrolet 3500 hd regular cab
$8,500 Listed 4 days ago in Miamisburg, OH |
02-06-2024, 01:14 PM | #20983 |
newport in not that far away from me about an hour
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 Chevy Trucks the longest lasting most dependable trucks on the road |
02-06-2024, 08:15 PM | #20984 |
Post Whore
02-06-2024, 08:20 PM | #20985 |
Post Whore
https://www.facebook.com/marketplace...7-af8f6ffa6de6 1972 Chevrolet 3500 hd regular cab & chassis
$6,500 Listed a week ago in Stanwood, WA |
02-06-2024, 08:27 PM | #20986 |
Post Whore
https://www.facebook.com/marketplace...7-af8f6ffa6de6 1970 Chevrolet c10 Custom
$11,500 Listed 2 weeks ago in Vacaville, CA |
02-06-2024, 08:28 PM | #20987 |
Post Whore
https://www.facebook.com/marketplace...3-e85e691b8133 1969 Chevrolet classic
$18 Listed 2 days ago in Marysville, WA About This Vehicle Driven 18,288 miles Manual transmission Exterior color: Black · Interior color: Seller's Description Runs and drive perfect. Some rust on the inside. A lot of new parts.. 1969 c10 california bed 350 4speed Engine was rebuilt New brake lines New wheels / tires Clean title $18,000 No trades Marysville, WA Location is approximate Seller Information Ahudett Farias Joined Facebook in 2013 Sponsored Send seller a message |
02-06-2024, 08:30 PM | #20988 |
Post Whore
1968 Chevrolet C10 2WD SWB Pickup (Project)
$8,500 Listed 20 hours ago in Kennewick, WA Details Condition Used - Fair For sale is a shortened 2wd 1968 Chevrolet C10 pickup with a clean Washington title. Cab has typical rust in corners and rockers. * There is currently no motor/transmission installed (originally a 292 inline 6 w/ granny 4spd. – Muncie SM465 – no longer have). I have a 5.3L (LM7 - 2006) and 4l65E (2007 - RWD) transmission sourced – they go with the truck Also included is the complete wiring harness, accessory drives, airbox, exhaust manifolds, and fan shroud with cooling fans from the 2006 Chevrolet 1500. Currently installed on the truck are, but not limited to: CCP Grand Slam suspension kit (#6770GSK-6D) Disk brakes front (CPP 12”) and rear (11.5” Bro-Speed) [6-lug] CCP Power Steering box / Power steering pump – NIB (#CPP6772PSK-S) CCP Drop Center Drive Loop (crossmember) (#6372LDL-S) Performance Online Extreme Performance tubular trailing arms (#TTA6072) CPP adjustable trac-bar (#6572DATB) Rebuilt 12 Bolt Posi-traction rearend with new: Eaton Detroit Locker differential Moser axles (#A3065GMTK) USA Standard 4.11 gears (#ZG GM12T-411T) CPP Rear shock relocation kit (#6372SRK) Performance Online 19 gal. under-bed aluminum fuel tank w/sending unit, fuel filler, and hose (side-fill) [#AGT6372-SK] - w/ CPP return line fitting New In Box parts include, but not limited to: CCP Power Steering column / column-shift – w/shift linkage kit (#TC-6772-SB, CPTSL, 6772WHP) CCP Power brake booster (#6772BB2-11) – will need an easy mod for 4 wheel disc brakes Performance Online transmission crossmember (#TCM6372) CPP C-Notch kit – bolt-in (#6372CNK) Aluminum Radiator w/ 12” fans and aluminum shroud (#SL-282A-AT-CVP + Shroud & 12” fans) Dirty Dingo LS adjustable motor mount kit With engine mounts Aluminum LS coil mounts FI Tech (#40004) remote mounted fuel injection fuel pump w/reservoir United Pacific chrome front bumper (#105671) United Pacific chrome rear bumper (#106671) Chrome bumper bolts Cab mounting kit (#CMS6772) Bed mounting kit (#110248) Speedway Motors 22-Circuit universal aftermarket wiring harness kit (#910-64022) Taillight housings (#C677207) LED reverse lights/lenses (#110200/110201) LED Taillamp inserts (#LED72FL) LED Side-marker lights – amber (#SMLD72A) LED Side-marker lights – red (#SMLD72R) LED Dome light – chrome (#DLH72EU) LED Electronic Flasher Original* parts included: Steering wheel Gauge cluster Dash pad (blue) Aftermarket carpet kit - black (used) Kennewick, WA Location is approximate https://www.facebook.com/marketplace...3-e85e691b8133 |
02-06-2024, 08:33 PM | #20989 |
Post Whore
https://www.facebook.com/marketplace...d-0d2a61ccdf20 1972 GMC k15
$2,850 Listed 2 weeks ago in Chehalis, WA |
02-06-2024, 08:34 PM | #20990 |
Post Whore
02-06-2024, 08:35 PM | #20991 |
Post Whore
https://www.facebook.com/marketplace...c-0a901c5a8116 1968 Chevrolet c10
$10,500 Listed 4 days ago in Seattle, WA |
02-06-2024, 08:45 PM | #20992 |
Post Whore
https://www.facebook.com/marketplace...d-87f509977eeb Blazer 72
$49,500 · In stock Listed in Las Vegas, NV |
02-06-2024, 08:48 PM | #20993 |
Post Whore
1971 c10 step side bed (bed only)
$2,500 Listed 5 days ago in Yuba City, CA https://www.facebook.com/marketplace...d-87f509977eeb |
02-07-2024, 06:43 AM | #20994 |
Post Whore
02-07-2024, 06:44 AM | #20995 |
Post Whore
02-07-2024, 06:46 AM | #20996 |
Post Whore
1972 Chevy C20 Camper Special truck
$6,250$7,000 · In stock Listed in Camano Island, WA Details Condition Used - Good I am selling my 72 C20 3/4 ton long bed Camper Special pickup truck. I was going rebuild it, I decided to put it on the market. It has rust on the body, the doors, the rocker panels and windshield channels. It has a V8 automatic 350 engine with headers unknown miles. It runs great. Rebuilt TH350 transmission and Carter carburetor. It has a new Dakota digital instrument cluster, a new Redhead steering gear box, and a mini starter, The tires have low mileage. It still needs some work, I am asking $6250 OBO. Let me know if you have any questions. Camano Island, WA Location is approximate Seller information Benjamin Pena https://www.facebook.com/marketplace...2111112l%22%7D |
02-07-2024, 06:48 AM | #20997 |
Post Whore
1968 gmc short box 4x4. V-6 4 speed. Runs and drives.
$10,000 Listed 12 hours ago in Laurel, MT Details Condition Used - Fair Original short box 4x4 https://www.facebook.com/marketplace...2111112l%22%7D |
02-07-2024, 06:48 AM | #20998 |
Post Whore
https://www.facebook.com/marketplace...2111112l%22%7D 1971 c10 shortbed
$2,000 Listed 5 weeks ago in Windsor, CA Door pickup |
02-07-2024, 06:49 AM | #20999 |
Post Whore
https://www.facebook.com/marketplace...2111112l%22%7D 1968 Chevrolet c10
$2,500 Listed 4 weeks ago in Manteca, CA |
02-07-2024, 06:50 AM | #21000 |
Post Whore
https://www.facebook.com/marketplace...2111112l%22%7D 69-72 Blazer seats
$3,000 Listed 2 days ago in Escalon, CA |
