Closed Thread
Old 11-24-2010, 06:23 PM   #2101
jbgroby
jbgroby's Avatar
Re: What did you do to your truck today?
We did the final wet sanding today of the cab. Friday morning we paint the top of the dash Charcoal on Saturday we mask and paint the interior silver fawn. Guys its getting so close I can smell it, It's only been ten years.
jbgroby is offline
Old 11-25-2010, 06:06 PM   #2102
fryer1979
Redneck Hillbilly
fryer1979's Avatar
That's really cool Lakeroadster, I've always been interested by the CAD programs. If you don't mind my asking, where did you get your cab vents from? I've read about that instal a time or two on here and would like to do that to my own truck, but have no luck finding any. I'm not even sure what to look for exactly.
fryer1979 is offline
Old 11-25-2010, 06:35 PM   #2103
rendus
rendus's Avatar
I haven't drove my truck in about a month but I've been smelling a strong turpentine odor everytime I've walked by it. Finally did some investigating last week and discovered the gas tank has started leaking again. Multiple leaks all along the bottom. I pulled it today (thank goodness there was only two gallons of gas in it) and removed all the hardware and the new fuel sending unit.
rendus is offline
Old 11-26-2010, 12:49 PM   #2104
Turkey
Turkey's Avatar
Finally got my linkage adjusted to shift nice and smooth. Took the ole lady out for ice cream.
Turkey is offline
Old 11-26-2010, 07:50 PM   #2105
jbgroby
jbgroby's Avatar
FINISHED all the wet sanding and washed the truck down for the 1K sealer prior to painting Sunday, weather turned wet ugly and cold overnight.
jbgroby is offline
Old 11-26-2010, 08:11 PM   #2106
losthope
losthope's Avatar
messed around with the 63,bolted most of the front clip on and took drivers side fender and door down to bare metal and put a coat of primer on them,i also put the wheels and tires that came with my 65 on the 63, still dont know if i want to sell it part it out or keep it yet. it needs alot of body work and i have minimal exp. but i figure i can use this to practice on tell i make up my mind . guess you got to start some where!! heres some pics
losthope is offline
Old 11-26-2010, 08:14 PM   #2107
greg65
greg65's Avatar
I might have missed it but what exterior color are you going with?
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline
Old 11-26-2010, 08:22 PM   #2108
jbgroby
jbgroby's Avatar
This two-toned combo
Olympic White over Canyon Blue Factory stock colors.
jbgroby is offline
Old 11-26-2010, 08:31 PM   #2109
greg65
greg65's Avatar
nice. Can't wait to see it in the sun light.
1965 c-10 swb
2004 tahoe
1993 mustang gt
greg65 is offline
Old 11-26-2010, 08:57 PM   #2110
jbgroby
jbgroby's Avatar
Me too!
jbgroby is offline
Old 11-26-2010, 09:54 PM   #2111
BigPhil66
BigPhil66's Avatar
Went and bought a new power steering pump to replace the salvage yard leaking one...connected it up bled the system and got the truck started for the first time in months. I am so thrilled to have power steering, I just need to put it on the ground to try it out. I need to fix my welds on the steering column because I have never welded before other than high school a long long time ago. I need to start the suspension now.
BigPhil66 is offline
Old 11-27-2010, 09:12 PM   #2112
198plus
198plus's Avatar
I mocked up an old Big Block that I had laying around.......The tubular mounts worked out fine. I used a set of BBC Hooker headers for a 69 Camaro, they fit very nice. Now I'll send the headers off and have them hot jet coated.
New Engine almost ready.....
198plus is offline
Old 11-27-2010, 11:04 PM   #2113
boat
boat's Avatar
got all the brake lines on
boat is offline
Old 11-28-2010, 02:28 AM   #2114
BigPhil66
BigPhil66's Avatar
Here are two pics and a video...the crank pully looks like it may be wobbling just a little bit. I guess I should have stood in one spot. *shrug*
Old 11-28-2010, 06:20 PM   #2115
willyp
willyp's Avatar
Chemically stripped and belt sanded the old oak bed, getting ready for stain.
The price of cool aint cheap.
willyp is offline
Old 11-28-2010, 07:26 PM   #2116
jbgroby
jbgroby's Avatar
Glad to see you were able to salvage it. saved $200 easy
jbgroby is offline
Old 11-28-2010, 07:37 PM   #2117
Cops053
Cops053's Avatar
Greased it, oil change, flushed radiator and new anti-freeze
Cops053 is offline
Old 11-28-2010, 08:03 PM   #2118
chopttop
Junior Member
chopttop's Avatar
Got the '71 in the old mans garage, up and off the tires for the winter. Got the battery charged so I can move the '70 and start on it.
'71 C10, Choptop/Lowered
'70 C30, w/24' Franklin Motor
'91 9c1 Caprice
'90 Harley FL, 127 Ultima engine w/6 speed, Blk & chrome
chopttop is offline
Old 11-28-2010, 08:34 PM   #2119
Tommy454
Tommy454's Avatar
Repaired the holes in the rear fenders, moved the lights and gave it a fresh coat of primer.
Tommy454 is offline
Old 11-28-2010, 08:40 PM   #2120
SRVBLUES64
A big fat zero, its just to cold here in Indiana. Does anybody have any thoughts on a heater for a garage I have 220v and 110v no gas, Thanks Jeff
SRVBLUES64 is offline
Old 11-29-2010, 11:26 AM   #2121
Turkey
Turkey's Avatar
Got my tree yesterday with it.
Turkey is offline
Old 11-29-2010, 12:06 PM   #2122
jbgroby
jbgroby's Avatar
I cannot wait to do that with mine! thats is too cool, Although the guys at the Christmas tree lot did not LIKE it because it took the guys away from looking at trees!
jbgroby is offline
Old 11-29-2010, 01:10 PM   #2123
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
running the lines for the hyrdo boost. Those brackets are captin fabs set up. Picture was done using photo shop for the line company "gottashow" they dont have very good insturctions so I sent them that pic. Ididit sent me the wrong steering column so that is going back ...bummer but they are taking care of me so more down time. Plenty of other stuff to work on..
GMR-PERFORMANCE is offline
Old 11-29-2010, 04:53 PM   #2124
Turkey
Turkey's Avatar
Used the tailgate as a welding table in order to start on my welding cart.
Turkey is offline
Old 11-29-2010, 08:36 PM   #2125
losthope
losthope's Avatar
not much with the 65 just drivin it to work and back everyday, but did get out the hammers and dolly and beat some dents out of the 63 did alright i geuss for a first time doing it.
losthope is offline
Closed Thread
