Old 10-31-2011, 11:39 PM   #2101
71Sleeper
71Sleeper's Avatar
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Goes to show...There is always more than one way to skin a cat.
71Sleeper is offline   Reply With Quote
Old 11-01-2011, 09:35 AM   #2102
67cheby
67cheby
67cheby's Avatar
you my friend are a PROBLEM SOLVER !!
67cheby is offline   Reply With Quote
Old 11-01-2011, 01:34 PM   #2103
thor
thor's Avatar
time for video of e-brake slides ha, ha
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 11-01-2011, 01:43 PM   #2104
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Great work and ingenuity!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-01-2011, 10:46 PM   #2105
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
And on tonight's episode of As The Wrench Turns, we have a bed that got mounted and a little shot-o-bling.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 11-01-2011, 11:05 PM   #2106
noonzor
very nice!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 11-01-2011, 11:35 PM   #2107
67cheby
67cheby
67cheby's Avatar
looking good !!
Old 11-01-2011, 11:42 PM   #2108
Dieselwrencher
Very nice!
Ryan
Old 11-01-2011, 11:51 PM   #2109
VA72C10
VA72C10
VA72C10's Avatar
Looking good.....although you really need to clean your bed
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 11-01-2011, 11:55 PM   #2110
71Sleeper
71Sleeper's Avatar
I got the same advice on mine to.
Old 11-02-2011, 12:01 AM   #2111
VA72C10
VA72C10
VA72C10's Avatar
BTW....you're nearing #1 on the views.....231K+ as of tonight!
Old 11-02-2011, 09:28 AM   #2112
67cheby
67cheby
67cheby's Avatar
i know it is a little petty thing but with the work you have put in , i think those bolts through the bed floor need to have a round head instead of the hex head to blend in better, maybe a round allen headed bolt ?
Old 11-02-2011, 09:45 AM   #2113
drewskiren
drewskiren's Avatar
I agree completely, but since the bed floor is so rough I am rhino-lining and covering the whole thing up with a rubber mat. Since it has to be covered up anyway, bolt heads don't really matter.
Since I am planning on using the truck, I figured it was insane to spend $1000 on a bed floor and then worry about denting or scratching it. Yes, I hope the truck is magazine worthy, but that is a secondary consideration to my using it everyday.
Drew
Old 11-02-2011, 11:36 AM   #2114
jb1016
"Oh well, it's a driver."
jb1016's Avatar
The fact that you plan to use it is the best part of the build. I hope you get to put as many miles on it as the build has had views!
Old 11-03-2011, 01:32 AM   #2115
drewskiren
drewskiren's Avatar
Tonight's episode begins with painting the radiator support and new radiator mount satin black. A few more coats tomorrow and it will be ready to assemble.
Then I moved on to the shift linkage. I welded and extension on the shift ear I cut off to clear the brake booster, then assembled the Kugal stainless steel shift linkage. http://www.kugelkomponents.com/zenca...&products_id=6
I very carefully fit and adjusted, then shortened the rod twice so as not to cut too much off at once. The throw is now perfect and I get all gears to click nicely, it even lines up on the column indicator right.
Then I read the wiring diagram and ended up only needing one wire on the right electrical block -green temp sensor wire for gauge. I may want the switched brown wire for something, so I left it for now.
Drew
Old 11-03-2011, 01:50 AM   #2116
Dieselwrencher
Little by little.
Ryan
Old 11-03-2011, 01:58 AM   #2117
drewskiren
drewskiren's Avatar
Originally Posted by Dieselwrencher View Post
Little by little.
Exactly.
Drew
Old 11-03-2011, 02:36 AM   #2118
VA72C10
VA72C10
VA72C10's Avatar
More good progress. Shift linkage looks good as does the rad support!
Old 11-03-2011, 02:51 AM   #2119
71Sleeper
71Sleeper's Avatar
Little by little.
And soon there will be little to do.
Old 11-03-2011, 04:34 AM   #2120
72shortstep
lovin' the lowcountry
72shortstep's Avatar
Are you keeping the mechanical fan or going with an electric set-up? sorry if you already answered this but that chip in the fan blade made me think about it, haha.
Chris
29461
72 SWB stepside
71 SWB stepside
DRIVE IT LIKE YOU STOLE IT!
72shortstep is offline   Reply With Quote
Old 11-03-2011, 09:07 AM   #2121
drewskiren
drewskiren's Avatar
Mechanical, because it is free and installed!
Drew
Old 11-03-2011, 04:26 PM   #2122
drewskiren
drewskiren's Avatar
These pics are more fun to look at.
Where do these little square rubber blocks go? They came with my tailgate bumpers kit.
Drew
Old 11-03-2011, 04:58 PM   #2123
67cheby
67cheby
67cheby's Avatar
SWEET they are bumpers for the tailgate !!
Old 11-03-2011, 05:00 PM   #2124
drewskiren
drewskiren's Avatar
Where?? got a picture?
Drew
Old 11-03-2011, 05:01 PM   #2125
Pop's C-10
Pop's C-10's Avatar
Have you thought about doing tha stop light mod that i've seen on here using that factory cargo light..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
