Closed Thread
Old 11-29-2010, 09:07 PM   #2126
MacbreSkull
MacbreSkull's Avatar
Re: What did you do to your truck today?
I didn't do anything today cause it looks like this right now...
But i have a gas tank soon to arrive so it won't be that way for long
1964 Chevy Fleetside Long Box
MacbreSkull is offline
Old 11-29-2010, 09:14 PM   #2127
fink64
today i hualed in 700.00 worth of scrap metal so i can afford to work on my truck. The wife is really going to enjoy her christmas present, new gauge cluster for my truck. lol
fink64 is offline
Old 11-30-2010, 12:50 AM   #2128
MalibuKasey
Artist
MalibuKasey's Avatar
Fixed the gas gauge (bad float), Fixed the blower motor, and fixed a nasty exhaust leak caused by my carb spacer... guess Ill just have to live with the heat soak... for now.
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66
MalibuKasey is offline
Old 11-30-2010, 11:03 AM   #2129
jbgroby
jbgroby's Avatar
Although I find it "purdy", how do you folks live with that? i would go insane (although I don't have far to go to get there)
jbgroby is offline
Old 11-30-2010, 11:07 AM   #2130
jarkill
jarkill's Avatar
Nothing today, But i'm off all next week so i plan on getting some body work done
63 C20 Fleetside LWB
jarkill is offline
Old 11-30-2010, 11:15 AM   #2131
firefighter736
firefighter736's Avatar
Took her off to the body man to get new rockers, cab supports, floor pans, and center cab supports put on her. Hope he doesn't take forever to do it.... welding isn't my forte and I really wanted to save this BBW cab.
firefighter736 is offline
Old 12-01-2010, 07:07 PM   #2132
lakeroadster
Formed the flanges into the rear cab wall for the cab vents. Bolted the vent surrounds in and trimmed the cab flanges flush.
Next step is to prime the surrounds, install them and seam seal the joints.
lakeroadster is offline
Old 12-01-2010, 07:12 PM   #2133
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
put my new steering wheel together
GMR-PERFORMANCE is offline
Old 12-01-2010, 07:27 PM   #2134
MacbreSkull
Ive lived here all my life, ya get used to it. Makes people crazy toward the end of the winter, but i don't mind it.
Old 12-01-2010, 07:33 PM   #2135
GMR-PERFORMANCE
I got some friends up the road in Logan, you might know them they own a body shop and a harley repair shop. Wolfards?? ring any bells
Old 12-01-2010, 07:39 PM   #2136
MacbreSkull
Nope, doesn't ring any bells with me but i bet i have some car buddies from that area that it would for sure.
Old 12-01-2010, 08:02 PM   #2137
jimmydean
jimmydean's Avatar
I got bored so I took a wire wheel to my upper control arm so it kinda matches the lower.
Drivers side
Passenger side
I had some POR15 left, so I put some on the calipers after I cleaned them up, too.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline
Old 12-01-2010, 09:45 PM   #2138
chopttop
Junior Member
chopttop's Avatar
Go the bumper, grille, hood off and got the (1) fender and cowl ready to go.
'71 C10, Choptop/Lowered
'70 C30, w/24' Franklin Motor
'91 9c1 Caprice
'90 Harley FL, 127 Ultima engine w/6 speed, Blk & chrome
chopttop is offline
Old 12-01-2010, 10:00 PM   #2139
66redw/white
made in america
66redw/white's Avatar
did alittle bit of rewireing on the alternator and front parking lights
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes.
sounds good
1964 c10-283 powerpack, 3 on the tree
2004 corvette- lowered, borla, tuned. slow
my old girl
1966 c10- 305v8, t-5 sold
66redw/white is offline
Old 12-02-2010, 11:45 AM   #2140
GMR-PERFORMANCE
Ran the new fuel line from tank to pump last night swapping over to a new pump so gotta wait on that to come in.
Old 12-02-2010, 06:45 PM   #2141
markeb01
Senior Enthusiast
markeb01's Avatar
Washington law mandates new reflectorized license plates every 7 years, so those got installed this morning. Also test fit the new 15x7 TTO front wheels and re-engineered the gas pedal pivot making for much smoother operation. It was nice having garage temperatures in the 40's again so I could be out there for a while.
markeb01 is offline
Old 12-02-2010, 07:21 PM   #2142
kirtzen
kirtzen's Avatar
Any chance you could show a picture of the pedal pivot?
kirtzen is offline
Old 12-02-2010, 09:08 PM   #2143
markeb01
Senior Enthusiast
markeb01's Avatar
Not a whole lot to show, but here it is. I’m running a 1960’s era Cal Custom aluminum pedal, attached to an original Moon pedal pivot. This is mounted on a stainless steel plate which bolts to the floor using the original captive nuts. There’s a block of Delrin on the back of the pedal which acts as a rubbing surface for the factory firewall linkage, and an anti-rattle spring which applies a small amount of downforce on the pedal to keep it from rattling against the throttle rod.
Before:
Although I’ve had this in place for a number of years, it was beginning to a feel a bit notchy. After studying the angles I realized the setup would benefit by having the pivot relocated. Since I didn’t want to drill more holes in the floor or firewall, I simply made a larger stainless steel plate which moved the pivot bracket forward 1 inch, over 1/4 inch, and rotated the pedal slightly to the right. I also added a new grade 5 pivot bolt. The changes make it feel like it’s on ball bearings.
As of today it looks like this:
markeb01 is offline
Old 12-02-2010, 11:31 PM   #2144
kirtzen
kirtzen's Avatar
markeb01
Thanks, it looks great. I need to do something similar.
kirtzen is offline
Old 12-02-2010, 11:49 PM   #2145
bubba327
HOW long until spring??
bubba327's Avatar
markeb01
hey Mark looks good
Me too --I was thinking of the the old barefoot surfer style gas pedal. I had one in a rod many years ago. I found a few still around on E-bay. Just might have to order one.
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline
Old 12-03-2010, 12:05 AM   #2146
markeb01
Senior Enthusiast
markeb01's Avatar
The bare foot versions are still available NOS or new. There’s even a matching dimmer switch cover, although I’m not sure how practical that would be.
Here’s an NOS example on eBay:
http://cgi.ebay.com/Vintage-CAL-CUST...item35ae414c7c
And Mr. Gasket sells brand new what appears to be an accurate replica:
Amazon.com: Mr. Gasket 9645 Barefoot Style Gas... Amazon.com: Mr. Gasket 9645 Barefoot Style Gas...
Just be careful shopping for a used one on eBay. A lot of people “get the fever” and bid these things up well beyond the price of new. Same thing happens with Moon pedals. I believe all the bare foot versions clamp to the existing stock pedal.
markeb01 is offline
Old 12-03-2010, 12:33 AM   #2147
markeb01
Senior Enthusiast
markeb01's Avatar
markeb01
If you decide to go with the old Moon style pedal, there were 3 basic flavors available back in the 60’s – Cal Custom (which I have), Eelco, and Moon. Any of these can be returned to like new condition by sandblasting. I got tired of mine getting stained with dirt, so I blasted it and painted it with POR-15 Sterling Silver several years ago. About every 6 months I spray it with Windex and scrub it with a tooth brush, then wipe it off and it looks like new again.
There were also off brands, and some sellers on eBay try to pass off bus pedals, and even drum pedals as speed equipment. I’ve also seen several apparent Moon pedals with a different word cast in, frequently ending in H.S. These were normally cast in high school metal shops back in the 60’s in a sand cast mold made from a genuine Moon pedal. Here’s a quick description of each of the main brands one at a time so it doesn’t get too confusing.
The Moon pedal was by far the most popular and can still be purchased new from Mooneyes. I tried using an old original Moon pedal first, but they have a raised border, rim, ledge or whatever you want to call it on the left side as well as the right side and bottom. In real world use the left hand border interfered with operation of the brake pedal, so initially I removed the left border. I kept trimming more and more to get to work until it soon looked like crap so I started looking for one of the other brands.
Here are several photos of Moon pedals. They also were available with two hinge styles, center pivot or heel.
Here’s a link to the Mooneyes web link:
http://www.mooneyesusa.com/moon-foot...53509cc45a044d
Next up is Cal Custom which looks very similar to the Eelco version, except for the pyramid or waffle pattern. Cal Custom is indented while Eelco protrudes. The only advantage of one over the other is the Eelco is probably easier to clean. Neither of these brands have the ledge on the left side.
I bought my Cal Custom pedal on eBay which is the only place I have found any in many years. You may have luck locally if you have swap meets in the area. Cal Custom came in two styles, heel pivot and clamp on (to attach to a stock accelerator pedal). Mine is a heel pivot type, attached to an original Moon heel pivot bracket. Here are a few pictures of both styles:
Cal Custom also offered a matching dimmer pedal. I bought one as a kid and put it in our 52 Oldsmobile, but my dad hated it and kept pulling it out because his shoe constantly hung up on the side of the miniature. I've seen these on eBay sell for anywhere between $20 up to $75. Here’s a couple of pics:
Eelco is the 3rd brand and here are a few photos. They can always be identified by the little barefoot insignia on the back.
All 3 brands seem to be equally popular now, and condition seems to be the most important factor in their cost. I’ve also seen bidding fever drive a mediocre Moon pedal over $100, when a new one could be purchased for less than half that amount.
Happy hunting if you decide you want something like this.
markeb01 is offline
Old 12-03-2010, 01:55 PM   #2148
Vernski
Holy crap Markb you sure do your homework thanks for sharing the pic's, haven't seen some of that stuff for years....Vernski
Vernski is offline
Old 12-03-2010, 03:02 PM   #2149
StevieC
I got a 65 big window from my renter in lieu of a months rent... it's rough
It hadn't been started in two years so last night I bought a battery for it, a couple gallons of gas, and a can of starter fluid.
It took a while and when it finally came to life water started spraying out the middle of the metal upper radiator hose/pipe.
So today I got me a radiator hose, a one day vehicle move permit, and I'm on a mission to drive that truck an hour and a half to my place
StevieC is offline
Old 12-03-2010, 04:12 PM   #2150
markeb01
Senior Enthusiast
markeb01's Avatar
Thanks Vernski, I routinely focus way too much time on details I’m interested in. I like to share as much as possible for those that may care about this stuff in the future, when there aren’t any more old guys around to ask.
Good luck on your adventure. Hopefully the weather cooperates and the trip is uneventful.
markeb01 is offline
Closed Thread
