Closed Thread
Old 04-17-2011, 01:30 PM   #2126
sjarrett71
sjarrett71's Avatar
Re: What did you do to your truck today!
Drove it to work about 11 miles. Longest trip since the tranny swap and it did great!
-Scott-
sjarrett71 is offline
Old 04-17-2011, 01:46 PM   #2127
DesertCat
DesertCat's Avatar
All I've ever done for it... bought parts :-p
Have yet to actually see it in person...
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline
Old 04-17-2011, 04:12 PM   #2128
profe56
Preparing rear end to swap
Uploaded with ImageShack.us
profe56 is offline
Old 04-17-2011, 04:34 PM   #2129
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Drove to Lowes for stuff in the addition. Since the T10 got installed, Been a blast to drive. However, next move might need to be a power steering setup!
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline
Old 04-17-2011, 05:06 PM   #2130
69trk
69trk's Avatar
put some rally wheels/spinners on the truck today...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline
Old 04-17-2011, 08:42 PM   #2131
Rob H.
Rob H.'s Avatar
Did a little more tuning too the carb and used it like a truck! Also put the original hub caps back on.
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline
Old 04-18-2011, 12:23 AM   #2132
jhwkns
Registered Cruiser
jhwkns's Avatar
I finally got off of my lazy butt. After a year of running around in primer I'm going to finish my paint job. 98% of the body work was done months ago. I had gotten to a point and stopped. Meanwhile a few other projects were done in front of it.
I backed it into the shed, and my son and I pulled it apart today. It's almost funny how fast you can strip one of these trucks down. I hope to start painting tomorrow.
I intend to live forever. So far, so good.
jhwkns is offline
Old 04-18-2011, 06:53 AM   #2133
Bennett68C10
Bennett68C10's Avatar
Originally Posted by stevencvn72 View Post
If that's a spintec...it's gonna sound SICK!
Yes they are Spintech Super Pro Streets, i'm excited to hear them I figure they should sound pretty good.
I also picked up a 700r4 with converter this past weekend at Englishtown Swapmeet. Got it for $140.00 with 80k miles on it. Going to see how it runs then rebuild it before i put any big power to it. Fluid was really good in it and not burnt, transmission is in really good shape came out of an 1988 Caprice. Will just do a tune up and new seals in it for now.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 04-18-2011, 08:22 PM   #2134
You doing it in white again?
Palf70Step is offline
Old 04-19-2011, 01:43 AM   #2135
jhwkns
Registered Cruiser
jhwkns's Avatar
For now, Yes. Old habits are hard to break. I might go two tone later on.
I got the inside of the bed painted this evening. It turned out pretty nice. The prep work of stripping, sanding, and knocking the dings out of the bed floor took so long, I hope it was worth the effort. I hope to get the cab, hood, door panels, and tailgate sprayed tomorrow.
jhwkns is offline
Old 04-19-2011, 11:45 AM   #2136
npc1
npc1's Avatar
Well I didnt do it today but I did it yesterday. I ordered my adjustable trailing arm crossmember from Nathan at Porterbuilt. Piece number 1 of many to come from Porterbuilt.
npc1 is offline
Old 04-19-2011, 07:39 PM   #2137
gonnuts
gonnuts's Avatar
Put on my Lokar shifter linkage on my 700R4 , it's way better than the mickey mouse set-up the PO had on there(zip ties should not be used on shifter linkages!!!) Still waiting on my engine from my builder, getting frustrated it's been a day or two for at least a week now.
gonnuts is offline
Old 04-19-2011, 07:50 PM   #2138
Dano69c10
Dano69c10's Avatar
Got my new stainless fuel lines (tank to pump) in today. Plan on removing the old lines, then installing the new ones. I also need to bend my own line to go from the pump to the carb.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline
Old 04-19-2011, 08:03 PM   #2139
bucketObolts
bucketObolts's Avatar
yesterday and today I pulled the front end apart. I am eagerly awaiting new 7" slam specialties bags, tie rod inner and outers, pitman arms, wheel bearings and new drum parts for the rear. Almost bit on the rear disc conversion, but had to just shut off the computer and walk away with my tail between my legs.
LIFESTYLES OF THE POOR & UNKNOWN
bucketObolts is offline
Old 04-19-2011, 08:51 PM   #2140
SSchevimp
i pulled the farmer bumper off. along with the "custom" ginormous hitch, pulled the two side fuel tanks that were added off, also took these helper leaf lookin things off ... and ordered some parts
70 c10 long bed
57 chevy 2 door wagon
07 tahoe
96 civic commuter
SSchevimp is offline
Old 04-19-2011, 09:23 PM   #2141
pritch
pritch's Avatar
I guess I better jump into this thread since I'm working on my new '68.
So far, I've given the cab a good once-over cleaning, fixed the driver's side door latch. Crazy thing wouldn't latch, so I pulled it out and it worked fine in my hand, so I put it back in and now it works fine in the door. Sunday I got the new ball joints and shock and brakes back together-driver's side only, and then today I started on the right side. I got everything apart before I ran outta steam, but going back together is the easy part.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline
Old 04-19-2011, 11:40 PM   #2142
Cooper33
Cooper33's Avatar
Finally got the garage cleaned out, washed the truck and moved into the garage. Want to keep out of the elements until I get a job and can start pouring money into it. To bad I don't have the money, cause I got all the time in the world.
Brad
67 Chevy SWB stepside - http://67-72chevytrucks.com/vboard/s...d.php?t=449426
89 Ford Bronco
92 Suzuki Sidekick
94 Kawasaki Vulcan 750
06 Honda Aquatrax
Cooper33 is offline
Old 04-20-2011, 12:03 AM   #2143
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I discovered that my spare -- original, I believe -- contained no air. I have not checked it in a great many years. If it loses air, as I expect it to, I'll be shopping for a wheel & tire....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline
Old 04-20-2011, 03:29 AM   #2144
wwotr
wwotr's Avatar
Well actually a couple of days ago......
Stripped off the Black Paint on my 72 GMC Grill.
Afterwards, I'd say it was about a 7.5 out of 10.
Definatley a "50 Footer", but will do until I buy a new Chrome Grill.
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline
Old 04-20-2011, 09:59 PM   #2145
flashed
I bought my 72 a new cowl hood and made a deal on a new front grill assembly by trading a new GM 68 Chevelle fender for it.
flashed is offline
Old 04-20-2011, 10:34 PM   #2146
Keller
Keller's Avatar
drove it like i always do
came home to find a box of goodies by the front door...
1972 C10 Longbed 350/350
Keller is offline
Old 04-21-2011, 11:28 AM   #2147
zellway
zellway's Avatar
Got my tail lights installed. Also finished the exhast. This weekend will be back on the road.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline
Old 04-21-2011, 11:50 AM   #2148
1quik70
I don't have any pic but, I filled mine full of black mulch last week! This week, I have just been beating the old thing back and forth to work like I've done since I bought it last March!
1quik70 is offline
Old 04-21-2011, 12:16 PM   #2149
60ratrod
yes, i do
60ratrod's Avatar
Finished removing the front driver's cab support and mount bolt. That bolt didn't wanna give in. Now on to removing the front clip to help with installing the new support
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline
Old 04-21-2011, 12:17 PM   #2150
Gene
Gene's Avatar
Got my matching lock set installed that just showed up today from LockDoc. It sure will be nice to use one key when she gets back on the road!
Gene is offline
Closed Thread
