03-05-2016, 08:18 PM | #2126 |
Re: What did you do to your truck today part III
....got a great group picture of the whole reason I'm fixing the truck up. Our future 'bolters.......
http://s1299.photobucket.com/user/jb...23904108567829 |
03-05-2016, 09:19 PM | #2127 | |
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
03-05-2016, 10:21 PM | #2128 |
My long stepside sides arrived from mar-k yesterday. Very impressed with the 2 day shipping and the quality packaging/crating. And as always extremely happy with the parts!!
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
03-05-2016, 10:30 PM | #2129 |
Sealed up the 230ci today. Working with gaskets and sealer is stressful for me. Glad it's over. I also set/adjusted the valve lash today. For me, a lot less stressful.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
03-05-2016, 10:35 PM | #2130 |
Today we got busy priming my new bed sides and painting my front fenders, front bed panel, tailgate, rear cross sill and cowls.
03-06-2016, 09:40 AM | #2131 |
Oooh pretty shineys!! Put my overtime to work - finally bought the pulley/bracket kit I needed when I did the front end swap! Before shot. After. Got rid of a cool period correct but cumbersome fan shroud. We'll see how that little fan works in Houston traffic. I might have to go to a bigger unit with a built-in shroud. Oh yeah, I stuck a new carb in there while I was at it
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com Last edited by Hilandr451; 03-06-2016 at 09:53 AM. |
03-06-2016, 09:49 AM | #2132 |
Well I finally got around to replacing the bed wood in my '66 C-20. We got all the boards sealed and the new rails treated and coated with POR15.
my nosy neighbor comes over while these were drying and says "don't those go the other way? " well at least he's got a sense of humor! Mrs. Hilander even got into the action!
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com Last edited by Hilandr451; 03-06-2016 at 10:07 AM. |
03-06-2016, 10:54 AM | #2133 |
and the fun begins....... One side and one wheel tub off, work resumes on tearing down the rest of the bed. Cutting and grinding.... ....and grinding and cutting.
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com |
03-06-2016, 11:37 AM | #2134 |
cleaned up the cross braces and started on the tubs.
Got the cross braces treated and coated with POR15. got everything fitted on the truck but I ran out of daylight.
03-06-2016, 01:40 PM | #2135 |
Hill
I sent you a PM.
03-07-2016, 10:11 AM | #2136 |
03-07-2016, 10:15 AM | #2137 |
Something about these bullets is irresistible but I eventually went back to stock on my fleet side... yours looks good!
03-07-2016, 09:26 PM | #2138 |
It's Better With Nitro
03-08-2016, 01:16 PM | #2139 |
03-12-2016, 06:13 PM | #2140 |
Finished the bed!!!
03-12-2016, 07:49 PM | #2141 |
some hood work, adjustment, various trim scenarios and the drivers side door panel DONE
After all the deliberation 60 WON |
03-12-2016, 08:43 PM | #2142 |
Put the 230ci on the engine run stand and gave it a test run. Here's the VIDEO.
03-13-2016, 06:05 PM | #2143 |
Got this email earlier........
All I can say is Roll on weekend....!! Though, saying that, Saturday is kind of reserved and Sunday I will be in Essex at the NSRA Swapmeet. Hope to find a few bits there, including a thermostat housing.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
03-14-2016, 10:42 PM | #2144 |
Assembled Passenger Side Door this evening, pulled the junk bench seat, started mechanical assembly on the van tilt... getting ready for wheel.
Installed the Passenger Side Door Panel and arm-rest. Good night |
03-15-2016, 11:28 AM | #2145 |
Found the last piece to my horn button (it was under the seat and rusty) guessing PO took wheel off for some reason and installed universal button) Rewiring it today
Installed Street sign sun visors Need to replace passenger E brake cable (drill out frame rail holder) And order piston and rings to replace #1 |
03-17-2016, 02:22 PM | #2146 |
Been working on my truck more the last couple of weeks. Tired of talking about it. Front half of frame is clean and coated in POR. Almost finished with putting new bushings under the cab. My friend sprayed color and matte clear on the motor and transmission yesterday evening. Next step is to move the crossmember forward to center the front wheels then fabricate the mount for rack and pinion. After that, put in the motor/trans and start wiring. I ordered the harness from PSI yesterday, can't wait to get it !
03-17-2016, 02:59 PM | #2147 |
Finally got around to cleaning the engine bay. Primer on it now, then paint, then new MC and at some point the engine will make it's way back in there
1961 Chevy Apache "BoomStick" -First build, lots of plans, little experience. What's the worst that could happen? http://67-72chevytrucks.com/vboard/s...d.php?t=694506 |
03-17-2016, 07:22 PM | #2148 |
Drove it to town.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
03-17-2016, 10:02 PM | #2149 |
Just got my updated wiring harness from MCB Matt....hopefully i will getting it installed this week
03-17-2016, 10:18 PM | #2150 |
Used mine to pick up my engine from the machine shop
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
