05-17-2015, 06:23 PM | #2176 |
Re: What did you do to your truck today? Chapter II
I found some parts I didn't realize I had, including a sending unit wire clip! OMGosh I have a member mailing me two of those since I didn't think I had any. I'm an idiot.
I also found some carb parts I had totally forgotten about so now all of those are soaking in Evaporust. |
05-18-2015, 10:03 PM | #2177 |
05-18-2015, 10:27 PM | #2178 |
Not bad seats for $120, going to recover them or a set of covers, nice to have the center console.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
05-18-2015, 10:32 PM | #2179 |
Yesterday I broke the key off in the ignition and today I got it started using a screwdriver. And I tried to retire the trailer light connector that was not hooked up right the first time. It almost seems like I have too many green wires.... Tomorrow I will attack again!
Posted via Mobile Device |
05-18-2015, 11:08 PM | #2180 |
Keep after it DdowC20!
I got some more stuff together for my electrolytic derusting tanks and wired the first one up. I'll try it out tomorrow. |
05-18-2015, 11:12 PM | #2181 |
Got my truck to go up and down with the push of a button. Pretty big milestone.
Of course it took me a few days to run all the wiring. Ran all he stainless braided fuel line and plumbed in the fuel pump. Drilled and tapped a couple dozen 5x.8 metric mounting holes to mount said fuel line and air line. Only broke a few taps in the process. I'm getting closer and closer by the day to driving this thing. |
05-18-2015, 11:47 PM | #2182 |
My Daughter & I took the Blazer out and blasted around late yesterday afternoon. Ran it pretty hard and flipped the power steering belt off. 255/50R/18's steered pretty HARD on the way home. It never did that before. Conveniently the old belt stayed inside the shroud so I can use it as a guide for the replacement.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
05-19-2015, 05:49 PM | #2183 |
Replacing the old turn signal switch, and decided to "fix" my gauge cluster lights while I had everything apart. Got some 10" led strips from work, and ran them along the outside wall of the inner metal frame. I also managed to wire another led strip to the door switches to replace the missing dome light. Not the prettiest fix, but it's better than nothing until I can get a correct replacement assembly.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast! Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun. 1st BN 3rd MAR. '00-'04 |
05-19-2015, 05:53 PM | #2184 |
05-19-2015, 07:45 PM | #2185 |
I ran electrolysis on my radiator hold down brackets. The process works and is cool as all get out, but I guess 2.5 hours isn't enough time. Not a lot of rust came off although a good bit was on the sacrificial steel. It did remove most of the paint though.
I'll try again tomorrow and go for 12 hours running time. |
05-19-2015, 10:54 PM | #2186 |
Cluster is done and installed, turn signal switch is in, but when I indicate only one side flashes. Oddly enough, it's the same side regardless of which direction I indicate. Also, the right arrow on the dash lights up when I step on the brakes.
Odd.
05-19-2015, 11:01 PM | #2187 |
Could be a ground problem but have run into the harness plugs corroding inside and jumping over to another post a few times now.
05-19-2015, 11:02 PM | #2188 |
Forgot to mention located most of the way down pas side frame rail just above diff area.
05-20-2015, 12:46 PM | #2189 |
The funny thing is that the turn signals flashed correctly before this, I only replaced the switch due to the springs breaking. Which gave me automatic signals, I turn the wheel, they flash that direction. I'm not doubting a possible issue along the frame, since the brake lights have been iffy. Sometimes both work, sometimes only the driver side, or passenger side.
05-20-2015, 07:06 PM | #2190 |
Just picked a 71 GMC Stepside, Love them stepsides. A lot of little things to do. Well I order a American autowire 67-72 complete wiring kit. I looked at the old wiring that everyone & their brother had mess with & said replace the hold thing. The hardest thing was enlarging the panel/fuse box hole. So far no problems Everything plugs or snaps in. Taking my time & trying not to muckup.
Day one all is well. |
05-20-2015, 08:48 PM | #2191 |
Installed my 3-point seat belts and bolted up my bench seat. Vac-ed out the whole cab. Much cleaner now. Then drove it around the farm. Found that I can't shift down while in motion. Guess my clutch needs some more adjustment.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
05-20-2015, 08:53 PM | #2192 |
I ran electrolysis on a radiator bracket for 9 hours and now have it in some left over Evaporust. I also did a lot of discussing with other members (Fitz) about how better to remove surface rust and get ready for the part to be painted.
05-20-2015, 09:22 PM | #2193 |
i usually shift with no clutch but sounds like it
05-21-2015, 12:40 AM | #2194 |
Here are some pics of the progress. Got her on the rotisserie this evening and got a good start on the drivers side!
67 Chevy Shortbed Fleetside C10 400 SBC/Turbo 350/Posi 62 Impala SS (Clone) 350 SBC/4 Speed/3:36 Posi Rear 2003 Silverado Crew Cab (Black) 2500 HD 4x4/6.0L/Auto/Posi |
05-21-2015, 01:21 AM | #2195 |
Received:
Balance of hardware for the moldings. NOS Only need one (or two if I can find better) trim pieces (upper tailgate) for the complete upper/lower sides and tailgate. One NOS LH back-up lens. Mint One NOS red deluxe. Mint. One NOS amber deluxe. Still in the package, but can't say I'm thrilled. It's nice, but there's small flaw in the trim. I believe they have a marker for that. With that and the others I have an 8-piece NOS lens set I won't use. Package deals, etc., and changed my mind about the deluxe (learning curve, SS-education)......Going to use standard markers instead. Two NOS park lenses. Mint and marked 1971. I should receive the standard red markers by the end of the week, and with those I'll have all ten lenses for my build. NOS but one (amber marker), though it's real nice. The price on 6 of the lenses was great, with the tails being absurdly cheap. They have the correct 71 markings too. Marked 67 seems to be much more common.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-21-2015 at 10:04 PM. |
05-21-2015, 10:03 PM | #2196 |
Picked up an NOS rear mirror bracket today. Same price as the repro. I bought last year. Another education.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-21-2015, 11:03 PM | #2197 |
Got a 'phone call from the Paint Jail to - day , he says he's painting my hub caps and rear bumper , I think he expects me to pick it up this Holiday weekend ~ yeah right .
Apparently he's given up on installing the HVAC or connecting the electrical , that's O.K. as I don't trust anyone else to do it correctly . Wait'll I post pix of the shiny new paint .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
05-21-2015, 11:08 PM | #2198 |
It was COLD today and very rainy, so I hardly went out except to run electrolysis on the other radiator bracket. A slow process but at least it's cheap and pretty effective.
05-22-2015, 07:32 AM | #2199 |
What does electrolysis do? Is that a plating process or a derusting process?
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
05-22-2015, 08:32 AM | #2200 |
Electrolosis can be used for de rusting .
