Closed Thread
Old 11-30-2010, 04:01 PM   #2201
68 TT
Still plays with trucks
68 TT's Avatar
Re: Finally "Silvers" build thread!! ('78 swb 2wd silverado)
Originally Posted by Captkaos View Post
12bolt truck axle is NOT the same as a 12bolt car. The pinion on the 12bolt truck is smaller. The 10 bolt is the same strength and it has a bigger/stronger pinion. It is not worth the effort to find a 12bolt, save your money and time and just upgrade the 10bolt. If you don't plan to drag race it every day with slicks on it you will be fine.
I agree. You can also upgrade the 10-bolt in your truck with the 30-spline posi carrier out of an 88-up truck making it nearly as strong as the car 12-bolt.
An 88-up truck rear axle swap may be the way to go for you as long as you can handle the minor extra width with your wheel offset. It brings the rear wheels out closer to alignment with the front. Glock35ipsc did the swap on Fred and it really helped the looks.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline
Old 11-30-2010, 04:15 PM   #2202
nlped
nlped's Avatar
^^^I did it before Bob on my now gone "87 GMC (nicknamed...wait for it...Bob ). While doing the swap, I installed new bearings, seals and an Eaton posi-unit too. It was a pretty simple swap...just cut the spring perches and shock mounts off and relocate accordingly. And it does make the track width in the rear just a fudge wider, but I doubt it would affect your set-up.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 11-30-2010, 04:27 PM   #2203
68 TT
68 TT's Avatar
Someone told me that the Z71's got a clutch type posi carrier instead of the gov-lock posi carrier the regular trucks got. Don't know if this is true or not but it would mean you could find a used clutch type posi rear end to do the swap with.
68 TT is offline
Old 11-30-2010, 04:34 PM   #2204
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
None of them ones I have seen past 1980 were clutch type from truck I knew were factory.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Captkaos is offline
Old 12-01-2010, 01:27 AM   #2205
nbpro
z71 gm package consist of
Tires and shocks mostly. Driving lights in the lower front valaince, G80 locking rear diff (aka Timex locker),
The tires were a slightly more aggresive tread All Terrain, and the shocks were over priced Bilstien. and a Skid plate package
The interior trim was either LS or LT, (badge on "B" pillar") LS being cloth seats, base radio( several options to this) dash cluster had fewer gauges. 4x4 actuation was dependant on trim level, push button selection, on both trim levels LS and LT, LT having the "autoride" option offering selectable automatic full time 4x4, VS 2hi .4hi amd 4lo
LT was leather, full gauge package, Uplevel stereo package, better HVAC controls. most likely to have power windows and locks, XM option, OnStar,
The Work truck (WT) 4x4 were vinyl seats, usually no carpet but a rubber mat, inner door panels were plastic, no power windows, 4x4 as floor mounted stick.
There are caveats and exceptions to any and all of this, Dealers make changes to the trucks at the dealership which really confuses things.
nbpro is offline
Old 12-02-2010, 05:00 PM   #2206
menace121978
menace121978's Avatar
got my fenders turned out nice...
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline
Old 12-02-2010, 05:04 PM   #2207
draggin86
draggin86's Avatar
looks good brotha! one more step closer!
draggin86 is offline
Old 12-02-2010, 05:09 PM   #2208
nbpro
those look good. is it just the insides, or are both sides painted?
nbpro is offline
Old 12-02-2010, 05:12 PM   #2209
3r!c84
Badass
3r!c84's Avatar
baby steps, baby steps
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline
Old 12-02-2010, 05:23 PM   #2210
nlped
nlped's Avatar
There just trimmed out on the inside, right? The outside will be painted on the truck as a whole...correct?
Here, nor there... They look KILLER!!!
Carter
nlped is offline
Old 12-02-2010, 05:34 PM   #2211
menace121978
and you are correct thanks guys!!
"Dennis the Menace"
Old 12-02-2010, 11:07 PM   #2212
Stitch
Location: Where I come from, it's cornbread and chicken...
I like the undercoating inside the fender skin. They look great man. It's coming along alot faster than my crewcab lmao
Stitch is offline
Old 12-02-2010, 11:25 PM   #2213
N2TRUX
Happy to be here
N2TRUX's Avatar
Those look great. Now you need cover panels cut to hide all the holes...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
N2TRUX is offline
Old 12-02-2010, 11:55 PM   #2214
baclay9
How did you paint the under coating inside the fender like that?
baclay9 is offline
Old 12-03-2010, 12:47 AM   #2215
bigblock73
yeller
bigblock73's Avatar
Dennis, fenders turned out great! I hope you are as happy with yours as I am with mine.
bigblock73 is offline
Old 12-03-2010, 12:49 AM   #2216
bigblock73
yeller
bigblock73's Avatar
Undercoating comes in an aersol can, stick the nozzle in there, and apply a nice even coat. Wipe off any overspray before it dries. Did my hood and fenders like this a while back.
Old 12-03-2010, 02:25 AM   #2217
54Caddy
GM Addicted
54Caddy's Avatar
dennis another question on the calipers have you tries mounting the 15 wheels you have with the wilwood calipes. I will be running stock steelies on my truck and want to make sure they will clear.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline
Old 12-03-2010, 02:45 PM   #2218
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looking good my friend. Looking good!
--Josh
STOCKISH is offline
Old 12-03-2010, 02:57 PM   #2219
scotts62
One day...
scotts62's Avatar
Very nice!
Scott
93 crew cab build
Project 62
scotts62 is offline
Old 12-03-2010, 03:05 PM   #2220
palposity
palposity's Avatar
Agreed! They look great!
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original.
View Project Pops HERE
Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig
View Project Cletus HERE - SOLD
DD--2008 Duramax CCSB
palposity is offline
Old 12-04-2010, 02:39 AM   #2221
twoodson
Good job Dennis you son of a gun, send me that $$$$ tree for a little while and let me catch up.. lol Great job and keep up the good work.
twoodson is offline
Old 12-04-2010, 07:35 AM   #2222
menace121978
thanks for all the words guys!!! i put on the doghouse seals and threw a couple bolts in the drivers side fender i can see a couple light spots (in the pics) where i need to apply more undercoating and i need to chop 1 full coil off on the 1" bell techs to make her sit right. but other than that she looks good! almost like a truck again.
"Dennis the Menace"
Old 12-04-2010, 08:32 AM   #2223
nbpro
well get wonk on it j/o looking good man
nbpro is offline
Old 12-04-2010, 10:13 AM   #2224
RD71
RD71's Avatar
Thumbs up Re: Finally "Silvers" build thread!! ('78 swb 2wd silverado)
This is my first post (I'm new here, so hello...). I just had to say, I've been reading this entire thread from the start- what an amazing project! Your attention to detail is astonishing.
Keep up the good work, waiting to witness the finished product...
Classic motoring and more... As viewed through my SLR. Enjoy!
RD71 is offline
Old 12-04-2010, 11:57 AM   #2225
JohnC
JohnC's Avatar
Heck yeah man! Looks good!
JohnC is offline
Closed Thread
