Old 06-12-2008, 03:43 PM   #201
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Project Topless 365/24/7
Hey B, are those fronts on backwards? (You know why I am asking, right?)
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-12-2008, 05:53 PM   #202
5150
C10 Club Tennessee
5150's Avatar
Chuck(thelonerife) stopped by last night to look at it and I noticed it. I told him I bet Craig mentions something about the tires being on the wrong side.
I was grinding away on the rotor so they would fit over the hub. Mandi rolled them too me. I didn't care what side was what. After all day I just wanted to see what they look like
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 06-13-2008, 10:54 PM   #203
5150
C10 Club Tennessee
5150's Avatar
okay, got the shocks on and got the upper shock relocators on but now I'm pulling my hair out by trying to get this tank in. Called Tim and he tried to explain it over the phone but I'm not grasping it. Thought I'd take a pic and see if anybody could help. I'm sure it's common sense, but well you know. Tim said it went from right to left if that helps. I assumed that meant that the J-hooks went on the pass side.
Just not understanding the straps. They are different then any of the other ones I've seen in other threads.
Bryan
www.gmtruckshow.com
Old 06-14-2008, 01:10 AM   #204
hgs_notes
GEARHEAD
hgs_notes's Avatar
Don't ya just bolt the driver side of the strap up to the fraame, then put the J bolts in the passenger side, then set tank up where it belongs and hook the J into the passenger side end of the straps?
hgs_notes is offline   Reply With Quote
Old 06-14-2008, 03:28 AM   #205
original_balzer
original_balzer's Avatar
I bought a 69 blazer tub once that was shaved of everything doors and tailgate welded up too. windsheild was chopped 8" and leaned back. It had a huge consel that went front to back the inside was all flat sheet metal on the sides and doors. It was full on roadster status with some unusual exterior body mods.
I bought it thinking I could UN-do most of it and use the tub for my 72 4x4 blazer. In the end I hauled it to the scrap yard cuz 1) it was too much work and 2) I couldnt sell it or give it away at the time. It was rather hideous truthfully. You could hardly tell it was a 69-72 blazer.
BUT every since then I thought it would be sweet to have a nice 2wd blazer minus all ( or at least most) of the mods that one had.
VERY COOL!
original_balzer is offline   Reply With Quote
Old 06-14-2008, 11:03 AM   #206
lyrikz
PITbut
lyrikz's Avatar
Famous message board line "son if you cant figure out how to install that gas tank, you probably shouldnt take on this kind of project"
I hate when people say that. Bolt the left side up, NOT tight, just enough to hold that and the tank in place. Install the J bolt, then lift up the strap and put it in the j bolt. Tighten as necessary...
Sometimes you will run into things that are SUPER easy but will just stump you.. Mine for example was removing the cigarette lighter... 2 hours later a buddy came over and had it out in 35 seconds. ahaha
Keep up the good work man.
lyrikz is offline   Reply With Quote
Old 06-14-2008, 11:22 AM   #207
bagged74
its just $$$$$
bagged74's Avatar
are the straps bent the wrong way? its really pretty easy once you figure it out.
bagged74 is offline   Reply With Quote
Old 06-14-2008, 11:39 AM   #208
meathead95
computer illiterate
meathead95's Avatar
yes his straps are bent backwards
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 06-14-2008, 04:33 PM   #209
5150
C10 Club Tennessee
5150's Avatar
thanks lyrikz, I know how people are on here. Just like our mother's said "if you have nothing to say nice then..." Yes, pretty embarassing that I put the whole front end together bu can't figure out how to put in the gas tank. I appreciate the help, never understand why people won't answer board members easy questions, it's like they're trying to teach them a lesson.
Yes, I think they are bent backwards. I'll try it and picturing it like that seems like it will work.
Bryan
www.gmtruckshow.com
Old 06-14-2008, 05:27 PM   #210
Brian
Check out my build thread the pictures will help you on th tank.
http://67-72chevytrucks.com/vboard/s...d.php?t=221437
I didn't use the j-bolts (I couldn't find where I stored them ). I just used threaded rods instead, but you'll get the idea.
Old 06-14-2008, 05:27 PM   #211
meathead95
computer illiterate
meathead95's Avatar
did you get the pics i sent you on your phone? i also left you a voicemail?
72 2wd blazer
72 swb 4x4
Old 06-18-2008, 08:59 AM   #212
5150
C10 Club Tennessee
5150's Avatar
OK guys, been up since Monday at 2:30. When I got off this morning, I had to do the route all day and my mother wanted to take us out for my dinner for fathers day....so naturally, I chose Toots again. Got home around 9 pm and saw my rear end out behind the garage. So it didn't matter how tired I was....I wanted to attempt to get it installed. I ended up crushing 3 fingers on my left hand between the trailing arm and the concrete floor. I got both of the u bolts through, but need new nuts that I will get tomorrow at Ace. Then I realized that rear disc brake brackets and spacers were put on wrong. The spacer was put on first instead of the bracket. I'm sure that he already filled it with fluid, so it will be a mess to fix. I'm going to install the rear end and bags and deal with that while its on the frame. I will get some pics up tomorrow of the progress I have made.
P.S. My fingers hurt so bad that Mandi had to type this........So she says that is why this paragraph is punctuated correctly
Going to bed
_________________
Bryan
www.gmtruckshow.com
Old 06-18-2008, 11:02 PM   #213
5150
C10 Club Tennessee
5150's Avatar
Got alot done today. Rear end is up and in, the gas tank is up and in and it's on all 4's.
Bryan
www.gmtruckshow.com
Old 06-19-2008, 04:25 AM   #214
tdave00
Restoring a 68 SWB
tdave00's Avatar
I am a little late to the party, but it it is looking sweet Bryan. I'll stop by this weekend to pick those bags up.
tdave00 is offline   Reply With Quote
Old 06-19-2008, 06:42 AM   #215
5150
C10 Club Tennessee
5150's Avatar
thanks for the kind words. That's cool about the bags I'll be here all weekend.
Bryan
www.gmtruckshow.com
Old 06-20-2008, 11:50 PM   #216
5150
C10 Club Tennessee
5150's Avatar
Bags are mounted. Just need to run the elbow and the line. Gonna be a challenge in that tight space.
Bryan
www.gmtruckshow.com
Old 06-21-2008, 01:54 AM   #217
pcorriveau951
pcorriveau951's Avatar
5150, the roadster is coming along very nicely, i just look thru your thread again and dont know if i over looked it or just isnt in here, but what size tires are you running front and rear? I read your running a 20/22 combo but didnt see the tire size.
Thank you, Phil
pcorriveau951 is offline   Reply With Quote
Old 06-21-2008, 02:06 AM   #218
5150
C10 Club Tennessee
5150's Avatar
235/55/20's up front
285/35/22's out back
Bryan
www.gmtruckshow.com
Old 06-21-2008, 06:03 PM   #219
5150
C10 Club Tennessee
5150's Avatar
Got the brake lines done and the bags plumbed. So far they're holding good air through the schrader valves. We'll see in the morning if the pressure is the same. Got it outside to take some better pics and to pull the tarp out to clean all of the shavings and crap that I've dropped on there in the past 10 days.
Also got the motor bolted in but don't have the tranny cleaned up yet.
Bryan
www.gmtruckshow.com
Old 06-22-2008, 07:54 PM   #220
gringoloco
A guy with a truck
gringoloco's Avatar
Lookin' good! I like the wheels Have you figured out how to wire up that alternator yet?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-22-2008, 08:01 PM   #221
5150
C10 Club Tennessee
5150's Avatar
nope, not yet. I wired one up on my stepside, but don't remember how I did it or where I got the info on how to do it.
If you find it let me know
Bryan
www.gmtruckshow.com
Old 06-23-2008, 01:28 AM   #222
gringoloco
A guy with a truck
gringoloco's Avatar
I just wired mine up tonite. Looks to be the exact same setup as yours. Stole mine off a '94 S10 Blazer 4.3 Vortec. The 'L' terminal needs resistorized(?) 12V switched; the 'F' terminal gets 12V switched. I used a resistor from Radio Shack to simulate the light bulb for the 'L' circuit- everything I've read says without the resistor or bulb the regulator will meet an early demise...
-Chris
Old 06-23-2008, 08:17 AM   #223
5150
C10 Club Tennessee
5150's Avatar
If you don't mind when I'm at that point I'll hit you up on a PM.
Bryan
www.gmtruckshow.com
Old 06-23-2008, 04:08 PM   #224
Putter
More Cowbell....
Putter's Avatar
On mine, I actually installed a colored bulb (non-LED) under the dash. It is "on" when the key is on but the alternator is not turning. So, in my case, if I throw the belt or the alternator stops putting out power, the bulb will light...like a 'warning' of-sorts.
Keep those pics coming. That thing is starting to take shape. Wonder if Craig regrets yet???
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 06-24-2008, 11:39 AM   #225
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Wow, I missed this one for a while Looks good B!
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
