Old 04-27-2014, 07:02 PM   #201
portworks
Re: Tail light fuel filler
Bump.
portworks is offline   Reply With Quote
Old 04-29-2014, 03:33 PM   #202
utee05
Subbed.
'72 GMC Super Custom 1500 350 V8 w/AC
utee05 is offline   Reply With Quote
Old 04-29-2014, 05:23 PM   #203
Elliot949
Elliot949's Avatar
Originally Posted by HuggerCST View Post
Sorry guys, I haven't been on much to check this thread lately. The main problem is no time, but I will update you when I can. Thanks
Well If I can get the Make and part Number of the Filler cap then I will order it and reinvent the wheel and try to do this myself... I would appreciate any info you can supply me with... Thanks... Dan
Elliot949 is offline   Reply With Quote
Old 04-29-2014, 08:40 PM   #204
portworks
Not sure, but it looks like he modified a white cap #6993A
Old 04-29-2014, 09:40 PM   #205
Elliot949
Elliot949's Avatar
White Cap?...
Old 04-30-2014, 07:26 AM   #206
portworks
white cap brand. It is a Marine part . #6993A
Old 05-05-2014, 03:35 PM   #207
HuggerCST
HuggerCST's Avatar
I was using a stainless, push-up marine style filler, labeled "water", and machining the mounting lip off of it. Like this one. http://www.ebay.com/itm/NEW-316-stai...vip=true&rt=nc
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 05-05-2014, 04:05 PM   #208
mcbassin
Still Learning
mcbassin's Avatar
Hey Wynne,
You have used this setup for several years now, do you have any trouble doing fillups at the pump? What gas tank are you using? I am still leaning towards a similar setup but worry about slow filling....
mcbassin is offline   Reply With Quote
Old 05-06-2014, 09:06 AM   #209
HuggerCST
HuggerCST's Avatar
I have one of Fuelcellguy's tanks, and don't have any trouble with slow filling, but I usually don't hold it wide open. I usually fill it at about 1/2 to 3/4 speed, which is plenty fast enough, and it's only a 16 gallon tank, so it doesn't take long. If I top it off too fast, it will burp fuel out when it gets full, and if I pull into a station that has the big boot around the nozzle, I may have a problem, but so far it hasn't happened. I think the key to fast filling is being able to vent the tank as fast as you want to fill it. I have mine vented with a 3/8" hose at one corner, and another 3/8" hose running from the top of the tank to the filler, just below the gas cap. It works ok, but I think a 1/2" vent line would be better.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 12-20-2014, 06:05 PM   #210
6L72C10
6L72C10's Avatar
Any update on the hidden fuel filler
6L72C10 is offline   Reply With Quote
Old 10-27-2015, 03:57 PM   #211
jks67ss396
bump
jks67ss396 is offline   Reply With Quote
Old 10-27-2015, 06:51 PM   #212
portworks
I was able to fab everything up for little cost with a Marine filler neck /cap assy, handsome plate metal from Atwoods. It took me 2 or 3 times making one from scratch to get it right, but once you get started it's not that big of a deal. You just have to cut away quite a bit behind the drivers tail light assembly.
Old 10-27-2015, 08:12 PM   #213
jks67ss396
thanks man. i have no problem making one from scratch. its just with work and the kids, it would be great to just buy one pre-fabbed, ready to tack in there
ive seen one guy run his through the reverse light. after youve done this, do you think that would be easier or harder than the tail light?
thanks
Old 10-27-2015, 08:43 PM   #214
portworks
I understand about you not wanting to have one yourself. I felt the same way, but not being able to buy one, I had no choice. I definitely would not try to do on through the reverse light, there is not enough space!
Old 10-28-2015, 12:07 PM   #215
Racinaround
Racinaround's Avatar
I still have the pattern in the laser cutter
I can make more, I just got so much crap from some guys on the board about it
I just let it lay
$10 Flat or $25 bent up
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
2008 Dodge HD3500 Tow Rig
Racinaround is offline   Reply With Quote
Old 10-28-2015, 06:53 PM   #216
nlped
nlped's Avatar
I just let it lay
I'd be interested in a bent one, but what's involved to install?
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 10-28-2015, 11:56 PM   #217
wesmigletz
wesmigletz's Avatar
I just let it lay
I'd be interested in a bent one, too
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
Old 10-31-2015, 11:44 AM   #218
6L72C10
6L72C10's Avatar
I just let it lay
I would be interested in a bent one as well maybe 2
Old 10-31-2015, 11:48 AM   #219
74baggedbug
I just let it lay
Intrested in a pre bent 1 also
74baggedbug is offline   Reply With Quote
Old 10-31-2015, 06:55 PM   #220
piecesparts
Parts and more parts
piecesparts's Avatar
What is needed to order a bent piece from you? Be happy to work it out, however you want.
Frank
Frank
piecesparts is offline   Reply With Quote
Old 11-12-2015, 09:51 PM   #221
MATT SHIELDS
MATT SHIELDS's Avatar
I'd be interested in a bent one as well. Thanks.
MATT SHIELDS is offline   Reply With Quote
Old 11-12-2015, 10:08 PM   #222
Possmguts
Possmguts's Avatar
Here's my version of a tail light fuel filler. I would have taken better pics of it as it went together, but my fab skills leave alot to be desired. It was fun though, and turned out ok I think. It still needs some fine tuning(rubbing, spring tension, paint, etc), but I'm satisfied so far. Filling the tank will be the real test. Thanks to you guys that helped with ideas and parts.
What a cool way to do this. I have actually been brain storming on how and where to do a filler hole... This may be the one. Give me something to look forward to when I get to the bed.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 11-12-2015, 11:02 PM   #223
Elliot949
Elliot949's Avatar
here is the one in my 67... It is roughed in at this point so final adjustments need to be completed...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Old 11-12-2015, 11:14 PM   #224
Possmguts
Possmguts's Avatar
Is this something that can be done with no tail light trim??
Old 11-12-2015, 11:15 PM   #225
Elliot949
Elliot949's Avatar
Sure... it wouls actually be easier...
