#201 |
Resident of Here
Re: 72 K20 build thread, need good name
You have one...not a 67-72, but you do.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck
#202 |
![]() Join Date: Apr 2007
Wow it's been a long time since an update. Since my last post I've done a few things, and am now cruising ahead with good momentum...FINALLY!
The hood is primed with more Southern Polyurethanes epoxy top and underside. Cleaning the underside down to clean bare metal was a very time consuming and frustrating experience. Since I also have the normal slight crease/bend in the center of the hood ridge, I built a little brace on the underside to keep constant pressure against that point. With the addition of new insulation pads, I am hoping this won't happen again. I'll post a good pic of this tomorrow. Plan for the underside is to go two coats of the smooth dark gray Durabak in the skin, and then satin or gloss black for all the framing. Same deal for the inside of the fenders. That is the plan for tomorrow, one more coat of masterseries and then on to the Durabak. I finished the body work on the inside of the cab. Had to do quite a bit of rust repair, so all that was replaced with new metal. I cut the dash (bring on the hatred) to accommodate a double din stereo and that was alot of work as well to get it to look good. After probably 20 rounds of filler, then sanding, I got it just about right so I could seal it all in with another coat of epoxy. After that I seam sealed the entire inside cab with the 3M Automix 2 part sealer and it is the sh!t! Went on well, and dries quick. I'm not too concerned with the looks, since all the lower areas will be under 2-3 coats of more smooth Durabak. This way the floor will be well protected for hopefully ever and I can even hose it out if I ever need to. I built it like a boat, so there is no way for water to escape! The seam in the top inner cab I took more time on for looks since that will be visible. More to come more often than it has been I hope. Thanks for looking
Maj USAF 71 K5 Blazer CST 72 K20 HT383 NV4500 Mass-Flo EFI 71 K10 LWB 52 Dodge Power Wagon 67 Dodge WM300 Power Wagon 48 Dodge WDX Power Wagon My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=239487 |
#203 |
wow, I forgot about your truck!
How do you like the masterseries? I used that on my frame... are you going to epoxy or paint over it? Be sure to do it within two days or you'll have to scuff it... Looks good
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#204 |
Forgot about my truck??!! How dare you...
I've used the Masterseries before and I'm beginning to like it more than the Rust Bullet. I think it is thinner and dries much quicker. It also seems to have a longer shelf life. I'm going to go directly over it with the Durabak, so hopefully I should be good to go. Think you'll finish before me? We should go cruising when we're both done
#205 |
you'll be done first, remember... you're coming up here to paint my truck after you do yours....
#206 |
Two posts in two days! Making good progress.
Today I sprayed the smooth Gray Durabak over the interior and the underhood skin. I bought a 2.8 nozzle for my Turbine HVLP system so I could spray. The first problem I ran into was that there were alot of small chunks in the durabak that I have to filter out. The usual paint strainers are way too fine and the Durabak wouldn't even go through it, so I had to come up with something else. Ended up using 220 grit drywall sanding screens. Worked pretty well. It did not spray as well as I was hoping, as it spattered quite a bit. I could have thinned it a bit with Xylene, but it was kind of runny as it was, so I had to settle. I was really hoping to put this on nice and thick, but it wasn't going to happen. I'm going to see how it is when it dries and I'll go from there. I can always brush or roll it on too, but I wanted a smooth finish. Oh well. I'll post more pics after it dries.
#207 |
More
#208 |
I'm gonna have to look that stuff up, is it the final coating then?
you know if you throw a handful of sand then it will be like a navy ship! oh wait, you're Air Force!
#209 |
the coating looks pretty good
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#210 |
Lurking Member
How's the project coming? I look forward to seeing if there's anything new.
JJ 72 GMC 1500 350 4 Speed, stone stock baby!!!!! 72 GMC K-2500 350TPI 700R4 For those who fought for it, Freedom has a flavor the protected will never know.
#211 |
Uh oh! Finally busted...
I've been really bad about updating this lately. I have made some progress and hope to post some new pics tonight. Thanks for keeping me honest
#212 |
Ok, well here's a little update. I wasn't happy how the smooth Durabak sprayed, it seemed too thin and runny, so I bought some more of the Durabak with the rubber particles in it and rolled on a few coats over the smooth coats. I like it much better and it seems to be more durable. If I wanted to, I should be able to hose off the interior without worrying about rust.
I also did the underside of the hood skin with it and then painted all the framing with gloss black Masterseries paint. So now the rush is on to get the cab/doors/fenders/hood ready for the painter. Yes, I have made the decision to outsource the paint simply because I think it will take me a year to prep it all myself and after all that time I would want a professional job. I found a guy in MD, http://www.mikescustompainting.net/Home.html who is really nice and does good work. He's charging me $2000 for a complete paint job for all that. That might increase when he sees it...Tax return will go to that... Told him I already have everything epoxy primed, and that he'll just need to do some filling, block sanding and finish from there. No assembly since I'm giving it to him in pieces and want it back in pieces. Then I should be able to fly putting it all together...
#213 |
that looks pretty good now...
giving up on the paint huh? whatcha gonna do with that fancy HVLP setup?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 01-21-2009 at 08:29 PM. |
#214 |
VA72C10
![]() Join Date: Mar 2008
Saw this truck in person today...that durabak looks tough and pretty sweet.
Now get to work Tim
Looking for a 67-72 swb or blazer project in or around VA.
#215 |
![]() Join Date: Apr 2008
Keep up the good work.What happened to the 67-68 chevy front end?Did you use the GMC instead?
#216 |
I've been going to a 67-68 GMC front end all along. So I have that 67 chevy grille that I will end up selling unless I decide to use it on my 71 Blazer if I convert that to a 67-68 front clip
#217 |
Nice build. What color u going with?
MY POND TRUCK BUILD http://www.67-72chevytrucks.com/vboa...d.php?t=297393 |
#218 |
Right now, I'm thinking Black, but as with everything else on this build, that could change tomorrow
#219 |
ok, bringing this one back from the dead Tim....
what's going on with the truck? I'll PM you my number and we can chat about the details and the hood.
#220 |
I knew you would be pinging me for progress! I'm still doing bodywork, but should be making some posts this weekend. I'm getting close to paint, but I've been saying that for about 9 months!
#221 |
I just went back through your build. How's that paint system doing with primer? I know you said that you found a good painter in your area for $2K, of course that was 2007 prices!!!
![]() Let me know if you want to sell that turbine system when your done too. Might come in handy on my build as it is low on funding as well.
#222 |
Well although the photos are not that exciting, I did reach a pretty exciting milestone today. I'm happy (finally) with the panel gaps and alignment. I drilled my alignment holes in all the panels and took them off for the last time. Next time they go on they will be painted! I'll be painting all of the panels off the truck.
#223 |
Took the day off to finish some progress I made this weekend. I finished all the major body work on the cab and sealed it all in a coat of epoxy primer. I then went to town with the self leveling seam sealer on the rain gutter (went on like a dream). After then I switched to the regular seam sealer for everything else.
Then sealed all that with another coat of epoxy. This morning I laid on two wet coats of 2k Primer. I bought this from SPI in black, so I can really see where I need to do more work. Finally some visible progress...I took advantage of Eastwood's 25% off sale on Monday so I have plenty of sandpaper comin...
#224 |
Looks nice, coming up to Carlisle in a few weeks?
That paint system did a decent job, let me know when it's for sale!!!
#225 |
VA72C10
Looks good. Nice progress!!!
| Bookmarks |
