08-02-2007, 09:56 AM | #201 |
Re: Killers 5.3L install
08-02-2007, 09:57 AM | #202 |
08-02-2007, 10:13 AM | #203 |
A guy with a truck
Reverting to the old technology-putting the knock sensors in the side of the block like the old LT-1s. More like two steps forward, one step back- the DOD is worth it...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-02-2007, 12:34 PM | #204 |
ahh, i follow ya now....yea i agree the KS location is very minor compared to having the DOD..
08-02-2007, 02:38 PM | #205 |
Questionable
I don't really care for DOD, you're only looking at a 1.5-2.5 mpg gain from it on the highway, tops. Just doesn't seem worth the effort and programming to keep it. I like the general principle, but until they are adding 5-10mpg, it's not of interest.
If my engine came with it, that's great - but for the sake of ease, I think I'd rather go non-DOD for the reduction of hassle and stuff in the way. On another note, where did you find your metallic heat sheild tape? I was hunting at Summit a short while ago and couldn't find anything.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
08-02-2007, 02:49 PM | #206 | |
"DON'T CARE FOR IT"...dude your the one that turned me on to this motor....come on show me some LOVE!
R.I.P. Killer 71 10/26/07 Last edited by killer71; 08-02-2007 at 02:56 PM. |
08-02-2007, 04:21 PM | #207 |
Questionable
i know, i know. it's a killer setup! yours is way better than mine. mine is just ... different. look on the bright side: you can run ethanol, i can't. you'll get better gas mpg than i will. your engine is newer and less mileage. you paid less $$$ for your setup yours is almost done, and mine is almost done...but drastically diff't schedules. yours will be better installed than mine hell, once i'm done, i need to drive over to 68ss' house one weekend and beg him to help me rewire the engine harness
08-02-2007, 04:32 PM | #208 | |
08-02-2007, 05:09 PM | #209 | |
Not that much love! na j/k, all i can say is i truly envy you and 68 ss for the wealth of info you guys have up there in your noggins for such young guys. A fella can truly learn a lot from you two.
R.I.P. Killer 71 10/26/07 |
08-02-2007, 06:02 PM | #210 |
Questionable
68ss has me stomped in the knowledge dept in these swaps, i just share what i hear and learn (which is usually mostly correct )
08-02-2007, 10:08 PM | #211 |
killer is finally done with mocking everything up.... got the rear disc brake kit installed and the right fittings came in from summit, so the fuel system was completly mocked-up as well....once it was all together, i started tearing killer down to the frame....i got further then the pics show, all i lack is removing the front suspension....this will be removed tomorrow morning and weather permitting will be gone to the sandblasters by noon....
and here is another sneak peak of this 'coolness'.... Last edited by 68 short step; 01-10-2008 at 08:53 AM. |
08-02-2007, 10:08 PM | #212 |
08-02-2007, 10:13 PM | #213 |
08-04-2007, 10:57 AM | #214 |
got killer all striped, and off to the sandblasters....this frame is pretty clean to begin with... so it'll come out real nice!!
08-04-2007, 11:29 AM | #215 |
Nice jack stand on the front end, where I can I pick one up at?
And Dude where is my truck???
R.I.P. Killer 71 10/26/07 Last edited by killer71; 08-04-2007 at 11:30 AM. |
08-04-2007, 11:39 AM | #216 |
the jack stand is a custom speaker thats held up many of misc parts, your frame almost destroyed it, so ill put that on your tab .... and good news i got 35$ for the frame and rear end at the scrape yard...
08-04-2007, 11:45 AM | #217 |
I woulda took no less than 50$
08-04-2007, 12:39 PM | #218 |
68S.S..... I know you were looking for a career in the 'specialty' automotive field & decided it was time to start working for yourself. Are you doing this one full time or part time after 'work'?
08-04-2007, 01:38 PM | #219 |
well from now on this is my full time job...
08-04-2007, 02:07 PM | #220 |
08-04-2007, 04:11 PM | #221 |
Good for you. Good luck on your new path. If you ever require a helping hand, I'm not too far away.
Nice Firebird BTW.
08-05-2007, 09:12 PM | #222 |
got all the pieces back from the sandblasters,they turned out great, and headed to the powdercoaters first thing in the morning......
08-05-2007, 09:42 PM | #223 |
Looks like I won't have to worry about rust for a while!
08-05-2007, 09:46 PM | #224 |
08-05-2007, 10:30 PM | #225 |
I love how the metal turns out after blasting... such a fresh start isn't it? Nice work and nice project...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
