#201 |
Re: project INCREDIBLE HULK 6.2L with 6L80E
Ok, couple questoins about the trans cooler...First, how well do they work compared to the in radatior ones like stock? Second what size is it? And where do you get your braided lines and fittings? I am looking to do this mod on my truck, and i see you have done it to a couple ones u have built. Thanks and keep up the good work.
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
#202 | |
PITbut
#203 |
me 3
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project |
#204 |
it is a 18" dual row cooler, can be got from summit, jegs, ebay, etc.....
i use -6 AN fitngings and -6 braided lines, these too came from summit/jegs......compaired to the "traditional" rad. mounted ones this cooler is designed to disapate heat by haveing BOTH internal and external heat dissipating fins also this heat sink design produces high heat transfer with minimal airflow... unlike the traditional radiator mounted ones..... haveing said that it is designed for a non-lockup converter trans cooling needs, so with a lock-up converter, it should work out really well.. |
#205 |
I was thinkin about putting this on my 4L80E, so it'll be good?
#206 |
should be good, yes.
#207 |
a little progress to report on the hulk.....got the trans tunnel fabbed up......
#208 |
why not just kit a "high hump" and bolt it in?
nice truck though
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#209 |
because i wanted one customade!
you'll see why later! |
#210 |
got the wire harness fitted in the old vent hole......it fits nice and will look great tucked under the dash...
#211 |
Tasty Cakes!
I tried to look back and see if you said anything, but there is sooo much stuff to look through! Did you leave the outer part of the air vents open to allow for drainage? Or do you have some way of cleaning em out? Just wondering since you blocked them off from the inside. I do like how you mounted your fuse block, looks sharp!
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
#212 |
yes i left a section open for drainage/debris, ill snap some pics of this
#213 |
Tasty Cakes!
Are you French?!
#214 |
#215 |
AX ME HOW I KNO DIS!!! ![]() ![]() Last edited by 71Hulk; 07-21-2008 at 04:52 PM. |
#216 |
that's a nice little mod.
WIth the shape that mine are in I might do the same, but I would have to be running A/C since I will have no other ventilation... Whats the plan for the wires through the firewall?
#217 |
here are the drainage holes...the is the pass side (all finished up... and the DR side about to be welded in and how it looks from the inside,,,,
#218 |
getting some progress....
got a head start on the wiring of the truck....im gonna run the wires for the air ride sensors through a bulkhead ,in the cab, to the air ride computer....also got the electric brake system (no vacuum booster), and started to moc it up.....but before i can install in, i neeed to make the driver side firewall smooth and symetrical with the pass. side......also still chipping away at the dash... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by 68 short step; 08-16-2008 at 12:52 AM. |
#219 |
Tasty Cakes!
Lookin good! Another question about the air vent/cowl area. Since you have the air vents blocked off, couldn't you have just left the whole bottom of the cowl area off? Just asking b/c it seems like trash could still get caught it there. If it was completely open it would be more likely to just fall out. I think your way will work fine, b/c I'm assuming your ride won't be parked under a tree much.
![]() Oh and what is that electric brake setup u have?
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado Last edited by Riveted1; 08-16-2008 at 03:12 AM. |
#220 |
68 short step wheredid you get that bulkhead connector from? did it come with all the pins?
Very Nice work by the way on both of your trucks!! |
#221 | ||
and thanks for the complaments |
#222 |
a little more progress this weekend....
got the mirror image of the pass side transfered to some metal. then tacked it into place.....my wife helped me a bit on the welding.....smoothed the welds and now i just need to make the other peice(held on by the magnets)....then ill build a stiffener for the firewall to support the weight of the brake set-up.... ![]() ![]() ![]() Last edited by 68 short step; 08-17-2008 at 07:26 PM. |
#223 |
68 short step,
Looking good. I wish my wife knew what a welder was. ![]() Question about the tranny. Will they fit any LS series engines? I've got an LS1 and I'd really like the potential fuel economy of the 6sp and I don't want to do a standard. Any idea what kind of compatibility issues I might have? I currently have a 4L60E.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
#224 | |
![]() Last edited by 68 short step; 08-17-2008 at 08:16 PM. |
#225 |
I kinda figured that would be the case. Thanks for the info.
