01-05-2011, 12:02 AM | #201 |
Under Construction
Re: MisterE72's Build thread: Too much Homework
Forgot to mention to fit the inner kick panel as well.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
01-05-2011, 11:19 PM | #202 |
Keep Your Nose Clean
Allright, I tacked in the lower a-pillar, welded in the floor section and kick panel, and test fitted the outer rocker. All looks good so far. I still have to get the door on befor I weld in the outer rocker. Tips and hints welcome.
01-06-2011, 09:15 AM | #203 |
Under Construction
this is what we did.......
use low profile sheet metal screws to hold the outer rocker in place while you test fit the door. if all is well you can then spot weld (rosette) weld it in. what we did was screw the outer rocker on, fit the door. once the door was fit, marked the hinges. drilled through the hinges into the cab to use for reference later, removed the rocker and drilled holes to use to spot weld to the cab, finish welding the a pillar, then screwed the rocker back to the cab as it was previously and started spot welding it in slowly, lastly remove the screws and weld up the holes... good luck, looking good sir.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 01-06-2011 at 09:17 AM. |
01-07-2011, 12:28 PM | #204 | |
01-07-2011, 12:33 PM | #205 |
I mocked up the door and i am satisfied with the fit.I had the left cab corner changed a couple years ago and never liked the fit so i cut it out. I tried to get it ti fit right but I took off too much metal. Time to order another corner.
01-07-2011, 01:17 PM | #206 |
Under Construction
that's how we learn. sometimes you can add some scrap metal back to make it work, but sometimes it's better to start with a new piece. Great progress, stay with it....
01-07-2011, 11:36 PM | #207 |
I love this thread... subscribing to it! I am a complete noob to all of this so I love the pics and the problems you are posting. Im about to start a project so its really fun to see how this is coming along. Good job Mr.E!! keep on posting your process.
01-08-2011, 12:01 AM | #208 |
At least your jumping in with both feet! The feeling of satisfaction when its done can not be compared to having it done by someone else.
Keep it up! You're motivating me! BTW, we need to get all the central valley guys that lurk here together sometime this summer....... Jay |
01-08-2011, 12:57 AM | #209 |
VA72C10
Just found this thread for the first time and read through. Looks like good progress is being made now! Frame looks great too (bet it's a little dusty now )
Looking for a 67-72 swb or blazer project in or around VA. |
02-02-2011, 01:34 AM | #210 |
Any Update on the progress?
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
02-12-2011, 10:41 PM | #211 |
I got the left cab coner last week and had time to install it today. I am satisfied with the fit. Check it out.
02-12-2011, 11:09 PM | #212 |
it looks good! nive job aligning and welding
03-01-2011, 12:26 AM | #213 |
Greetings folks. How's this for deja vu, I decided to redo the right cab corner and lower right a pillar. I had some difficulty with the fit on the cab corner, but overall it is better than what i replaced.
03-01-2011, 09:26 AM | #214 |
Restoration Virgin!
Good work MisterE....and we didn't have to wait a year for progress
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
03-01-2011, 11:35 AM | #215 |
Good one GCB. I even started taking off the dates from the pics so you all wouldn't notice my slow progress. I'm on it now though.
03-03-2011, 12:43 PM | #216 |
Under Construction
Nicely done MisterE!
03-03-2011, 01:02 PM | #217 |
Looking good Mr E keep it up!!
04-19-2011, 11:41 PM | #218 |
Still Learning
Great project MrE! just got through the whole thread. I love the chassis! it's amazing. I know how much time, money, and work you have in it. I am right in the middle of mine. Short on cash, I am fabbing as much of my own parts as I can. Still trying to pull the trigger on those high$$ brake lines. Yours turned out great. Nice work on all the rust repair. I'm past "most" of that already. Hang in there I know how long one of these frame off builds take.
04-22-2011, 09:20 AM | #219 |
PROJECT 7DEUCE
Looking good mre keep up the good work..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-25-2011, 02:22 PM | #220 |
Greetings everyone, I've had some time this summer to work (rework) on the truck. I was never happy with the right floor fit to the inner rocker and therefore kick panel...so I tore it all out and started with installing one of those new inner rockers with a part of the floor. I then fabricated a floor section. The result was much better. Everything lined up perfect.
07-25-2011, 02:41 PM | #221 |
Oh yea, i forgot to mention, i picked up this gauge cluster and painless wire harness. My plan is use a polished billet bezel with the gauges.
07-25-2011, 04:12 PM | #222 |
Still Learning
Nice work on the floor. Diggin the cluster too. More pics...
07-26-2011, 10:38 PM | #223 |
Under Construction
Very nice work Mr.E!
07-26-2011, 10:45 PM | #224 |
Looking good!
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
07-27-2011, 08:26 AM | #225 |
Restoration Virgin!
wooohooo...progress Mr. E....glad you got it back right!!!!
wow only 5 months for an update this time
