Old 02-26-2010, 02:31 PM   #201
nuke1
nuke1's Avatar
Re: 69 cst-10
Originally Posted by highperf4x4 View Post
Awesome. It sounded like you were saying you had a problem with your power steering until someone told you to put some fluid in it.
I knew that couldn't be right.
LOL, Perf, that would only be you with the trouble of the p/s fluid. SMRT, remember. Sorry had too.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-26-2010, 11:58 PM   #202
highperf4x4
Re: 69 cst-10
Actually I have a rigorous routine when installing/prepping a motor/accessories but I thought it sounded funny.
highperf4x4 is offline   Reply With Quote
Old 02-27-2010, 12:38 AM   #203
ripdog28
ripdog28's Avatar
Re: 69 cst-10
That is some funny stuff.... I may have to redo some of my brake piping. The prop valve has a small leak from the Master Cyl to the prop valve on one of the fittings. I tightened it down but still leaking a little. Also need to get a new flex hose for the pass side front. Plugged up somehow, can not get it to flow. little crap always pops up to slow ya down.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 02-27-2010, 12:43 AM   #204
sourkraut
sourkraut's Avatar
Re: 69 cst-10
can you hit tht hose with some air from your compressor?
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 02-27-2010, 06:46 AM   #205
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Yea, ill be trying something. Just me being lazy and getting POed because it is not just working perfectly like that ever happens. a week or two and it should be ready to smoke em. When i get POed i just start her up and it puts a smile on my face. It has been ideling at about 800 rpms
Update, I decided to turn on the engine, you know vacume assisted brakes, and bam it cleared out that plug fast. So lots of fluid on the floor but i was pumped. And just a little more tightening (more then id like with brass) and all the leaks are gone.
69 c-10 BBC
Old 03-09-2010, 09:05 PM   #206
ripdog28
ripdog28's Avatar
Re: 69 cst-10
So i moved the large fuel filter from the firewall to the frame rail. That stopped the damn leak i have been freaking out about. So no fuel leaks or Brake fluid leaks. Just need to finish the wiring i have been putting off and ill be good.
69 c-10 BBC
Old 03-09-2010, 09:52 PM   #207
highperf4x4
Re: 69 cst-10
But the brakes are working good now right?
Old 03-10-2010, 12:33 AM   #208
ripdog28
ripdog28's Avatar
Re: 69 cst-10
From what i can tell, they are. I have not driven it yet but when the engine is running they have tons of pressure (like they should). Im happy with them ATM.
69 c-10 BBC
Old 03-10-2010, 12:38 AM   #209
highperf4x4
Re: 69 cst-10
Awesome!
How long till burnout?
Old 03-11-2010, 07:45 AM   #210
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Im hoping 3 weeks but i have not hit one time target this whole build. I need my front window, Seat will be done in a week, and to finish some lighting, and update my registration. Not much but i know it will take longer then id like.
69 c-10 BBC
Old 03-11-2010, 11:01 AM   #211
highperf4x4
Re: 69 cst-10
Yeah it always does but I'll be pullin for ya!
Old 03-16-2010, 10:08 PM   #212
ripdog28
ripdog28's Avatar
Re: 69 cst-10
still need to be adjusted but they fit great. it is a 40/20/40 split bench. ill be getting the shifter mounted tomorrow then finish the wiring. I am so freaking pumped about this.
69 c-10 BBC
Old 03-16-2010, 11:38 PM   #213
highperf4x4
Re: 69 cst-10
Ok, so when do the door handles get mounted?
And where did you get them seats!
Old 03-17-2010, 01:38 AM   #214
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Ill worry about the handles after it is driving. Seat is from here. I thought i ordered the American lowback but when i picked it up it was the American Classic. It still looks good, i just removed the headrest. I didnt feel like waiting another month for it. was about $1k... Im happy...
69 c-10 BBC
Old 03-17-2010, 09:03 PM   #215
ripdog28
ripdog28's Avatar
Re: 69 cst-10
I have the biggest smile ever. Just a quick in and out of the garage after the seat install and the shifter hook up i was ready to get down. Im thinking i have about a 3000 rpm stall or maby the trans is cold but its working. Only touched the throttle and it left these. i didnt want to go crazy.
69 c-10 BBC
Old 03-17-2010, 09:29 PM   #216
ripdog28
ripdog28's Avatar
Re: 69 cst-10
So i tried to move it after i got the shifter hooked up and it didnt move. was about 3k before it started to crawl. I had to shift in and out of reverse before it moved. when it did it was really slow at 3k. Im a bit scared that ill need another trans but i know it is just cold. Ill have to let it warm up for a bit next time.
69 c-10 BBC
Old 03-17-2010, 10:38 PM   #217
highperf4x4
Re: 69 cst-10
Hmmm, this is an old tranny? Are you SURE you got enough fluid in it?
It would be awful hard to cruise around any with a 3000rpm stall unless you leave it in 2nd.
Old 03-17-2010, 11:31 PM   #218
ripdog28
ripdog28's Avatar
Re: 69 cst-10
I thought of that. Im going to start her up and let it run for a few min next time then try it out. Ill check the fluid then also. Today was just a quick test to FEEL HER UP. Im sure she is a little low on fluid but ill do that when it is all warmed up. Trans has a cleaning up about two years ago.
69 c-10 BBC
Old 03-17-2010, 11:32 PM   #219
highperf4x4
Re: 69 cst-10
Right on. Can't wait for the vid!
Old 03-19-2010, 10:36 AM   #220
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Dont you love spending hours working on something like electrical wires and you cant get it fixed? Then a day or weeks later, you walk in and just turn on the ignition and hit the lights and BAM it all works... HAHA I just laughed about that. Getting irritated about the lighting not working and this morning i get off work and drink a beer and go hit the ignition and lights pop on. Can not believe it.
69 c-10 BBC
Old 03-19-2010, 10:52 AM   #221
highperf4x4
Re: 69 cst-10
weird, mine did the same thing..........
Old 03-19-2010, 09:21 PM   #222
sourkraut
sourkraut's Avatar
Re: 69 cst-10
wiring fairys were over last night!
Old 03-23-2010, 01:47 AM   #223
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Took it for a little trip around the apartment complex today, talk about looks of discuss. I dont think they like BBC with just headers and mufflers with no piping. This biaaatch is nasty. Just a touch at about 1k that bumpes the RPM's to 3000 was making it lay sideways. didnt go crazy just a little on and off. Got to tear apart the pump again. Something must have got in it and wedged between the gear and housing. Im debating on replacing it already or just moving the 10 micron filter to just before the pump and replacing the 40 micron. IM SO FREAKING PUMPED.
69 c-10 BBC
Old 03-23-2010, 11:06 AM   #224
highperf4x4
Re: 69 cst-10
Man, I can't wait for the video.
Old 03-23-2010, 11:38 AM   #225
ripdog28
ripdog28's Avatar
Re: 69 cst-10
Wife was sleeping when i went out. got dark after that. will get one up soon.
69 c-10 BBC
