#1 | |
Conversion Truck Addicted
this truck i just bought im going to rebuild to a Great looking Daily Driver,
the frame and engine is like new the bed and front end is decent but doors, cab and most interior is shot and going in the trash this truck has been in denmark since 1991 and from 84 to 1989 it has been running with trailers for a circus in oklahoma specs 1984 Chevrolet C30 Dually Choo Choo Custom 6.2 Detriot Diesel 79.6xx Original miles with Dual Exhurst 4 Speed Stick Shift Plans Cab with doors and most of the interior going to the junkyard and new will be imported rust free from cali and the the bed is going off as well and the frame is going to get soaked in undercoating so it wont rust (live by the water so its very bad with rust here), the engine will get a tune up and maby try to get it to give out a little more power AC is going to be removed and a normal heater going in insted Paint Fire engine red and white on both sides going with a stock look thats all for now will post more later now time for pics ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() going on truck to the ferry as the brakes was sezzed ![]() ![]()
Thomas Quote:
#2 | |
Re: 84 Crew Cab Rebuild
![]() ![]() Next day picking it up ![]() ![]() towing it the last bit home as both batteryes died over night ![]() ![]() ![]() Home finaly ![]() ![]() ![]()
Thomas Quote:
#3 | |
![]() Original radio Works still ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Thomas Quote:
#4 | |
Wow bad doors and rocker panels
![]() ![]() very old florida licens plate ![]() ![]()
Thomas Quote:
#5 | |
a little progres but not much
![]() Last inspected in the states in 1989 in oklahoma but on florida tags ![]() ![]() ![]() ![]() ![]() ![]() ![]() Anyone know what these seats are out of whoud like to find a new set as they are very comfy but the driver side is very bad ![]() Getting ready to pull the bed tommrow
Thomas Quote:
Low & Fast!
Wow! That truck has been all over the world.. Very cool.
And on the seats it looks like they are some custom seat nothing that I have seen before.
GoatLube Experss
![]() Join Date: Oct 2009
that is the same seat's mine has , except mine are tan . mine is a Choo Choo Custom as well !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#8 | |
can we get some pics THANK YOU
Thomas Quote:
Happy to be here
![]() Join Date: Mar 2000
Your truck was a Choo-Choo Customs. They had their own seats made. Your best bet is to have a local upholstery shop try to restore them.
I like the special edition badges.
#11 | |
More progress
Cab Fenders and Bed are now of and finaly gets to see the frame and it looks good but what a load of work to get everything of Front Fenders off just need to get the inner fender off both rotten bad ![]() Got Rust? ![]() Bed off lighter then we expected ![]() ![]() ![]() They had welded on Hitch to the bed and frame what a pain to get off im going to clean up both hitch and bed around the opening and just leve it like its with maby a rubber strip around the hole in the bed so it dosent look to bad ![]() Cab lifted on the rear of the frame rails found out the the transmission was only held in place with 1 bolt on the Bell Housing and the drive shaft missing the nut on the crossmember and other 3 bolts on the transmission ![]() ![]() Cab of and just going to the some sheet metal of it and the Vin number and then its going of the junkyard ![]() ![]() Plans for the next few weeks before the cab arives, clean up the frame and paint it, undercoat it, new brake lines, new fuel lines, sand and paint the fuel tanks, rebuild front calibers, 3" Stainless steel exhurst with home grown headers and stacks in the bed, get the heads of the engine and get the of to my friend so he can do his magic and then paint the engine, new shocks Rancho RS5000 more will proberly come but thats plans for now
Thomas Quote:
Low & Fast!
No!! Don't put the stacks in the bed! It Looks cool with out that..
And you have been working you but off on this thing, keep up the good work.. ![]()
#13 | ||
Thanks i have been really working hard to get so far so we could close the gates on our garage. as we had 2 thin wood panels so it woundt look to inviting for theifs ![]() i cant wait to this thing on the road its the only one in town ![]()
Thomas Quote:
#14 |
Low & Fast!
I would say so, will it be to wide for some of your roads?
#15 | |
it bearly fits on the small roads if it had been like 5 inch to each dually fender it would have been illegal
Thomas Quote:
#16 | |
got a little done today
Intake Manifold is now off going to pull the heads tommrow and get them to off to be modified ![]() ![]() ![]() Both Tanks are off need new straps to hold them on but tanks are in good shape think the Left has been replaced at one point in time ![]() Tranny is going to get new bearings and seals the clutch will be replaced ![]() Toke the brake lines off going to replaced along with the fuel lines ![]() Is this stock? it looks to be welded ![]() drums and shoes are in good condtion going to clean them and put them back together along with a new seal for in the drum ![]() Im going to start grinding down frame and get it ready for some paint tommrow ![]()
Thomas Quote:
#17 |
nice progress
So do you plan on adding a turbo to that 6.2
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
#18 | |
no Turbo i have been thinking of maby adding a Blower but i think i leave it the way it is for now
Thomas Quote:
#19 | |
OK some updates
no pics today/tonight sadly i got all paper work "title" so i can get plates for it when its done paint is half way done on the frame looks AWESOME ![]() New cab bought along with running boards and a nice Camper shell please stay tuned ![]()
Thomas Quote:
#20 | |
frame teaser
![]() first coat of paint ![]()
Thomas Quote:
#21 |
lookin good
#22 |
ouch looks like alot of rust but the frame looks good.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
#23 |
Low & Fast!
Nice! When will your cab be in?
#24 | |
late december along with a few other goodies running boards, sleeper cab
Thomas Quote:
#25 |
The frame looks great! Keep up the good work.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
