Old 02-21-2011, 12:33 PM   #201
68 TT
Still plays with trucks
68 TT's Avatar
Re: '72 Chevy SWB, Project Driver
Originally Posted by usmcchevy View Post
Need to figure out some manifolds. Mine hit the motor mount stands on both sides.
Why not just modify your motor mount stands for clearance or fabricate some that will work and keep the exhaust manifolds you have?
I built my own frame mounts for my 67 C10 so I could use a set of different vintage big block headers on it. Not too difficult. I made them come in from the bottom of the top flange of the frame rails instead of coming over the top like stock. This gave me a bunch more clearance where you need it too.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-21-2011, 03:41 PM   #202
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Modifying my mounts is plan B at the moment, right now I'm going to try some Trail Blazer SS manifolds. For $50 shipped they will be the easiest option.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-27-2011, 12:09 AM   #203
usmcchevy
usmcchevy's Avatar
Still having manifold/engine mount problems. TBSS manifolds didn't fit, haven't had time to figure out what I'm doing there. I did have time to order some parts and get a little wiring done.
There is a method behind my madness................some where
Computer was going to go inside the cab, but it just seemed too at home here.
Build thread
LSx Swap FAQ index
Old 02-27-2011, 12:14 AM   #204
67chevy1series
67chevy1series's Avatar
as always!, great progress! i hate gobbs and gobbs of wiring....
67chevy1series is offline   Reply With Quote
Old 02-27-2011, 12:36 AM   #205
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Does it still work if it gets wet/damp? Keep at it, looks complicated, My next build is gonna be LS motor I think.
John
1999 Toyota Tacoma 4x4
Old 02-27-2011, 01:03 AM   #206
mcbassin
Still Learning
mcbassin's Avatar
So what's up with the TBSS manifolds? I have planning on using some of them. Well, if I could ever get a sweet deal on some. Wiring looks good, keep it up!
mcbassin is offline   Reply With Quote
Old 02-27-2011, 10:47 PM   #207
usmcchevy
usmcchevy's Avatar
The PCM was located in the engine compartment on the van it came out of so it should be ok. To me wiring isn't that hard, just time consuming.
They hit the engine stands. I really need to decide what to do.......grind some off the stands and manifolds, try some different stands or headers. I picked up a power steering box from another board member today and he gave me some V8 stands(THANKS RICK!) maybe they will work. I also played with the wiring a little more today, I need more garage time!
Build thread
LSx Swap FAQ index
Old 02-27-2011, 10:50 PM   #208
Hart_Rod
Hart_Rod's Avatar
I've got a nice set of 98 Fbody manifolds that should fit perfectly. Let me know if you need them.
R/
Hart_Rod is offline   Reply With Quote
Old 02-28-2011, 12:39 AM   #209
mcbassin
Still Learning
mcbassin's Avatar
R/
Fbody? is that a camaro with a an ls1?
Old 02-28-2011, 09:16 AM   #210
usmcchevy
usmcchevy's Avatar
R/
THANKS!!! I'll let you know.
F-bodys are Camaro's and Firebird's. If you go to post 25 there is a pic Hart_Rod posted that has pics of all the manifolds.
http://67-72chevytrucks.com/vboard/s...ight=manifolds
Build thread
LSx Swap FAQ index
Old 03-08-2011, 09:22 PM   #211
usmcchevy
usmcchevy's Avatar
Been a while. Just ordered all the fuel lines and fittings from summit and just about done wiring. Most of the loom is on still need to solder on a few more connections to the relays and tape up some stuff, then I'll post more pics.
Build thread
LSx Swap FAQ index
Old 03-08-2011, 10:31 PM   #212
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looking forward to more pics. It's coming along nicely.
--Josh
Old 03-09-2011, 04:08 PM   #213
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
So the whole dd and build as you lasted a long time haha lookin good, pretty cool these new fuelies in the classic trucks, best of both worlds, keep up the good work
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 03-11-2011, 11:12 PM   #214
usmcchevy
usmcchevy's Avatar
Thanks guys.
Ya it did
Wires on the windshield need to go in the cab, just need to drill a hole.
Little messy, but I want to make sure everything works before I finish the loom.
No circuits were integrated, every one kept the same amperage fuse they had in the van. Safer in my opinion and should I have a problem, it will make troubleshooting easier. Relays are for fuel pump, key on power and starter/neutral safety. The fuse block wires were left long so when I add E fans and headlight relays I'll have room to expand.
Build thread
LSx Swap FAQ index
Old 03-11-2011, 11:27 PM   #215
67chevy1series
lookin good! now get this thing on the road!!! haha
Old 03-11-2011, 11:42 PM   #216
usmcchevy
usmcchevy's Avatar
Oh, and Summit Racing rocks! Ordered on Monday got my stuff Wednesday morning...........minus 4 back ordered hose ends that now have a delivery date of April 21st
LSx fuel system in a box!
Shift linkage too nice for my truck.
Build thread
LSx Swap FAQ index
Old 03-12-2011, 12:52 AM   #217
gringoloco
A guy with a truck
gringoloco's Avatar
Had one of the Lokar column linkages on my Blazer. Super nice piece that takes out all the slop. If you haven't figured out the manifold/engine mount issue yet, you might try a set of 73-87 engine mounts. They are a completely different setup that frees up some real-estate in that area and updates you to the captured clamshell type mounts and bolt right in. I think I paid $10 for my last set at the pull-a-part. FAQ write-up here.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-12-2011, 05:18 PM   #218
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice build thread and congrats on the new one..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-12-2011, 11:31 PM   #219
usmcchevy
usmcchevy's Avatar
Thanks guys! I'm looking into the the 73+ mounts.........still not sure what way to go.
Build thread
LSx Swap FAQ index
Old 03-13-2011, 07:54 PM   #220
67shortie
Green club
67shortie's Avatar
I'm at work and can't see the pics, you have 6cyl frame mounts in there? If so, I swear I read that they are shaped differently than the V8 mounts and these SS manifolds hit because of that.
I am using my V8 frame mounts in the 6cyl location just drilled a new hole in the crossmember for the bottom hole. I will keep in touch with you when I get my SS manifolds in the brown truck that will be at the house soon and if they work. If so then all you will be needing is V8 frame mounts, if not I need a new plan too
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 03-13-2011, 10:26 PM   #221
usmcchevy
usmcchevy's Avatar
Yes, currently I have 6cyl frame towers with the adapter plates cut down so I can use the 4.8's Ac compressor. I have a set of v8 towers sitting here that another member gave me (thanks Rick). The V8 towers are similar on top, but the dent is moved forward just a bit. I don't think its enough to clear and still allow for motor mount flex. I'll post pics tomorrow.
I've looked into:
73+ mounts, move the engine too far forward
POL mounts, move engine up and forward
ECE mounts, move engine forward and cost$
I even borrowed some 98 Firebird manifolds.......no better than the TBSS manifolds.
I've pretty much decided that I need to just modify my current mounts. Won't be too bad. I'm going to cut the towers off right above where the motor mounts sit and weld some 3/16" plate straight over to the frame then fill the gap between the plate and frame with same square tube. A couple gussets and I'll have all kinds of room.
On a positive note for the day. I hooked up a battery and she turned over and has power to all sensors! Now, do I buy HP Tuners or let a pro handle it
Build thread
LSx Swap FAQ index
Old 03-13-2011, 11:47 PM   #222
67shortie
Green club
67shortie's Avatar
Humm, makes me wonder about mine. If it's close I can shim the engine up slightly so they will.
Also, did you look at the way the V8 mounts set the engine, I mean the mounting hole is designed to raise it over the 6cyl? Worth a shot, just compare the holes I guess
If mine show up soon I will compare, I do remember the truck manifold fit no issue it was just the pass side.
Old 03-27-2011, 09:17 PM   #223
usmcchevy
usmcchevy's Avatar
I made progress!: After a couple weeks of other projects, and my whole family getting sick, I made it to the garage and got something done.
Motor mounts finished. After destroying my 6cly stands(lets no go there ), I ended up just shaving the bump off the top of a set of V8 stands. I also had my computer tuned by Black Bear Performance. Pics will come tomorrow
Build thread
LSx Swap FAQ index
Old 03-27-2011, 10:22 PM   #224
andy4x4
this is going to be a nice "dd"!!!
andy4x4 is offline   Reply With Quote
Old 03-28-2011, 12:45 AM   #225
68greg
Wow, got off work over here in iraq and read your whole thread from start to finish, got alot of ideas for my '68 when i get home to Ar. anyways belated congrats on the bith of your son mine graduates h.s. in may. and again thanks for the welcome to the site a few days ago. I'll be following this build till your done keep up the good work.
68greg is offline   Reply With Quote
