#201 |
Re: 68 C 10 stepside "My American Bulldog"
oh well that still looks like a maze i wouldnt want to deal with!
#202 |
As i recall there a few special press tools needed ( i think 2 guys and some screwdrivers work too) to swap out clutch packs and I also beleve to install one of the packs inside a band.. What i cant figure out is what the copper line goes too, I have not seen that before. Its been about 1985 since i have been inside a turbo 350.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 01-15-2011 at 09:47 PM. |
#203 |
Your just looking at the valve body, all the clutch packs and planitarys are inside the main body.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#204 | |
But 2 paint can openers, With the ends ground sharp, Grab the discs pretty well. The copper line you see, Is actually white, Stained by fluid. Going to the coil. That engages the locking torque converter. This is not a regular th350, It's a th350c. That is why the kit had to be ordered. They had the freshen up kit, But not the complete rebuild kit. Spike ![]()
68 stepside http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
#205 | |
#206 |
Grandpa in the rustmobile...
Hm not to self, PM spike for possible future auto trans rebuild
Whats the diff. between TH350 and TH350C?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#207 | |
The TH350c was the upgraded version with a locking torque converter. And used in heavier applications. But people don't like change, Even through this newer tranny could give them up to 20% better fuel efficiency. The other thing they didn't like was that you had to wire up the locking torque converter for it to work right. Companies like B&M make control boxes for this purpose, With adjustable lockup mph control. But this will cost you a few hundred dollars. I won't be using a control box. I'll simply make my own. The following are the AC Delco part numbers for the original components used for this transmission type. Vacuum Switch - AC Delco # 212-331, GM # 14032087 (Quoted price was $35.31) Brake Pedal Switch - AC Delco # D850A, GM # 25524845 (Quoted price was $11.32) Vacuum Check Valve - AC Delco # 214-479, GM # 14020691 (Quoted price was $19.91) Total cost = $66.54 The plug for wiring to the vacuum switch is not available new to my knowledge and I could not find one at the local salvage yard. Seeing that I forgot to cut the one out of the van it came out of. To make the connection I will solder the wires directly to the connector lands on the switch using shrink tubing to provide some strain relief protection. One of the wires from the vacumm switch goes to a keyed 12V source while the other wire goes to the brake switch. The brake switch has four poles on it. Two are for the lockup function and the other two are for the tail light circuit. I will have to figure out which was which by trial and error. Once I get that figured out and connect the switched 12v from the vacuum switch, I will need to run another wire from the other pole down to the solenoid switch on my transmission. The other side of the vacuum switch consists of a male vacuum connection which I tubed to the intake manifold vacuum tree. The small check valve was inserted between the switch and the manifold. That is it. (Thanks houston54 for the info) Spike ![]()
68 stepside http://67-72chevytrucks.com/vboard/s...0&goto=newpost Last edited by spike38; 01-16-2011 at 11:11 AM. |
#208 |
'67 C-10 LWB Driver
![]() Join Date: Dec 2010
nice build! i'm going to make one the engine caddies that you made! maybe two!
'67 C-10 LWB - My Build Thread ![]() '67 C-20 LWB - My Donor/ Parts truck - SOLD! '92 GMC SAFARI VAN - My Parts Go Getter '06 KIA SPORTAGE EX - My Commuter "All of this crap better make a truck!" - my wife Sue. Proud U.S.M.C. Dad! |
#209 | |
You may want to change some of the measurements. You want the bolts of the oil pan, To sit on top of the 2x6's Spike ![]()
#210 |
i bet jason is going to have a fun time with those!
#211 |
Got my re build kit for my tranny this afternoon,
So I will do that Thursday and Friday I guess. Also picked up a set of SS hugger headers this week. ![]() And, Remodeled my swap meet cart, Kind of a Gasser T bucket look ![]() What you all think, Still not done though. Spike ![]()
#212 |
dude that thing is awsome!
#213 |
Thanks, I'm looking for an old wheelbarrow tub next.
Spike ![]()
#214 |
any progress on the truck!
#215 |
Finally got my parts today.
I'll be off Thurs, And Friday. Finish the tranny then. Spike ![]()
#216 |
great! my e brake almost works i just need 3 little things thanks to you!
#217 |
Has anyone here used one of these kits.
"2.5" 409 Stainless Steel Expanded Builders" Spike ![]()
#218 |
Got my new gas tank in today
![]() 78 Jeep Scrambler, The same as the Wrangler tank Silverdollar used. So I was doing some test fitting. But I got to looking at my parts cart, And thought it needed more room. So I started building a scale T-Bucket body for it. Should have it ready for paint tomorrow ![]() Spike ![]()
#219 |
Where you planning on putting the filler? Parts wagon is looking awesome. Hope to see it in person!
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
#220 | |
Using a motorcycle flush mount pop up cap. Spike ![]()
#221 |
I finished framing out the body today.
Put expanded metal in the bottom. ![]() And covered the outside with some ductwork tin. The painter next door, Offered to paint it. It rolls with ease. ![]() Spike ![]()
#222 |
#223 |
Finished mounting the gas tank yesterday.
Ended up using 3/4: angle iron, Mounting from up under the frame. The tank rises less than 1" above the frame rails. I also got my stainless steel hugger headers in. They look sweet. Spike ![]()
#224 |
GEARHEAD
Looks good. I used a 73+ blazer tank in mine and it's pretty big. I think I'm going to change the mounting to one like this though.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#225 |
67cheby
![]() Join Date: Sep 2008
nice
