12-02-2011, 02:05 PM | #201 |
Re: building my first lowered truck
progress from the day b4 yesterday.
First I capped off the lowers Then I cut out the new gussets Welded on... progress on the motor mounts Love this pic, can see all the holes of the front crossmember, motor mounts and lower link gussets
My Build Thread. 70 C-20, SFBD, angled Z, 3 linked. impressive for a noob? http://67-72chevytrucks.com/vboard/s...d.php?t=438132 |
12-02-2011, 11:24 PM | #202 |
todays progress.
motor mounts are finished up. they drop the motor 2" and push it back an 1" then had to section the crossmember a bit for the oil pan pushed the crossmember down a bit to match the slope of the front of the crossmember. tada cant even tell its sectioned then we dropped the motor in
12-03-2011, 02:36 AM | #203 |
Nice fab work! looking good man...
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
12-03-2011, 10:35 AM | #204 |
67cheby
looks like everything fits in there GREAT !!
12-03-2011, 04:48 PM | #205 |
thanks guys. going to have to build headers :/. next is the tranny crossmember and hopefully get going on that tomorrow.
12-04-2011, 09:30 PM | #206 |
got a few hours in today.
first got all the **** cut out, caps drilled and tapped. then welded up the ends. mounting points welded up, then tacked on
12-20-2011, 06:32 PM | #207 |
well ive ordered a quart of semi gloss black POR15 for the frame and a pint of silver POR15 for the arms and links.
anyone that has experience with POR15 have some tips and know how far a quart will get me on the frame? plan on brushing it on by the way.
12-20-2011, 08:57 PM | #208 |
my one tip: WEAR GLOVES!
that stuff does not come off skin
Cam 1972 Chevy C/10 "Custom Cruiser Project" Build Thread 1961 Olds Super 88 (Daily) 1966 Chevy Corvair 500, "Marigold" SOLD 2005 Subaru Outback Wagon DEAD 2008 Pontiac G8, New Winter/Daily |
12-20-2011, 10:40 PM | #209 |
hah, thank you sir.
01-10-2012, 02:07 AM | #210 |
after a month off i finally made it into the shop. first we got the truck on castors
then i got going on the tranny crossmember, plate cut and bent, 1.5" .120 wall tube bent @ 39* wing notched for the tube fits titties tacked on then welded up going to run a plate as a back bone along the seam of the tube to the upper mounts i built off of the frame. but next we're having a 40s chevy in the shop for a new floor and some other things, ill post that up as it comes. also the POR15 i ordered never showed up, looking into that now. ohh in other news, buddy got cut off and tried to off-road his mini, lol
01-10-2012, 10:52 AM | #211 |
67cheby
looking good man !!
01-10-2012, 11:43 PM | #212 |
thanks slosh-ster
01-10-2012, 11:46 PM | #213 |
67cheby
Lol. No problem haven't been called that since high school !!
Posted via Mobile Device |
01-11-2012, 12:15 AM | #214 |
So Many Ideas, So Little Money
was slosh sloshed in High School? haha
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
01-11-2012, 12:52 PM | #215 |
67cheby
LOL, my name is Mike Losh
01-13-2012, 10:26 PM | #216 |
buddy got bored and built a carrier bearing crossmember for me. some rolled 1" looks titties
01-14-2012, 01:50 AM | #217 |
67cheby
That's cool looking !!
01-14-2012, 02:09 AM | #218 |
Junk Yartist
nope, tried looking at it upside-down, right-side-up, and and don't see the resemblance... I must be missing something! Cross member looks sick though! are you mounting trailing arms to the x-member also?
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
01-15-2012, 12:38 AM | #219 | |
TODAY: moved my frame over for the latest. its a 1940's chevy sedan, mustang ll front suspension, buddy linked it last year and now we're mounting the ls1 and trans then doing some work on the floor, maybe more in the future. first got my turd out of the way frame in then assembled
01-16-2012, 03:21 AM | #220 |
today first i got the backbone for the tranny crossmember built and welded in. i regret drilling the hole in it but oh well. also the the mitered 2x4 welded to the frame
then started my new back half! JK did cut out the tank and compressor mounts though. going to redo them tomorrow also got the other plate cut out from the carrier bearing crossmember, havent decided on a way to mount it to the frame yet so its just sitting and my buddy got the motor/tranny mocked up and motor mounts cut out. a work in progress obviously. front view
01-18-2012, 06:34 PM | #221 |
paint is here and i got a job. so now ill have funds for parts but no time to work on the truck. lol. gonna try and bust out what i can of the frame saturday and sunday.
01-22-2012, 10:12 PM | #222 |
made some good progress on the truck over the weekend. first i started with redoing the upper bag plates
the old ones with the gussets already cut decided it would be easier to just cut out that area of the frame and start fresh then the new piece sectioned in heres the design my buddy came up with. i like it a lot next i boxed in the frame from the back of the cab to the wishbone crossmember all welded up next is to finish the upper bag plate for the drivers side, then mount the carrier bearing crossmember.
01-23-2012, 11:13 AM | #223 |
67cheby
nice looking Welds and bag mounts
02-06-2012, 12:19 AM | #224 |
progress from this weekend, first i got the carrier bearing crossmember finished. tapped holes in the frame for 3/8" bolts.
also got the other bag plate cut out. mount it next time and a couple other projects that are at the shop. buddy did most of the tube work and sheetmetal and i made the battery box. lol fuse box door next project on the list. sheetmetal floor, firewall and back wall. also misc welding and what not
02-06-2012, 11:01 AM | #225 |
outstanding!
