#201 |
![]() Join Date: Aug 2010
Re: My 85 chevy c10 build
Lol thats what I'm trying to figure out..I def wouldn't want to be in it going up and down like that....down is not so bad...its up that scares me...im trying to get some feedback in how to tone.it down or if its supposed to be like that...im told when the engine and tranny and bed on with shocks it will change it a little....I think u can put stuff on to slow it down..
Posted via Mobile Device |
#202 |
Are all the air lines and valves ran?
Line size, valve size, and weight of the truck determine the bag fill speed. How are the valves plumbed from the tank? I would leave it as it is (unless it has crazy big valves, 3/4" or bigger) until you get everything on the truck. If its still to fast then, you can put some type of restriction/regulator in the feed lines or in the lines to the bags. Do you have plastic lines? Posted via Mobile Device
#203 |
I'll have to get some better pics of how the lines r ran. I'm gonna try it like it is and see what happens
#204 |
Wow that moves up and down fast. Mine lifts like half as fast. My basketball is over now so i'm free pretty much all the time now. Just let me know and we'll get together sometime.
Max Max's bagged 81 81 rcsb bagged, 22s, build in progress 09 ext cab, 24" U2's, DD sub/amp |
#205 |
Ready when you are..I still need to weld up a team on my bed and put on some renders so I can mount the tank and compressors..
#206 | |
![]() ![]() ![]() J/k Posted via Mobile Device
#207 |
Lol no...its this Damn phone . I meant frame and fenders! Thanks for calling me out lol!
#208 |
![]() Posted via Mobile Device
#209 |
lol.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#210 |
Alright...so can anyone tell me if this oil pan is going to sit below the frame so when its aired out I'm going to have problems? And also what kind of fuel pressure does the 5.3 vortec need and what is a good fuel pump?? Thanks
#211 |
I dont remember what mounts
you are using, but mine sits just about even with the bottom of the crossmember. I will gone most of the day but will snap a pic when i get back. You need 65 psi on the fuel pressure. What tank are you using? If stock do your self a favor and run the intank pump, the fuel keeps the pump cool. Use a 87-91 tank with the baffles and sending unit for the same years.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
#212 |
if it's the stock truck pan it prob will hang below by a 1 1/2"......I believe around 58psi...whalbro 255, and wix 33737 filter/regulator
#213 |
Thanks moose!!
Update: engine mounts worked awesome and the motor is in! The trans pan does sit about an inch below the crossmember so I'm gonna have to figure something out there...just waiting to wire it up. Get the pc redone...fuel pump , regulator, fuel lines and trans lines. ![]() IMAG0381 by catkinson896, on Flickr ![]() IMAG0381 by catkinson896, on Flickr Posted via Mobile Device |
#214 |
Wow Curtis!!
Your moving right along! You'll be cruising it in no time!! Posted via Mobile Device
#215 |
Thanks joe! That's my goal is ASAP!
#216 |
I used the radiator and cooler lines from the donor on mine. Might be something to look at.
#217 |
Heck yeah I will do that. Did you use the transmission cooler too? Or is that small looking one I took off for the ac? Also did you leave the fan or did u go electric? Did the radiator fit or did u fab it in somehow?
#218 |
![]() Join Date: Jan 2012
fab it in? no worries just use a lil fencing wire haha kidding!!!
#219 |
camaro oil pan! Look on ebay
#220 |
pic of mine bro....
#221 |
Camaro pan or muscle car pan for ls on summit for $170?
#222 |
i think its an ls1 oil pan! almost positive! its shallow mount so youd be good to go
#223 | |
I used a hole saw to drill 2 holes in the bottom of the radiator support for the stock radiator tabs to sit in. I used the stock trans cooler thats made in the radiator, i will probably ad a secondary cooler later on. You will need to make some spacers to go between the radiator support and the radiator at the top mounting points. I used the stock engine driven fan for now, i will change to stock electric later on. I used as much of the orginal stuff from the donor as i could so if i was off some where and had trouble any parts store should have parts to fix it.
#224 |
come on already! you aint finished yet?
#225 |
Man dude...I still got a.ways...I still need a lot of parts!! I'm saving up a little..then were rollin
