Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-29-2013, 08:43 PM   #201
quadzero
quadzero's Avatar
Re: 66 4x4 my sons new project
Very impressive updates. The brakeline work is very professional. Even the snails are too cool.
quadzero is offline   Reply With Quote
Old 02-05-2013, 02:19 PM   #202
argonaut
argonaut's Avatar
Haven't had a lot of time for updates on here. I've been moving and trying to get everything that I can on the pickup so that it can be moved in another week.
Anyway, I got the hydroboost and power steering all plumbed up with nice hoses. I routed them inside the frame rail so I'm concerned that they might get too much heat from the engine. Eventually I'll get an oil cooler but didn't have time to worry about that yet. I can also route the hoses on the outside of the frame rail later if need be.
I did a bunch of other little things, moved the little feet mounts on the rear bed sill, got the radiator mounted onto the core support, got the rear driveshaft shortened and installed, etc.
Then I chased every blind nut thread and bolted all the sheetmetal back on. Put the tailgate back on, mounted the doors, core support, inner and outer fenders, front facia and grill, hood, etc. I still need to cut shifter holes in my fresh trans hump cover and get it bolted in. I also found out that there is truly no such thing as a perfectly straight panel. Stuff I had that I thought was good, isn't. The back corner of the bed was hit at one point, so the inner stake pocket that the tailgate trunion and taillight mount to is tweaked pretty good. Then one side of the front facia is tweaked so the front of the driver's side fender won't bolt up. Nothing that can't be overcome, but I spent a lot of effort trying to find straight, original sheetmetal, but I guess its impossible
Here are a few quick photos I snapped at midnight on Sunday when I finished up for the weekend.
Someday this baby will get paint..... a man can dream!
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 02-05-2013, 02:25 PM   #203
argonaut
argonaut's Avatar
The pickup sits pretty level. And that is more or less how I planned for it. But the front is really stiff so I might pull the fourth, small leaf from the bottom of the pack. Hopefully this will soften it a little bit and only bring the front down an inch or so, giving it just a little rake. I can always bolt in a zero rate.
I'm also contemplating taking the overload leaf out of the back to make it more flexible, and maybe just replacing it with a zero rate.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 02-12-2013, 08:29 PM   #204
RANDY COX
RANDY COX's Avatar
Lookin good jason. I'm slowly workin on mine got the rear diff changed out.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 02-13-2013, 04:29 AM   #205
Chevymaniac
Sweet ride you got there. A nice paint job will really make that a head turner.
Chevymaniac is offline   Reply With Quote
Old 02-23-2013, 12:56 AM   #206
argonaut
argonaut's Avatar
All moved and settled into my new house now. The garage is about half the size, and its more of a clean, quiet neighborhood than my last house, but it'll work.
Got my radiator hoses hooked up last night. Then tonight I swapped out the stock 3/4 ton rear D52 calipers for these nice Wilwood small bore calipers. Yummy. I want another pair for the front (too bad I'm broke).
I also cut new openings in my *new* transmission cover to fit over the new transfer case shifter location. I think i'm going to use two of the same '73 transmission shifter boots for both the trans and the transfer case. I just need to find another oval shaped retainer ring.
I also made a start at installing my American Autowire wiring kit. And by make a start I mean that I opened the box, pulled out the new fuse box and held it up to the firewall. I can already see that the cowl vent handle is going to hit the new fuse box so I'm going to have to modify the mounting plate.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 02-23-2013, 01:42 AM   #207
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Awesome, everything looks sweet!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 02-23-2013, 08:26 AM   #208
duallyjams
duallyjams's Avatar
Time to update your avatar with that cool looking truck.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-23-2013, 08:11 PM   #209
RANDY COX
RANDY COX's Avatar
Lookin more and more like a truck,what color are you going paint it...
1964 BBC 402 4x4
Old 02-27-2013, 02:30 AM   #210
argonaut
argonaut's Avatar
Thanks guys!
I'm not sure about the color yet. Before I started building it I had a pale green color in my head. But now I think that it is a toss up between the sea foam green color of the cab and the baby blue of the bed. Interior will stay stock fawn with brown seat, visor, arm rest and other accents. But paint is a loooooooooong way off!
Got my front axle shims and rear zero rates in the mail a few days ago. Got them painted over the weekend and got a chance to put the front shims in real quick today after work. I like putting a second shim on top to keep the ubolts and nuts square to the surface of the plates.
These are 6 degree shims, which according to my math should have left me with about 4 degrees of caster while greatly improving the front pinion angle.
However once I installed them it seems that I only have about 2 degrees of caster :/ I guess I'll leave these in for now since they are already painted and installed, but I don't have high hopes. I'll probably order a set of 4 degree shims to swap in later.
While I was digging into the spring packs I pulled out the small fourth spring from the pack which made the front much more flexible than before. I think it will ride nicely now.
Still have to swap out the overload leaf with the zero rate out back.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-03-2013, 12:27 AM   #211
chevyboy73
chevyboy73's Avatar
Love this truck, some day when i'm a mega millionaire i'll build one (yeah right LOL) whens the big window going into this cab?
2011 Silverado ECSB LT
2000 Silverado RCSB 2WD
super bad habit of not owning a vehicle for a long time
chevyboy73 is offline   Reply With Quote
Old 03-14-2013, 12:46 AM   #212
argonaut
argonaut's Avatar
Dude, I am definitely NOT a mega millionaire... but I am pretty broke after spending all my money on this silly old truck.
Been getting some odds and ends tied up on the pickup. Put in new taillight housings and lenses and picked up some repop backup light assmeblies. Wow, the backup lights are pretty dang nice! All metal pieces, no plastic and real glass lenses. Just need to get the appropriate hole saw next weekend and those will be mounted too.
Put some new spark plugs in the motor but discovered that a) my old spark plugs looks really good, and b) napa gave me the wrong plugs. So I need to get a new set.
Made 1/4 shim to get my cab and bed leveled and straight on the driver's side. I also got my new transfer case rear output flange painted and installed. Later on I need to decide how I'm going to do the parking brake. I'm thinking I can find a motorcycle rotor that will fit the flange bolt pattern, then I'll use a mechanical spot caliper from Wilwood and just need to make a simple bracket for the caliper.
I'm also having a bit of frustration over tires selection, or lack thereof, for my pickup. Ideally I'd like to run a 35x10.5R16 radial tire. These would fit with the skinny, knobby look of these old 4x4s, would fit perfectly on my stock 6.5" wide steelies, also be decent to drive on the highway. The bad news is that there is only one tire available in this country in that size, and it is an Interco SSR. The thing is they are very expensive ($350 per), they don't have very good reviews around the interweb, and I don't think that they will wear or balance, etc very well. The next closest ting would be a Q78-16 TSL bias ply, which I would love to have, but they don't wear well on the highway. And my truck will be doing a fair bit of highway driving.
After much deliberation I think I've come to grips with the fact that I'll just have to run a 315/75R16 tire like all the other kids in town. I want the BFG KM2s but they are pretty darn expensive too. So I may settle for the old faithful BFG All Terrains. Either way I'm not going to be able to run the black powdercoated stock steelies like i was planning on And my Alcoas are really only 7" wide too. I'd prefer an 8" wide wheel. So the best thing I could find is this:
Black Rock Series 908 Yuma Matte Black
or this:
American Racing ATX Series AX3981 PTFE (teflon) Coated Black Mojave
or this:
Wheel Vintiques 82 Series
The aluminum wheels are an attractive option because they are easily 10-15 lbs lighter. And they'll show off my blingy red wilwood calipers.
What do you guys think?
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-14-2013, 01:34 AM   #213
MTCK
MTCK's Avatar
I like the black aluminum wheels. I think desert rat sells a knock off of the teflon mojave that are a little cheaper. Also if I recall correctly you can get a tall skinny(er) in a 285/75R17. Again, not cheap.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 03-14-2013, 05:19 PM   #214
argonaut
argonaut's Avatar
Oh, i forgot to mention I got my door checks installed. they're from a mid 90s Jeep Cherokee. I put the nicer looking one on the driver's door and I really like it! Two detents and it opens up wide enough. But I put the second one, which was pretty scuzzy looking, into the passenger door and it doesn't open up as far as the driver's side. Weird!
I thought that all the Cherokee door checks were the same but apparently not. I didn't even think to compare the linkages on the two of them before I installed them. Grrr. Now I've got to pull them back out and see what is going on here.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-19-2013, 11:42 AM   #215
RANDY COX
RANDY COX's Avatar
Jason you've been quiet,any new progress or updates.I finally ordered my rockers and the other flooring stuff..
1964 BBC 402 4x4
Old 03-20-2013, 04:25 PM   #216
argonaut
argonaut's Avatar
Yeah, my revenue stream has greatly decreased since the move (rent in LA/OC is ridiculous) so I don't have the funds to work as quickly. Also I'v just been working on a lot of little things.
I did however finally get my front axle and steering sorted out. I replaced the 6* axle shims with 4* axle shims because a) my high steer tie rod was nearly hitting the leafs and b) the caster was only about 3*. So now with the 4* axle shims I've got 1/2" clearance between the leafs and the tie rod and my caster is better at about 5*.
The whole reason I started even messing with the axle shims was to improve my pinion angle and at least ensure i didn't have any binding at full droop. It seems like I've got a good compromise now for everything.
I also spent some time, and money, to get the crossover steering sorted out. There really isn't good documented information and dimensions out there on the different pitman arms, steering arms, tie rods, etc. I hate trial and error, but sometimes it just has to be done. I collected this info from my parts collection:
Pitman Arms:
GM 4wd Arm - 5-1/2" long (center to center), no effective drop
Jeep TJ Arm - 5-1/2" long, ~2" drop
Jeep SJ Arm - 6-1/2" long, ~1" drop
Steering Arms:
GM Stock Arm - 5-1/2"
GM 4-6" Lift Arm - 6-1/4"
PartsMike Crossover Arm - 7-1/2"
In the beginning I didn't know the effective lever arm lengths for the crossover steering arms nor for the Jeep pitman arms. So I took a gamble and ordered from the nice guys up at PartsMike.com in norcal and they suggested an SJ arm, reamed to a GM taper. When I got the SJ arm I thought it looked a little twinky and also it didn't have much drop to it. Luckily, because of the way I had mounted my steering box (differently from 99% of others doing this conversion) the castle nut on the tie rod just barely cleared the frame. I also found out that the SJ arm is pretty thick, and I had to mill a bit off the surface where the tie rod is inserted in order to keep the head of the tierod from hitting the pitman arm as it pivoted through its full range of motion.
So then I went ahead and ordered a TJ arm when I was getting some other parts shipped to me. It "looks" beefier, and has another inch of drop to it, and I figured being an inch shorter it would give the steering box a little more mechanical advantage over the tires. I installed it and it seemed to fit nice. But then I did a lock-to-lock steering test to get the steering centered and discovered that the short length of this arm wasn't giving me enough side to side swing to turn the spindles all the way to their hard stops.
So, the SJ arm ended up having the advantage that it doesn't limit my turning radius, it length ratio with the crossover steering arms is closer to the stock 1:1, and being flatter is actually better because it means less non-axial torque on the steering box. And it turns out that while the TJ arm "looks" stronger, the SJ arm is actually thicker. I think there are some other wagoneer or IH arms that could work too, but I'll be happy running this until/unless it fails unexpectedly.
I also pulled out the rear overload leafs and installed a 1" zero rates in their places.
Put in some new taillight lenses and finally got the Big Ugly beast registered.... after forking over $1,000+ to my friendly neighborhood CA DMV! It would have been more but I fought a good fight. Needless to say I'm still not real thrilled with the outcome.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 03-20-2013, 04:59 PM   #217
RANDY COX
RANDY COX's Avatar
Jason I feel your pain,I can't even imagine what it cost's to live in La(oc).I have a family of 4 and I'm the only one that works.my son daughter are 16,and my wife is not able to work.My daughter just got a job at Taco-Bell after school.So money has to be stretched so far that sometimes there's not enough...anywho I do what I can when I can.I was able to get rid of the 3/4 ton Diff's,so I was able to order my floor panels Rockers Yada Yada Yada...So that's my next step once that's done then I can concentrate on the body.To bad you live waaaaay over there or to bad I live waaaaay over here.
1964 BBC 402 4x4
Old 03-20-2013, 06:01 PM   #218
'63GENIII
'63GENIII's Avatar
Hey Jason, Back when I was lifting a CC dually that I had, I too was looking for a tall skinny 16"x36" tire that would balance well and have good manners on the road. What I came up with was Denman Coyotes. I just did a search for them and found that the company folded years ago but it sounded like someone had bought the molds with the intention of producing them again. I do remember they were much cheaper than the TSL's that I had put on the truck originally (and then replaced BC I couldn't stand them), they rode real nice and balanced like a car tire. I don't know how agressive of a tire you are looking for (as these were not) but it may warrant a little looking? My other thought was some ofthe surplus Humvee tires that I see on C.L. sometimes. Not sure if they would have the size that you are looking for but everytime I see them, the price looks right. From what I hear, they ride real well and are of a little more agressive design. Just a thought. The truck looks great by the way! You've got way more motivation than I EVER had
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 04-08-2013, 12:40 AM   #219
argonaut
argonaut's Avatar
Chris,
Thanks for the input. I would run the army surplus Michelins in a heartbeat, given that they are so cheap, but I really don't want to go to 37" tires. They'd fit okay up front, but they'd stuff right into the little wheel well openings in the back when off road.
I've already accepted the fact that I have to run a 315/75R16 radial, unless I choose to splurge on a set of 35x10.5R16 Interco SSRs.
We'll see. The wheel and tires are the last thing I'm going to do once I get everything else up and running.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 04-08-2013, 12:59 AM   #220
argonaut
argonaut's Avatar
Did a little work on the pickup this weekend. Bent up a 3/8" ss line from the pump to the carburetor. That checks the fuel system off the list; complete.
I decided to stick with the Deluxe heater rather than the recirculating heater. It should push a lot more air, being fed form the cowl, and it also keeps fluids from having to pass into the cab.
I'm going to run a cable actuated control valve on the heater inlet hose. Since the deluxe heater controls have two positions on each lever (one push, one pull) I can attach a second cable to the "heat" control lever. The first cable moves the flap to direct air coming from the cowl into the heater core, and the second cable will open and close the valve. This way the one lever will modulate incoming air and incoming glycol to the heater core. We'll see how well it works out.
I got a new battery box put in too. To old one was toast. I'm thinking of cutting out a thin rubber mat to the floor of the pan. I'd like to pick up an AGM battery so I don't have to deal with acid corrosion on top of the battery all the time. AZone sells their "platinum" for around $145, and I almost bought one today, but figured I should do a little more research first.
I also stole and idea from member 64ShortBox and used a 90's Ford coolant overflow + washer fluid reservoir box and mounted it on the driver's side of the radiator. Since it is a big rectangular box it kind of mirrors the battery. I'll probably paint over the yellow lettering with white so it doesn't look so out of place. I the fact that it has a washer fluid pump built in, so that way i don't have to run wash fluid into the cab on the wiper motor mounted pump. i will have to relocate my horn to the front of the core support. I can't lie, I'm not in love with the way it looks; doesn't exactly match a 60's Chevy pickup, but I like the fit and functionality of it, so I'll keep it.
I painted my radiator mounts, cut some rubber cushions to fit and bolt everything in place.
The other mini-project that i'll work on later down the road is ob board air. Luckily I'm a pack rat and I save the factory AC mounting brackets and the Frigidaire A6 compressor. My dad scrounged up some hoses for me too. Eventually I'll convert it into an air compressor. So far it looks like the pulley clutch is working and the pump seems to be pumping. I'll probably just clean everything up and replace the oil.
At this point I just need to get the valve installed in the heater hose, get the dash harness hooked up and fill up all the fluids. Then I can start her up!
Then once I re-gasket the TC I can drive it! Woohoo!
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 04-08-2013, 01:44 AM   #221
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Very nice, the A6 looks good in there! Do you have the "Dealer" under dash AC unit?
Tony
Old 04-08-2013, 03:45 AM   #222
argonaut
argonaut's Avatar
No AC unit inside. Although my C10 is a factory AC truck.
This pickup won't be getting AC.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 04-08-2013, 05:54 AM   #223
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Oh I missed the part about the onboard air, that's something I'd like to do to too. Ive looked into it and I could fit another A6 in there but I'd have to figure out something for another pulley. Do you know if you can block off the oil so it won't get into your air like you can with a York?
Tony
Old 05-25-2013, 07:41 AM   #224
RANDY COX
RANDY COX's Avatar
Hey Jason just checkin in to see how it's going.I haven't got to work on mine too much,for the weather rain,rain,rain.Iv'e got the driver side rocker and kick panel front door jamb all cut out,just have to put the new stuff in....
1964 BBC 402 4x4
Old 05-27-2013, 02:02 AM   #225
71cheynne402
Where did u get your 402 air breather sticker
71cheynne402 is offline   Reply With Quote
