Old 05-17-2012, 12:18 AM   #201
PDomes7277
PDomes7277's Avatar
Re: hotrod-c10
I believe Northern Tool has those same paint strippers for alittle cheaper than Lowes or HD. Being a avid shopper at Northern....
I used similair strippers but they only last about an area of a fender/door...on my passed experiences
1972 Chevy C-10 SWB
- 5.7/4L60E
2011 GMC Sierra - Daily
1977 Harley Super Glide FXE Shovelhead
PDomes7277 is offline   Reply With Quote
Old 05-17-2012, 01:05 AM   #202
litew8
litew8's Avatar
Re: hotrod-c10
looking good mighty
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 05-17-2012, 10:39 AM   #203
72SWBChevy
72SWBChevy's Avatar
Re: hotrod-c10
Looking good!!
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver -
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline   Reply With Quote
Old 05-18-2012, 07:11 PM   #204
mightymouse
mightymouse's Avatar
Re: hotrod-c10
Originally Posted by 67cheby View Post
Looks great !
Originally Posted by mcbassin View Post
This is another great project. I like the way you fixed the floor on the cab, I can relate to rust repair. I also like the paint strippers you are using. I may have to pick some of those up. It looks very clean. Subscribed..
Originally Posted by tantrumpipeline View Post
coming along great!!!
Originally Posted by butternut1972 View Post
Looks great mouse!
Originally Posted by litew8 View Post
looking good mighty
Originally Posted by 72SWBChevy View Post
Looking good!!
thanks guys , for all your replies. ive been trying to get all the gaps fenders ,hood, doors etc just right but im no bodyman keep on trucking
mightymouse is offline   Reply With Quote
Old 05-18-2012, 07:30 PM   #205
1966JSM
Re: hotrod-c10
nice work, keep it up
1966JSM is offline   Reply With Quote
Old 05-18-2012, 08:33 PM   #206
Stevo427
Re: hotrod-c10
+1 for the grinder paint strippers. I used them on my door and they work great.
Stevo427 is offline   Reply With Quote
Old 06-03-2012, 05:40 PM   #207
mightymouse
Re: hotrod-c10
thanks' 1966jsm
yeah they work good , i was checking out litew8 's build and he was using them thought i would try em
Old 06-03-2012, 06:11 PM   #208
mightymouse
Re: hotrod-c10
got a few things mocked up. mounted my ignition box and coil under dash an ran coil wire thru firewall . got a overflow can for my radiator, optima battery, and throttle return springs . pretty good weekend
Old 06-03-2012, 07:21 PM   #209
72blueshark
72blueshark's Avatar
Re: hotrod-c10
lookin great!
'72 C10 deluxe long bed, 350 auto project in the works
http://67-72chevytrucks.com/vboard/s...d.php?t=513464
Now accepting donations towards the Wade needs hot rod parts fund. all applicable donators will be thanked hospitably with a 12 pack of any alcoholic beverage of their choosing
72blueshark is offline   Reply With Quote
Old 06-03-2012, 07:46 PM   #210
litew8
litew8's Avatar
Re: hotrod-c10
Coming together!
Originally Posted by mightymouse View Post
thanks' 1966jsm
One thing to remember with these, or any other tool used for similar purpose, is
to not spend too much time in one spot. Doing so may cause the metal to heat
up too much and could cause the metal to warp.
Old 06-04-2012, 05:51 AM   #211
Enigma_89
Re: hotrod-c10
Ya man, I'm in the middle of a floor pan replacment myself. Very time consuming. Workin almost everyday trying to get it done before i have to deploy.
I'm sorry to say this but I would expect that your existing cab it screwed. If so you could always use the metal for patching holes. Thats what I'm doing with my old floor. You might have some trouble lining up the Floor with the cab on the front unless your buying an original and not a refab. I got a refab and it's taking prying a beating to get it to sit right.
The high hump is really gaudy, good choice on replacing that. The low hump is a much smoother look to me.
Keep up the good work, hope so see more from you soon!
Enigma_89 is offline   Reply With Quote
Old 06-04-2012, 07:41 AM   #212
mightymouse
Re: hotrod-c10
yeah, i like the low hump trans tunnel better too! the floor pan was tri-plus brand that i got from gmc pauls and i'm happy with the fitment even the seat mount holes were right on good luck with your project and thanks for your service be careful and get home safe...jw
Old 06-29-2012, 10:16 PM   #213
mightymouse
Re: hotrod-c10
not much going on , my alternator wasn't charging the battery. new batt, alt , solenoid , starter etc .. my neighbor across the street, sergio also a member suggested that since the brackets were powder coated maybe i should run a ground wire off the alt , i did and he was right , everything now charging, i haven't had a chance to tell him yet . thanks sergio.. also filled the trans full of fluid wired the trans brake and filled the rear end housing with grease. ran it thru the gears on jack stands and everything seems to work may take a while to save for rear brakes thats next unless something else cuts in line . also met a guy with flawless stripping said he would blast my truck minus bed and doors for $550.00 i think thats fair but hes the only one Ive checked with............keep on trucking..jw
Old 06-29-2012, 10:49 PM   #214
mud.man.rj
mud.man.rj's Avatar
Re: hotrod-c10
Not sure what you mean, filled the rear diff with grease, not 80/90 oil.
mud.man.rj is offline   Reply With Quote
Old 06-29-2012, 10:57 PM   #215
mightymouse
Re: hotrod-c10
yeah, 80/90 gear oil .
Old 06-29-2012, 11:07 PM   #216
mud.man.rj
mud.man.rj's Avatar
Re: hotrod-c10
Cool, got the good stuff too I see.
Old 06-29-2012, 11:19 PM   #217
litew8
litew8's Avatar
Re: hotrod-c10
Yep, that alt. should be self grounding to the bracket.
If you don't want the wire connected, just scuff the bracket where it bolts up.
Doubt you'd see it when installed. Keep on truckn' mighty
Old 06-30-2012, 01:54 AM   #218
Ends
Re: hotrod-c10
looks sick man, is your rear axle narrowed? and are you going with a static suspension or going to bag it? very good looking set up!!
LAYDIIREST member
1970 C10 stepside full tube Chassis, supercharged 454 and much more, 95 motor and trans swap, pro street SLAMMED!
1951 Fleetline custom chopped, channeled, narrowed.
Ends is offline   Reply With Quote
Old 06-30-2012, 10:23 AM   #219
mightymouse
Re: hotrod-c10
thanks ,Ends, the rear housing was cut down to 46-3/4" and its got double adjustable coil overs for a little street strip action (originally intended for my sons old camaro). thanks again..jw
Old 07-02-2012, 02:12 AM   #220
jhaymon
jhaymon's Avatar
Re: hotrod-c10
use the stock hood. cowls have been done to death
jhaymon is offline   Reply With Quote
Old 07-02-2012, 06:39 PM   #221
mightymouse
Re: hotrod-c10
hey jhaymon, thanks for they comment, yeah i sold the cowl hood at pate swap meet in April. i really liked it also. wished id kept it and painted them both like others on here suggested cause i didn't get much for it anyways. but the stock hood really looks nice..
Old 07-02-2012, 08:24 PM   #222
jhaymon
jhaymon's Avatar
Re: hotrod-c10
you must have missed this 20dollar gem. it's a little boogered up on the front left, but still cool . plus its got old skool wide louvers on it instead the new tiny louvers like the one on the truck now.
Old 07-02-2012, 08:34 PM   #223
mightymouse
Re: hotrod-c10
Attachment 950300
man you scored good on that hood someone really put alot of work into it .thanks for sharing pic..jw
Old 07-02-2012, 09:17 PM   #224
67cheby
67cheby
67cheby's Avatar
Re: hotrod-c10
Looking good !
67cheby is offline   Reply With Quote
Old 07-03-2012, 06:56 PM   #225
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
Re: hotrod-c10
Nice progress Johnny! Truck is looking gooood.
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
