Old 08-31-2013, 09:29 PM   #201
Sammy
Re: Project 67
When I was in the Army we had name for light weights who couldn't handle the current tasks presented them I'm not allowed to post here but it starts with the letter "P." Ha ha.
I did get beige on the fenders, cowl, radio delete plate. Despite the uncomfortable weather conditions.
Now I need to reshuffle finished items to get close n personal with the bed.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 09-05-2013, 08:04 PM   #202
Sammy
Re: Project 67
Got some things done today thanks to FireDog n Pop's help. First reinstalled the cab on the frame, then installed the windshield, and the rear window. Surprising how well installation went with the windows. Maybe 45 min with a 15 m brake n the middle. Also received the new panel for the cluster Pop's done a fine job on that. Also installed the two doors after replacing the window regulator on the driver's side. Wanted to comment on GMC Pauls parts..Dash Panel was super nice no issues with the quality at all. Plus the other items arrived in about 3 working days. Even with the holiday in the middle. Also worked some on the bed as you will see in the pics I will post below. Very happy so far how things are going and starting to see some progress which is a good thing. Starting to look more like a truck again..
Old 09-07-2013, 09:31 PM   #203
firedog
firedog's Avatar
Re: Project 67
Not to brag or anything but that windshield went in real smoothly, and looks the best out of all of the ones we have installed.
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 09-07-2013, 11:01 PM   #204
Sammy
Re: Project 67
2K the passenger bed side. Making a attempt at salvaging a tailgate to see if it will pass as a driver's gate for now.
Old 09-09-2013, 06:52 PM   #205
Sammy
Re: Project 67
Got a 2nd coat of primer on the bed side. After a couple of days of work finally finished the gate. Surprisingly turned out better than I really expected. No before pics of the gate but I assure you it looked like it had been drug behind the truck rather than inside a truck at some point. Plenty of filler in this one and a couple of dents that is beyond what I can do. It is better than no gate for now until something much better catches my eye.
Waiting on hardware to install the driver's bedside, head board and tub. Then the floor coating to finish the floor. Next is the underside of the bed some needed repairs to supports and primer coat the underside at least maybe even a coat of tractor black before beige get sprayed.
Old 09-11-2013, 10:13 AM   #206
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Re: Project 67
Looking great there Sammy.
Really digging the paint scheme now that I can see it as a roller.
Very close to the color my friend has on his 1970 C/10 LWB truck.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 09-11-2013, 03:47 PM   #207
Sammy
Re: Project 67
Thanxs Scott. Actually reminds me of the 50th gold color in some ways. Except lighter. Kinda disappointed that someone else has painted a similar color. Wanted something "ODD" or different yet pleasing without being over the top. Without the white cab top it was just too much and very plain looking and I immediately knew that it wasn't going to work for me in a solid color. Likely to put a stripe at or near the belt line down each side front to rear after it is together. Have not decided gray, white, width or if only a single stripe yet though. Everyone that has seen it in person has had good comments. And the pics doesn't do it any justice either.
Old 09-11-2013, 03:52 PM   #208
Sammy
Re: Project 67
Under bed repairs are finished and about 75% POR-15 also. May even use the coating on the inside of both rear fender tubs.
Old 09-12-2013, 10:23 AM   #209
C20-67_N_MO
Post Re: Project 67
Here is my friend's 1970 c/10 3/4 ton LWB truck.
Then you can judge for yourself if its close to your color.
Old 09-12-2013, 05:11 PM   #210
Sammy
Re: Project 67
Similar.
..Today I spent a couple of hours {at least it seemed like it} adjusting the doors for gaps and to work like I expected. I don't have the correct length core mount bolts for the core but all is needed is to drop them in the holes. Longest time was taken aligning the grill to bolt it to the fenders. I like all the gaps so far except one (lower passenger side fender}believe it can be shimmed at later time. Firedog already pointed out I may want to paint the inside of the fenders white to match the grill. He may have a good point.
Old 09-13-2013, 01:57 AM   #211
firedog
firedog's Avatar
Re: Project 67
We need a side shot to see those rims tucking!
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 09-13-2013, 02:05 AM   #212
jeboblasto
Re: Project 67
Nice truck! i had to put in my vote for keeping the grill like that, i have wanted to do that with mine. Not the usual though, that's for sure but for some reason i like it. cheers.
jeboblasto is offline   Reply With Quote
Old 09-13-2013, 12:55 PM   #213
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Project 67
You're killin it buddy.... Missed you all last weekend.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-13-2013, 03:21 PM   #214
Sammy
Re: Project 67
Thanxs for the kind comments. Must remember I'm not a body man or a painter. But I will attempt anything a couple of times if need be. Matter of fact today I repainted the R/F fender due to my mistakes. The more I do it I get just a bit better. But I don't have the equipment and have to make do. So plenty of mistakes.
While the fender was drying I added the white to the driver's side and it can be compared now to the other one.
Was going to push it out for a side pic but the tire's are touching the inside of the fenders barely. But it will happen. Ohh they fill the fenders up nicely with no air in the bags. Next week it is possible to get the bed situated enough to roll it out for a peek. Once all the body is back on the frame it will get a once over with 300 grit most of the flaws addressed and what I hope will be a final coat of beige to blend the body panels and correct the installation bumps n bruises you concur during reinstalling grills, doors, windows and so forth.
Pic of the difference in the white around the headlight. Enjoy!
Old 09-13-2013, 03:58 PM   #215
knomadd
knomadd's Avatar
Re: Project 67
That looks much better with the white painted around the headlight on the fender. Nice work!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 09-13-2013, 03:58 PM   #216
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Project 67
Much better in my opinion.
-Nate
Old 09-13-2013, 07:49 PM   #217
Sammy
Re: Project 67
For Firedog..
Old 09-15-2013, 08:58 PM   #218
Sammy
Re: Project 67
Got the eye white on the right fender to match the other side. Also the 2nd coat on the right bed side, tail gate and the header panel. Getting short on beige may have enough left to 2nd coat the driver fender or the 1st coat on the final bed driver's bed side this week. 1st coat of Armor All bed coating on the floor. Another pic to enjoy...
Old 09-15-2013, 09:23 PM   #219
darkhorse970
darkhorse970's Avatar
Re: Project 67
Looks real good! I really like the paint color and wheels together.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 09-15-2013, 09:32 PM   #220
Sammy
Re: Project 67
Thanxs Darkhorse. I knew a lighter color would be easier on me.
Old 09-16-2013, 07:43 PM   #221
firedog
firedog's Avatar
Re: Project 67
maybe we should take the fenders off and cut the insides to fit the tires so it will drop even lower, just kidding, looking great hope to catch up with you this week and we can set the bed on.
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 09-16-2013, 08:23 PM   #222
El Campo
El Campo's Avatar
Re: Project 67
Everything is looking very nice!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 09-19-2013, 04:30 PM   #223
Sammy
Re: Project 67
Thanxs to help especially Firedog we got OddBall moved and the bed set, tailgate mounted. Really looked sweet in the sunlight gathering sunshine today. Forecast for thunderstorms tonight so it will be a short breath of fresh air. ID'd the front bumper brackets so that maybe next. Alignment of bed/cab doesn't appear to be a huge issue. Just the left rear corner of the cab may need a shim.
Enjoy.
Old 09-19-2013, 04:33 PM   #224
Sammy
Re: Project 67
The front bags required some blocks to turn the wheels with deflated bags.
Old 09-19-2013, 04:37 PM   #225
Number98
Prestige Worldwide
Number98's Avatar
Re: Project 67
Your truck is really looking good!
Number98 is offline   Reply With Quote
