#201 |
![]() Join Date: Nov 2008
Re: I dont no what I am building haha
Your killing me Dino.
#202 |
Still Learning
More pictures!
Posted via Mobile Device |
#203 |
Eric Congratulations........
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#204 |
Ok here is what I have going on. I mounted the kit and I got all the brackets put in place. When I compress the bags the rear is not even close to being all the way up in the notch so back to the drawing board I go.
#205 |
Congrats on the new addition to the family!!!! All the builds are top notch.
#206 | |
#207 |
Are the bottom brackets too tall?
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
#208 |
Thats only part of the problem. If I shortened them I would only gain an inch and I need 3 and a half inches.
#209 |
What if you switch to a double bellow bag? I think they have a smaller compressed footprint than the sleeve bags.
#210 |
I took some pics of mine to see if they would help at all
![]() From top of frame to top of notch ![]() Laid out this much room left in notch ![]() My bracket is 2 1/4 inch tall. After installed from top of bracket to top of axle tube is 1 1/2 inches. Just some info I hope it helps. Posted via Mobile Device
#211 | ||
VA72C10
![]() Join Date: Mar 2008
Once again...we see PB is the man and caught this days ago! ![]() I re-read this and.... ...Just wanted to make sure it is clear I meant no disrespect to Scotts or Superflysteiny with my PB comment...just remembered him noting this a while ago... Scotts makes some great products and obviously is working to get this worked out which is ![]() And superflysteiny makes some of the most awesome trucks I've ever seen!!! ![]()
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 02-02-2012 at 01:28 AM. |
#212 |
The 9000 bag min height is 4.5 " the lower bag mount cannot go any lower on the rearend axle tube you see in the pic.The bolt securing the bag is 3/4 long and with the
thickness of the head this makes the bolt 1 inch. You can see juans post on his rear set up he has notch installed at higher point and he also has the same rear set up as you see here in this thread and you can see that his burb is layed out. If the notch you see is raised up in his frame on this set up will work perfect. The notch we made for this frame was deigned to be able to box his complete frame in. We have some different brackets that will allow the bag to be installed in front of the axle and will allow the bag to sit lower.There is also a different upper bag mount,the lower 4-bar mount will have the lower bag mounted attached to it. We have contaced Eric on this as well today. This will be all taken care of no problem at all Last edited by Scottshotrods; 02-01-2012 at 07:26 PM. Reason: add |
#213 |
I'm along on this one, first congrats Eric to you and your wife on the birth of your son...family is everything. Great to see the kids in the shop too.
I'd make the 'burb long enough to fit a fold flat rear seat (mini van style), for the very back seat, in the rear storage area. Three kids, three friends. Does the Scott's front cross member move the wheel forward in the wheel wells? I'm looking forward to this install, I like the idea of a static drop...even if air bags are very adjustable. Enjoy the ride ![]()
#214 | |
#215 | |
![]() Posted via Mobile Device |
#216 |
I figured your going to run a bigger rear wheel then what I got. I'm at a 28 inch tire. I'm sure you will find the right answer for your set up. Sorry I was not much help.
#217 | |
Justin |
#218 |
![]() Join Date: Feb 2003
Bummer bro, thats a ton of work.
#219 | |
Big Red - Now its a SWB!
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
#220 |
Thanks guys I will get more pics up as soon as I can.
#221 |
![]() Join Date: Mar 2010
Eric, You could lower your axle brackets to have just enough space for the bolt head. Make a relief hole big enough for the bolt and washer. then mill a slot to your final hole. This would allow you to have the bolt in the bag nearly tight so you wouldn't need the room for the hole legnth of the bolt for installation. It would gain you some room but probably not enough.
Just trying to help. |
#222 |
wow sorry i'm late! i never got the memo,that you started this build. well i'm here now
![]() hello...hello... damn they went home already |
#223 |
welcome
#224 |
Have you guys seen the roof to my burb. It seems to have gone missing. Can you guys help me find it.
#225 |
Your an animal!!!
