Old 09-19-2012, 08:03 PM   #201
68Stepbed
68Stepbed's Avatar
Re: Project: LS1ick68
Ask away, Brian! BTW, you weren't bugging me. I enjoyed our conversation.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 10-13-2012, 11:16 AM   #202
RRC
RRC's Avatar
Just picked up a LS1,thanks for the inspiration ! Truck looks great!
RRC is offline   Reply With Quote
Old 11-06-2012, 08:23 PM   #203
cjohnson6772
cjohnson6772's Avatar
I hope you don't mind me bugging you with a few questions, but hey that is what you get for having such a clean install . I've got a LQ4/4L80e that I'm going to put in my '72. I am planning on copying your setup with regards to your engine mounts and probably your headers. I was wondering if you are still satisfied with your mounting/fitment or if you would do something differently if you had it to do over again.
BTW: absolutely amazing truck. When I get into my swap I might make a drive up to Sevierville to see the '68 in person if you wouldn't mind.
cjohnson6772 is offline   Reply With Quote
Old 01-07-2013, 03:03 PM   #204
68Stepbed
68Stepbed's Avatar
Thanks!
Sorry for the late reply. Thanks to you as well. Ask me any questions you need to know. So far, I'm very satisfied with all the parts I used except for the TransDapt adapter plates. I wish I had went with the Dirty Dingo mounts. I really like my headers and have no complaints with them, but I kinda wish I'd went with a long tube design. But for the money spent, there's no reason to complain.
Come on over to Sevierville any time. PM me if you want my contact info.
Matt
Old 01-07-2013, 03:16 PM   #205
68Stepbed
68Stepbed's Avatar
The final step(at least a major one) is finally complete. The 4.11's and Eaton Posi are installed.
New Eaton posi(limited slip)
factory 4.11 r&p set, new crush sleeve, bolts and threadlock ready to go.
Tear down.
Out with the 3.07 gears and modified Gov-Lock.
The guy installing the gears was supposed to do everything on Thursday, Jan 3rd. He went back to his shop to remove the bearings off the old carrier since they were practically new. One of them messed up in the process, so he looked in his attic for another set. In the process, he fell out of the attic and broke two ribs!! He said he needed to wait and come back on Friday to finish. As you can see from the pics, the rearend was almost completley out anyway, so I decided to finish pulling it out to make it easier on him.
Everything installed and ready to get oil and cover and be reinstalled!
I got it all put back in and bolted up by Friday evening, but had no one to help bleed the brakes until Saturday evening. My wife came out and helped me get that done so I took a test drive. The lower gearing made a HUGE difference!!!!
Now I need to figure out how to get traction.
Matt
Old 01-07-2013, 05:07 PM   #206
gringoloco
A guy with a truck
gringoloco's Avatar
What a roller-coaster! Gears are the single best upgrade you can make, IMO. Enjoy!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-12-2013, 07:57 PM   #207
68Stepbed
68Stepbed's Avatar
I finally made an idle video.
http://www.youtube.com/watch?v=WqrdI...ature=youtu.be
Matt
Old 02-12-2013, 08:14 PM   #208
cericd
cericd's Avatar
Sweet! Let's see some of it rolling.
cericd is offline   Reply With Quote
Old 02-13-2013, 08:16 AM   #209
68Stepbed
68Stepbed's Avatar
I'll try to get a video of it in action soon. I'm going next Saturday to get another issue sorted out with the trans. After that, it will be in better condition for a video.
Matt
Old 02-14-2013, 09:22 PM   #210
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Sound AWESOME Matt!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 02-15-2013, 11:54 AM   #211
solidaxel
solidaxel's Avatar
Question back on the TBSS and Camaro manifolds, is this a problem with clearance on a 4L60E?
How much meat did you have to take off the transmission to make them fit?
Did the exhaust shop have to make a different down pipe?.
What else am I missing with the stock manifold in a 78 1/2 ton.
Your build was very well "built" sorry to hear about all the hot rod problems in the end to get it all working
NICE WORK !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-15-2013, 12:39 PM   #212
68Stepbed
68Stepbed's Avatar
Well, I'm running a 700R4, not a 4L60E. The 4l60E shouldn't have any problems with any of the stock manifolds, since that trans is what most came with. The only clearnce issues I had with the manifolds was with the stock engine mount towers. Your 78 will have the "clam shell" style mounts and flat style towers, so you shouldn't have any clearance issues.
My major issue was with the particular headers I bought. They did interfere with the converter cover mounting "ears", which I had to trim. They wouldn't be an issue with the 4L60E as they don't have those ears.
Matt
Old 02-15-2013, 03:41 PM   #213
solidaxel
solidaxel's Avatar
That 4:10 gear and 1st gear in your 700R must be a stump puller for about 60'!
How do you like everything now that you are driving your truck?
LS 3 4L70E
Old 02-15-2013, 06:57 PM   #214
68Stepbed
68Stepbed's Avatar
I love it!! I still have some fine tuning to do with the carb and timing, and I've been stalling on getting the steam lines redone. I'm taking it back to the transmission guy next saturday to get the kickdown issue sorted out. Right now, the trans won't shift down(we're thinking a stuck throttle valve) which is also keeping it from letting the rpms rev up higher, so it's changing gears too quick.
So far, though, it's ALOT of fun with the 4.11s!!!
Matt
Old 02-16-2013, 02:59 AM   #215
BigDan3131
BigDan3131's Avatar
I just got my new issue of Super Chevy and they said that Trick Flow has a -4 kit out for the steam lines.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 02-18-2013, 10:10 AM   #216
Hart_Rod
Hart_Rod's Avatar
Your truck is looking and sounding great! Here's a link to the steam line kit:
http://www.trickflow.com/egnsearch.a...6&autoview=sku
Hart_Rod is offline   Reply With Quote
Old 02-19-2013, 02:59 PM   #217
68Stepbed
68Stepbed's Avatar
Thanks for the link, Rob.
Matt
Old 03-22-2013, 09:13 AM   #218
jae
Your truck is amazing. I'm getting ready to start a 5.3L swap into my '71 using an almost identical setup and you've given me some great ideas on how to keep it clean. (I love your spark plug wire conduit solution!)
I'm going to be using the TH350 that's already in the truck, and it looks like it's quite possible it has those same "ears" that yours did and I'm getting a little worried about header clearance, since I was thinking of using the same ones you did. Once you had the tubular engine mounts in, did the Camaro manifolds clear everything ok, or was there still a clearance issue somewhere?
jae is offline   Reply With Quote
Old 03-24-2013, 10:10 AM   #219
68Stepbed
68Stepbed's Avatar
Thanks! About the wire looms, though. They're in the way of being able to use a dipstick. I used a Lokar dipstick, but had to shorten it, and I really can't get it out to check the oil.
The Camaro manifolds actually would have worked well with the tubular mounts. I just went with headers since they were inexpensive enough. Another option is the Hooker manifolds if you wanted to go in that direction.
Matt
Old 04-02-2013, 01:51 PM   #220
boomz55
sick build man!! job well done
boomz55 is offline   Reply With Quote
Old 04-07-2013, 04:27 AM   #221
dec010974
dec010974's Avatar
hello to all. hey 68 stepbed, where did you ge those fuel line clamps? ive been searching the web for 3 days.
dec010974 is offline   Reply With Quote
Old 04-08-2013, 08:42 PM   #222
68Stepbed
68Stepbed's Avatar
Got your PM and replied to it.
Matt
Old 04-08-2013, 08:44 PM   #223
68Stepbed
68Stepbed's Avatar
I finally bit the bullet and ordered the -4AN stuff to build my steam lines correctly. This crap is stinking expen$ive!! I have well over $120 in this setup.
Sorry for a craptastic cell phone pic. I'll try to get some better shots in the future.
Matt
Old 11-07-2014, 01:01 PM   #224
elf w/capital T
dude that engine looks good!! wow super clean!
elf w/capital T is offline   Reply With Quote
Old 11-09-2014, 12:25 AM   #225
68Stepbed
68Stepbed's Avatar
Thanks, elf! Since you revived the thread, I've made a couple small changes.
Matt
