02-17-2013, 12:55 PM | #201 |
Re: DURG's Black 65 C10
nice!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
02-17-2013, 01:25 PM | #202 |
Lookin' really great. Way to go.
02-17-2013, 03:58 PM | #203 |
I am looking for a set of these Porterbuilt hood hinge relocation brackets. I thught someone may have a set after upgrading to his newer style hood hinges.
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black |
02-18-2013, 02:08 AM | #204 |
Congrats! Looking really good, great attention to detail.
02-20-2013, 06:10 PM | #205 |
02-20-2013, 06:42 PM | #206 |
Looks like member meltmetal is hooking me up with a set of Porterbuilt hood hinge supports so I can move forward with my front bracing. Thanks, Matt!
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black Last edited by DURG; 02-21-2013 at 07:21 AM. |
03-06-2013, 08:49 PM | #207 |
Here are the Porterbuilt hinge brackets installed. I have made a couple removeable metal plates to weld the 1-1/2" metal tubing to that will run down to the frame horns from each of these brackets. The tubing will be welded into the center hole of the plate and ground flat on the back side. The braces will be attached to a removeable piece on the front of each frame horn as well. I will run a cross brace with a 3/4" heim end on each end that will attach from side to side near the front of the motor somewhere around water outlet height. I am also showing the new AAW main fuse block and the aluminum plate it mounts to. This plate attaches by longer upper bolts that go through the firewall that hold the hinge brackets on which are the OG holes used to attach the OG inner fenders.
03-08-2013, 04:00 PM | #208 |
Looking good! I am using AAW classic update on my 67 camaro project, LOVE their kits....
03-08-2013, 09:11 PM | #209 |
Great build!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-09-2013, 08:21 AM | #210 |
Awesome truck!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
03-09-2013, 03:49 PM | #211 |
I used the complete Classic Update kit on my 62 Impala SS also. Tech support if needed is excellent as well.
03-17-2013, 11:07 AM | #212 |
Few minor updates: Truck is back on the floor with the new a-arms installed with good adjustibilty on camber. I am toying with the idea of running a 61-62 style Impala barrel shroud as the stock fiberglass/plastic one won't be as easy to install as my radiator to engine height is different now. (I know the fan needs to move back to be centered) I used some PVC pipe to mock up how I want the front bracing to go. Went to get it bent yesterday at a near by racing chassis place but they were not working. I will be running a rod with heim ends from side to side connecting to where the lower elbows are shown on the braces. This will all be removeable. I am bolting a flat plate on the front frame horns that the braces will weld to on that end like onto the hood hinge brackets. Truck is shown at ride height.
03-17-2013, 12:47 PM | #213 |
Great job...look super!
03-17-2013, 04:21 PM | #214 |
Bad a$$!!!
Posted via Mobile Device |
03-17-2013, 04:43 PM | #215 |
67-72 parts collector,…
What did you have to change with your a-arms?
03-17-2013, 07:10 PM | #216 |
Slightly shorter so I could have some camber adjustment.
03-17-2013, 09:06 PM | #217 |
Man, I like EVERYTHING about this truck! It's the right year, the right color, the right parts, and it sits perfect.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
03-18-2013, 01:02 AM | #218 |
sweet ! hope you get it done soon
efi 496bbc th350 custom brakes narrowed 9 coilover rear. |
03-18-2013, 04:58 AM | #219 |
Thanks, it will all be coming back down to a bare frame for painting before it's done and money is tight for the engine department right now as it looks like I will be going to 32 hour work weeks thanks to the inept politicians. I'm shooting for summer of 2014 realistically.
03-18-2013, 02:17 PM | #220 |
Whats the backspacing on the coys? BTW great looking build!!
03-18-2013, 04:45 PM | #221 |
i have been watching and must say you have a awesome truck, i like every thing about it, and the 62 is sweet, i had a red on red 62 ss whan i was 16 and my dad sold it and gave me a 72 cutlass. cant wait to see the truck finished, keep up the awesome work
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
03-30-2013, 08:56 AM | #222 |
Got my front bracing roughed in down to the frame horns. There will be a cross brace to tie them together but I need to know where my accessory drive package will end up before I can commit to its location. I am leaning toward a GM Performance crate 350/330 setup with the front serpentine drive. The Impala twin is getting ready for spring. I still have snow on the ground here though.
03-30-2013, 09:11 AM | #223 |
Great work on the support bars.
I highly recommend any drive from Billet Specialties. V-trac or Tru-trac would be my first choice. Vintage Air's Front Runner set up would be my second choice.
03-30-2013, 10:06 AM | #224 | |
After looking at them it appears triple the price 1795.00 with no A/C pump in polished.
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black Last edited by DURG; 03-30-2013 at 10:10 AM. Reason: Sticker Shock |
03-30-2013, 10:11 AM | #225 |
