Old 11-02-2012, 09:31 PM   #201
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Re: 1958 LS2 with C4 front and rear
Thanks guy's..
I know we all hit the wall sometimes...it's just a bad day....I'll get over and knock it out...just going to take a littleeeeeeeeeeeee longer then i wanted
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 11-02-2012, 11:26 PM   #202
Kim57
Kim57's Avatar
Sorry about the troubles but as others have said you'll get it worked out in the end.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 11-02-2012, 11:27 PM   #203
oldman3
oldman3's Avatar
Hang in there, you'll work in out....Jim
oldman3 is offline   Reply With Quote
Old 11-03-2012, 09:11 AM   #204
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
You ll get her nailed and doing burn outs in no time..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-03-2012, 11:59 AM   #205
wutnxt
Thanks guy's......
Old 11-03-2012, 11:12 PM   #206
wutnxt
And the hits just keep getting better...I think I am going to have to cut out a portion of my original front cross member out o be able to get the power rack out...It's not for sure but i have it unblolted and there is no way it's going to come out. I had to take the walk and thing....and that is my plan B.....The other thing is does anyone know how to tell the C4 racks apart year wise ?
Old 11-04-2012, 10:41 AM   #207
not2oldchevy
I used the flat out kit on my AD, I can take the tie rod ends off and get my rack out.
not2oldchevy is offline   Reply With Quote
Old 11-04-2012, 12:24 PM   #208
wutnxt
But i C notched the front frame to get it to sit another 2" lower on the front...but i am going to try and take the tie rods off and see if it will make it but it doesn't look good....
Old 11-04-2012, 11:39 PM   #209
wutnxt
Well.......
Plasma cutter time....I had to hack up the original crossmember to get the rack out....
Old 11-04-2012, 11:41 PM   #210
wutnxt
But a the end of it......the rack lost out and i liberated it
Old 11-04-2012, 11:47 PM   #211
wutnxt
So this is the before pictures....if you look just prior to the butterfly set up you can see the straight 3" stainless tube that didn't work....
Old 11-04-2012, 11:50 PM   #212
wutnxt
These should be the after pictures......you can see the flare in the tube now....
Old 11-04-2012, 11:53 PM   #213
wutnxt
try that again
Old 11-06-2012, 10:56 AM   #214
wutnxt
Has anyone done the 4 wheel C4 disc brake with the CPP under floor master and booster combo ?...I put in the residual valves hooked it all up and it does seem to have any power brakes.....it feels just like booster isn't working or helping out. I swappedout boosters and it's still the same....wierd...anyone?
Old 11-06-2012, 11:09 AM   #215
wutnxt
Here are some of the pictures of what happened to my oak box when the radiant heater vent leaked....
Old 11-06-2012, 11:30 AM   #216
Chevette
Chevette's Avatar
If memory serves me (and it usually doesn't) GM used a 1" M/C piston in the C4. Make sure the CPP is too. You'll need a 2lb - 10lb setup because your m/c is lower than your calipers. Check your vacuum pressure. That's all I can think of.
On another note: Have you tried bleach or "wood bleach" on that stain. I'm not saying it will work, but it may be something to try on a very small test area.
Good luck sorting things out.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 11-08-2012, 11:00 AM   #217
wutnxt
Well....
I had my old rack and pinion rebuilt because I couldn't find a new one. I got it back at 5pm last night and called the boys over, and managed to get it installed and buttoned up last night. I have also been waiting for HPT to provide the software for my 4L80E behind the LS2 trailblazer combo and they replied back last night in a email saying basically that .....it's not going to happen because that combo was never offered from the factory. Soooooooo I gues thats my newest hurdle....I moved it last night and it's oing to need some brake work...the pedal " bottoms out " with out the truck stopping out. So i am going to have to think about that, but i am guessing that has to do with rod length for the Master.
Old 11-08-2012, 01:49 PM   #218
_Ogre
_Ogre's Avatar
they make stand alone trans controllers for the 4l80e trans, pricey but maybe an option
brakes: could be the rod or maybe just air in the system
make sure all brake bleed screws are on the top of the calipers
that sucks about your nice bed wood, i'd try mineral spirits to get the stain out
shop air compressor timer
Old 11-08-2012, 01:56 PM   #219
wutnxt
Ya thanks...I am looking at the stand alone harnesses right now...I have tried almost everything on the oak and it's going to have to come out and be redone. I think it's rod lenght but i migt just ebleed them again to make sure thas agood idea. It goes in for a alingment tomorrow and then maybe i can get it up in the air on my buddies hoist and work on the brakes. I so wanna drive it now....
Old 11-08-2012, 11:48 PM   #220
lt155ruck
lt155ruck's Avatar
Hey, just a thought... have contacted one of the floor or house restoration companies that deal with water/fire damage for floods etc. Maybe they have a magic solution? Sucks that it would have to redone
lt155ruck is offline   Reply With Quote
Old 11-10-2012, 09:39 AM   #221
wutnxt
I used to be in the wood Bizz....I tried it all...it's done. It's going to have to be pulled out and redone, I have already pulled some of the stain off working all the stained area. Trust me it's going to be ugly, drop the fuel tank and thats not easy because the way my filler tube is. Working around the 2 battery trays or drop them and then there is a row of bolts right in my new cross members that are ugly. So it's staying that way for a while.....lol
Old 11-10-2012, 09:51 AM   #222
wutnxt
Well i have brake woes...
The top of the pedal is fine but it doesn't stop the truck and the pedal bottom outs....I tried swapping out the booster already and thats not it....I adjusted the rod thats not it....so now it's come down to go with a smaller bore master cylinder....todays project.
But the good news is that it runs and moves...
Old 11-10-2012, 10:15 AM   #223
wutnxt
Well shifting woes....
It doesn't shift yet and with that trailblazer set up it's ugly.....So
Plan 1 )....We have a guy who can write program and over ride the GM code....I still don't think thats going to fly. With out relays....and....and...
Plan 2) I bought a stand alone tranny Harness From TCI...I know that will work
Old 11-10-2012, 10:18 AM   #224
wutnxt
I also got the 4 wheel alignment off the list.....It sure made a difference loading it onto the trailer....Having the wheel straight and both wheels pointed ahead....lol
Old 11-11-2012, 09:56 PM   #225
wutnxt
changed out the mater cylinder out..... to a 7/8"bore ...drove it aroud the parkng lot and it seems the brakes all good now.....so thats one big hurdle down....
Still have to deal with the shifting issue .....
